Like Tree5Likes
Old 04-30-2014, 03:58 PM   #4021
Colbynobo's Avatar
Trader Rating: 18 (100%+)
Before I purchased my two BD7s I was running a Xray T3. Therefore, I have a lot of Xray T3 suspension parts sitting around. However, I'm not sure if I'm ready to try making a Frankenstein car. However, it's nice to know that should I ever burn through my current pool of BD7 c-hubs that I can grab one of the T3 parts.
Colbynobo is offline   Reply With Quote
Old 05-01-2014, 11:34 AM   #4022
Raman's Avatar
Trader Rating: 54 (100%+)
I just picked up a BD7 RS and will be racing on Asphalt. Been brushing up on this thread..
1. front CVD axle needs to be trimmed,
2. Plastic spool and drive cups needs to be replaced with alu version
3. Arms, knuckles and uprights are brittle <--- is this in reference to std ones or carbon reinforced ones?
4. Diffs leak, use Kyosho O ring
Stabiliser: this is the rear one.. What do I use for front? Same one?
http://www.amain.com/product_info.ph...Stabilizer-Set
Anything else I missed?
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 05-01-2014, 12:27 PM   #4023
Front set is this one: http://www.amain.com/product_info.ph...er-Set-10-16mm
It is shorter then the rear stabiliser.
walzjer is offline   Reply With Quote
Old 05-01-2014, 01:00 PM   #4024
Trader Rating: 15 (100%+)
Get an Xray hard t3 front bumper and parts breakage will be minimal.
www.5280Raceway.com | Racing. Elevated.
samsking is offline   Reply With Quote
Old 05-01-2014, 01:27 PM   #4025
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
1. front CVD axle needs to be trimmed, Yes
2. Plastic spool and drive cups needs to be replaced with alu version That is the consensus
3. Arms, knuckles and uprights are brittle <--- is this in reference to std ones or carbon reinforced ones? Not true, stock are soft, very forgiving
4. Diffs leak, use Kyosho O ring or soak kit o-rings in silicon diff fluid before assy, have no leaks with this procedure
You may want to stock up on Blue/Pink springs
Kit springs are very soft, could be ok for street bashing, not racing
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-01-2014, 01:28 PM   #4026
Raman's Avatar
The front doesn't come with the hardware?
Old 05-01-2014, 01:30 PM   #4027
Raman's Avatar
I have a spare sets of TRF dampers standard and short, was planning on running those for now.
Blue and Pink are med and hard?
Old 05-01-2014, 02:29 PM   #4028
thisguy2849's Avatar
Running asphalt get hpi silver springs for front and rear
thisguy2849 is offline   Reply With Quote
Old 05-01-2014, 03:13 PM   #4029
Raman's Avatar
Thank you
Old 05-01-2014, 03:20 PM   #4030
Thank you
Yes, that will do the job
Old 05-01-2014, 03:53 PM   #4031
Plastics are high quality, good fit and strong both standard and graphite.
The graphite C hubs may be brittle but I haven't used them.
Certainly buy the kyosho orings P5. They now appear to be included with the kits as standard and they are provided with the diff maintenance kit. My diff case was faulty mis manufactured or bad tolerance which caused the leak. A number of other local drivers have had the same diff leaking issues with the 2014 which wasn't a problem with early kits. Keep this in mind if you have leakage issues from the outdrives.
TRF shocks will be good (I assume if you have shocks you have springs you already have springs) the yokomo springs seem good but just use what springs you have.
If you are buying a set of springs, Ride and HPI springs sets are the most popular with local drivers.
frozenpod is offline   Reply With Quote
Old 05-01-2014, 03:59 PM   #4032
Raman's Avatar
I do have TRF springs, but do not presently have any HPI springs. Are the 6543 the correct silver springs?
Old 05-01-2014, 04:44 PM   #4033
Unsure as I don't use HPI springs, TRF springs will be fine though.
Old 05-01-2014, 05:11 PM   #4034
The 6543 is the right spring
Old 05-01-2014, 08:58 PM   #4035
fatchickterian's Avatar
Default BD7 Battery Guide
Hi All,
I'm selling battery guides for BD7 in blue colour plastic, please take a look in the following link if interested thanks!
Adelaide F.S. BD7 Battery Guide (Blue Plastic)
fatchickterian is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
