Like Tree2Likes
Old 03-25-2014, 10:11 PM   #3916
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
Originally Posted by hanzo3 View Post
Where can I find an English bd7 manual?
From Yokomo
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-26-2014, 05:44 AM   #3917
Originally Posted by JimmyMac View Post
Are you using the kit orings? If so, try the Kyosho P5 orings. For me it took out the binding/tight feel of the outdrives. My diff has had a few months on them and run every weekend with no problems at all. Nice and much smoother than kit built.
Thanks I will try that
lk2849 is offline   Reply With Quote
Old 03-27-2014, 12:12 AM   #3918
CraigM's Avatar
My diffs feel terrible with the p5 orings - really grabby. I'm hoping the new yoke ones are a better fit, till then I'm just letting them leak
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 03-27-2014, 12:56 AM   #3919
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Umm must be your weather because they feel fine to me and everyone else around here.
I also put the updated diff rebuild kit in and they are the exact same P5 orings from Kyosho...
Racing4Evo is offline   Reply With Quote
Old 03-27-2014, 06:43 AM   #3920
Bar
I just used the standard o-rings on the diff, and have so far had no leakage issues. I did spend quite a bit of time sanding the back of the gears down as the diff was very tight, even for a new diff, I also ran an arm reamer through the crown gears as these were very tight on the shaft
Luke Burr
Bar is offline   Reply With Quote
Old 03-28-2014, 11:06 PM   #3921
jsr555's Avatar
Trader Rating: 17 (100%+)
Default BD7 gear diff
I'm currently building my BD7 and read most of the tips on here, but the gear diff. The instructions appear to say fill it to about 80%. I've only ever built xray gear duffs before and that seems a lot of oil. Are people putting that much oil in the Yokomo diffs or going just below the top of the gears.
It is very tight... Feels more than 2000. I'm thinking it has too much oil in it or I should had sanded the back of the gears a little...
Any advice?
Xray T4 - Yokomo Bd7-14 - HPI Pro5 - Powered by Hobbywing
HPI RS Pro - HPI Pro 3 - ??
jsr555 is offline   Reply With Quote
Old 03-28-2014, 11:28 PM   #3922
evochick's Avatar
Any advice?
If you can find Craig M's diff build on facebook, its a big help,
They work best when you sand the gears so there is non on the mould dimples on the back of the gears, 2 gaskets also help for some reason,
UnRetired
evochick is offline   Reply With Quote
Old 03-29-2014, 12:27 AM   #3923
jsr555's Avatar
Thanks. Dimples gone. I'll put it back together and see how it goes this time.
Old 03-29-2014, 08:11 AM   #3924
Send a message via Skype™ to orzel24
If anyone want winning RS setup there is a link:
Any questions PM or fb
orzel24 is offline   Reply With Quote
Old 03-31-2014, 10:15 PM   #3925
Has anyone else had diff leakage issues that were not fixed by using P5 orings?
As after 16/17 runs one of the P5 orings started to leak.
I used green slime liberally applied possibly why the original orings and the P5 orings didn’t leak immediately.
frozenpod is offline   Reply With Quote
Old 04-01-2014, 07:34 AM   #3926
Cool
I've yet to have any diff leakage with original BD7 diffs, standard o-rings, or P5
Old 04-01-2014, 11:41 AM   #3927
Jorge T's Avatar
Any advice?
I have 3 yokomo diffs all with OEM seals and none leak.
I only fill the diff to the middle of the cross pins. Think of these gear diffs as little gear pumps. If there is too much oil in them the pressure will make them leak out the seals.
RSD MS
Jorge T is offline   Reply With Quote
Old 04-02-2014, 02:04 AM   #3928
RC MARKET's Avatar
YOKOMO was update gear diff O-Ring is Red color .
1st lot was sold out,
second lot coming friday arrive.
RC MARKET is online now   Reply With Quote
Old 04-02-2014, 02:36 AM   #3929
Either your lucky or doing something different perhaps you might want to share.
Old 04-02-2014, 07:25 AM   #3930
Cool
As far as leaking from the diff output seals, I don't think I've done anything special, built per the instructions mostly
Checking axial play, and sanding oversize gears if necessary
World Champion, Jilles Groskamp has a pro-tip video here, you may find it useful
+ YouTube Video
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
