Like Tree2Likes
Old 06-02-2014, 05:23 PM   #4096
evochick's Avatar
Hi Everyone, need some suggestions,
I finally made an A final at a large event in touring car and finished 7th, but I think my setup could be better, I am still getting lots of push on corner entry, I noticed I am having to break earlier than everyone else just to get the noise of the car pointed. I had superior mid and exit corner speed which helped the over all lap time.
I was hesitant to change too many things during the event as the car was super stable and easy to drive (which helps a noob like me)
I already have some thoughts on things to change, but I just wanted some second opinions..
EDIT : Just noticed I had the wrong front blocks written down, they are the 3.5 kit blocks I was using
Thanks.
UnRetired
evochick is offline   Reply With Quote
Old 06-02-2014, 06:01 PM   #4097
CristianTabush's Avatar
By Looking at it really quick:
-Higher rear ride height
-Narrower Front (at least use the 43.5 blocks in the fr)
-Lighter Rear diff oil
-More Front Camber
-Maybe 1-1.5mm more ackerman shims
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 06-02-2014, 06:32 PM   #4098
JimmyMac's Avatar
Yeah, I would run 44.2/43.5 front blocks to get some arm sweep. Do you have any weight up front? If you notice, the Yokomo guys run 30g up front 15g per side. Other than that, everything that Cristian said. If its corner entry off-power, you can go to 4mm rear droop and try that out real quick.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 06-02-2014, 06:39 PM   #4099
evochick's Avatar
Sorry fixed, I was running 43.5 in the end, I didn't like the car with sweep or the wider front (I tried both on practice)
And yes the next battery's ill be running are the lighter Orca, so I was going to try the extra weight at the front.
Car was also still quicker overall with the 3K rear diff oil compared to the 2K.
UnRetired
Old 06-02-2014, 06:50 PM   #4100
JimmyMac's Avatar
You running direct servo horn or a servo saver?
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 06-02-2014, 07:04 PM   #4101
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
Thanks.
More Camber gain, take away inside link shims
.5mm more ackerman
1m front diff wouldn't hurt
but, if you want to try a big change, move front arms back
I like arm sweep, but it can be a somewhat aggressive change which works better with subtle steering movements, not for everyone. just imo
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-02-2014, 07:11 PM   #4102
evochick's Avatar
Servo savers are evil..... I don't even run one in my F1 car.
Just using the long Yokomo alloy horn.
UnRetired
Old 06-02-2014, 07:22 PM   #4103
JimmyMac's Avatar
Yeah, I was thinking more camber gain as well. Speaking of which, does anyone know which ball studs Volker and Hara use on the front and rear inner links? They are definitely shorter and they can run more camber gain than a kit car can with standard ballstuds.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 06-02-2014, 08:35 PM   #4104
evochick's Avatar
I doubt the factory guys use them but I have some of these still from my TC6.1, probably shortest you can get. ill give them a try.
http://www.amain.com/product_info.ph...all-Stud-Set-2
UnRetired
Old 06-02-2014, 09:01 PM   #4105
JimmyMac's Avatar
I was looking at those last night, but I'm gonna try some of my old Cyclone ballstudes that I ran on my original BD. Not sure if they are shorter or not, but I'll see.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 06-02-2014, 09:15 PM   #4106
Hugh Jazz's Avatar
The rear sway bar ball studs
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 06-02-2014, 09:17 PM   #4107
Well, the question was what gives more entry steering, not what would make the car faster
The most effective remedy for lack of turn- in in high to low speed areas is going to be more Ackerman shims, followed by perhaps a gear diff. The Ackerman change will be an isolated adjustment that should not change the behavior of your car in other aspects like the gear diff though. All the other suggestions will make marginal changes, but for example, more camber gain will not necessarily give a noticeable amount of increased grip at the beginning of a corner, but can give more steering in the middle and exit depending on the type of tire.
AE ballstuds, including our TC aluminum ones can all be used to lower the inside camber links for more camber gain. They are the same sized ball.
Old 06-02-2014, 09:33 PM   #4108
JimmyMac's Avatar
D'oH! ..... thanks.....
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 06-03-2014, 01:06 AM   #4109
CraigM's Avatar
I ran my car at 1440 with the weight up front, makes a huge difference, who cares about being over!
Try the weight, short front wheelbase, bump steer, lower camber links (kit), 3 deg rear toe, and more drag brake
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 06-04-2014, 09:38 AM   #4110
Cadman1981's Avatar
What does adding the weight in the front of the car do?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
