Old 05-04-2014, 03:17 PM   #4051
Jorge T's Avatar
Yes, front has wider track.
RSD Speedway
Jorge T is offline   Reply With Quote
Old 05-04-2014, 09:06 PM   #4052
AL1983's Avatar
Which body post hole (front & rear) do U guys use to mount a ltc-r body (which hole is best to put the clip)?
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 05-04-2014, 10:13 PM   #4053
JimmyMac's Avatar
Depends how you cut the body. Are you cutting it on the molded lines? I cut mine above the line to mount the body lower on the car. There is about 3mm or 4mm on the front lip.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 05-05-2014, 03:55 AM   #4054
AL1983's Avatar
Post
Frontlip 3-4 mm also.
Old 05-05-2014, 04:51 AM   #4055
So apart from the colour there is no difference between the black and blue kits apart from being price?
Thinking about leaving my current sponser for one looked at xray but drawn more to yokomo not had a yoko since yr4 m2 so many moons ago.
What are peoples thoughts good car,reason for thinking of leaving is lost confidence in my current car.
What parts seem to go arms, hubs,etc
Quietman is offline   Reply With Quote
Old 05-05-2014, 05:35 AM   #4056
Bar
Any guys have any ideas how to get more traction out of slow corners, I use Sorex 32's which is a mounted control tyre?
Luke Burr
Bar is offline   Reply With Quote
Old 05-05-2014, 08:10 AM   #4057
thisguy2849's Avatar
Black series comes with all graphite arms hubs etc. which u will want plenty of those as back ups
thisguy2849 is offline   Reply With Quote
Old 05-05-2014, 08:16 AM   #4058
S.Stew's Avatar
The graphite plastic isn't that bad. I keep one spare of everything except for front knuckles and C hubs, those I keep a couple of each. Realistically though, I've only ever broken 1 C hub. The car is pretty tough!
- Steven Stewart - Kawada USA
www.Kawada-USA.com
S.Stew is offline   Reply With Quote
Old 05-05-2014, 08:21 AM   #4059
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
both 2014's have this
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-05-2014, 08:32 AM   #4060
Colbynobo's Avatar
Trader Rating: 18 (100%+)
I haven't cut my body posts, so they're still at the stock length. When my LTC-R is mounted, there are 6 body post holes exposed above the body in the rear and 4 body post holes exposed in the front. Now that I've settled on the LTC-R as my body of choice, I will soon trim the posts accordingly.
Colbynobo is offline   Reply With Quote
Old 05-05-2014, 08:41 PM   #4061
OZDC's Avatar
Trader Rating: 16 (100%+)
Default Tweaked Suspensions Arms
For a while now I have been checking my suspension arms when rebuilding the car.
I am noticing that they develop a tweak, probably after a few hits or knocks and not necessarily big ones.
For example, if you put the arm on a perfectly flat surface (best if you strip it of all other parts), hold one end and push down on one side of the other I notice that it rocks a little. Sometimes a little others a lot. Compare it to a new arm which will be perfectly flat. Carbon and plastic both do it.
It does affect droop height a little and I have been replacing them, but I was wondering if anyone else has noticed or checked this?
Am I worried about nothing, its starting to get expensive?
Dave
OZDC is offline   Reply With Quote
Old 05-06-2014, 09:13 AM   #4062
Bar
Default Great job yokomo!!
Great job on the new gear diff yokomo!! I took mine apart today after doing a few meets with it to try and bed it in. I found out that the new o-rings are a hell of a lot bigger than the old ones which in turn was causing the pin to rub on the shim, lucky enough my dad had an old rebuild kit with the original o-rings and some new shims, rebuilt it and now it is perfect. Come on yokomo great car only problem with the car sort it out!!
Hopefully there are some team drivers on here who can pass this on to yokomo!!
Luke Burr
Old 05-06-2014, 03:18 PM   #4063
Trader Rating: 22 (100%+)
Is it 2014 conversion kit still available or do you have to piece it together?
sstretch is offline   Reply With Quote
Old 05-06-2014, 03:29 PM   #4064
Hugh Jazz's Avatar
Only a limited release. Haven't seen one for a few months now
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 05-07-2014, 04:04 AM   #4065
niznai's Avatar
Just a quick question.
What is the longest DCJ shaft Yokomo offer? I have the ones marked 40.6, interested in something a bit longer than that, 1mm would be enough.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
