Like Tree2Likes
Old 05-08-2014, 07:31 AM   #4066
corally's Avatar
Hello
any one know how use this .Yokomo Downstop O-Ring (YS-7B) ?
are to place on external part of ammo shaft?
corally is offline   Reply With Quote
Old 05-08-2014, 12:31 PM   #4067
RC MARKET's Avatar
SQUARE ALum. & Titanium Screw set for BD7 2014 Black Series
RC MARKET is offline   Reply With Quote
Old 05-12-2014, 03:13 AM   #4068
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default stretched belts
Hi guys,
Has anyone had any experience with belts stretching.
Car has only had three race meets, first meet was spot on, then was crap thereafter. I then noticed the front belt was very loose.
After tightening the front belt and loosening the rear, the car seemed great again.
I hadn't changed anything from the first race.
So I am wondering now had the belt stretched. I race 13.5.
Brad
Xray T4 16 | Sanwa MX11 | Much More Fleta | HW 3.1 | LRP Batteries | Team Argo | Meakin Park | Bayside | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 05-12-2014, 05:24 AM   #4069
thisguy2849's Avatar
Originally Posted by OHBRAD View Post
Hi guys,
Brad
They do stretch and loosen up once they are broken in but that's normal
thisguy2849 is offline   Reply With Quote
Old 05-13-2014, 08:18 AM   #4070
Bar
Hi guys,
Brad
I set the belt tensions when new and haven't had to adjust them since, it sounds like maybe you hadn't tightened the bulkhead screws down and the cams may have moved, I did that after changing the diff and being in a rush I had forgotten to re-tightened the screws
Luke Burr
Bar is offline   Reply With Quote
Old 05-13-2014, 09:52 AM   #4071
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
Hi guys,
Brad
A tiny bit, the belt cam settings on my BD7 have not changed since new
This is running mod & and stock
It may also be possible that the upper deck has moved from a shunt, in this case the belt tension could change significantly
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-13-2014, 09:55 AM   #4072
Cool A little something from the Awesomatix thread
Here a small update what we learned at the first outdoor races:
I have tested at the Worlds Warm Up and now at the ETS race a lot. At the ETS, traction was quite high so I ended up with the Alloy chassis. The car was very very easy to drive, just had a little understeer compared to the "steerkomos... " The Yokomos were unbeliveable fast.
-Fast Freddy Sudhoff
Old 05-14-2014, 06:02 AM   #4073
Default Front Roll Bar Tweak
Anyone finding their front roll bars tweaked from new in black 14 kits? The last 2 i'v had the front roll bar is not flat on the glass and end up with one link about 2mm longer to get them balanced? Not sure if it makes a big difference once its balanced but i'd prefer if it was flat..
kdempsey is offline   Reply With Quote
Old 05-14-2014, 06:12 AM   #4074
Originally Posted by kdempsey View Post
Anyone finding their front roll bars tweaked from new in black 14 kits? The last 2 i'v had the front roll bar is not flat on the glass and end up with one link about 2mm longer to get them balanced? Not sure if it makes a big difference one its balanced but i'd prefer if it was flat..
My kit was the same, bars could have been packed better
ETS RD4 setups from Matsee AT
Old 05-14-2014, 12:15 PM   #4075
Colbynobo's Avatar
Trader Rating: 18 (100%+)
I have 2 2014 Black kits. The roll bar for the 1st one was tweaked and needed immediate replacement. The roll bar for the 2nd one was fine. I had assumed I was the only person who encountered this issue.
Colbynobo is offline   Reply With Quote
Old 05-14-2014, 05:35 PM   #4076
fatchickterian's Avatar
Default Battery guide for BD7 2013/14
Hi all,
I have some high quality plastic battery guide, custom made to suit BD7.
Please take a look the following link thanks!
Battery Guide for Yokomo BD7 2013/14
fatchickterian is offline   Reply With Quote
Old 05-16-2014, 06:08 PM   #4077
AL1983's Avatar
Hi,
I want to replace my phillips head Diff screws to hex head screws.
Will these fit, ZC-F258? or which ones will fit?
Thx!
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 05-17-2014, 08:01 PM   #4078
I think, this doesnt fit.
You need tapping screw even you want hex.
nepiman is offline   Reply With Quote
Old 05-18-2014, 12:19 AM   #4079
I thought I read the new rebuild kits came with hex screws!
Jampot is offline   Reply With Quote
Old 05-22-2014, 12:57 PM   #4080
Raman's Avatar
Trader Rating: 50 (100%+)
Last night I was installing the stabilisers on the rear of my BD7 RS. Slight oversight in design by yokomo on the mount holes for rear bulkhead.
First the supplied screws a M3x8. Holes are M2 either a depth less than 4mm. You can't still deeper because you will run into the screw that holds the top and bottom half of the bulkhead together. Needless to say, I had to search for a shorter m3x4 , and hope it holds in a crash.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
