Old 03-18-2014, 01:01 PM   #3871
mikeygar's Avatar
Trader Rating: 14 (100%+)
Originally Posted by RedBullFiXX View Post
I've been running mod with plastic gears
Most guys I know do as well
Can't speak for Serpent or X ray quality, haven't tried one if those yet
I run 13.5 boosted on a gear diff I built for my BD5 3 years ago and it's still running well, but am using 4 gears. Never tried the 2 gear setup, too chicken my diff would give out :-)
So 4 metal gears, are lighter than 6 plastic gears ?
I'm not convinced of that
Not that this is something I would test, but can someone break out the scale to Bust this Myth please
no need to bring out the scales, I have the metal gears and they are HEAVY...
talking about diffs, Yokomo just came out with a new diff maintenance kit with red/orange o-rings.
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 03-18-2014, 07:34 PM   #3872
XSLR8's Avatar
Originally Posted by jdm19turn View Post
no were talking about the out side bearing on the lay shaft pully being binded up by the countersunk washer
Sorry you have misunderstood what I ment, for the people having binding issues with the lay shaft are you using the spur gear that comes in the kit or have you changed to a smaller/different brand spur?
This will relate to the lay shaft binding.
VBC Racing Australia.....FUTABA AUSTRALIA.....Volante tires.....WTF Fans.....R.A.B Hobbies....President www.serccc.com.au
XSLR8 is offline   Reply With Quote
Old 03-18-2014, 08:49 PM   #3873
jdm19turn's Avatar
im using the yokomo 96 spur gear
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 03-18-2014, 11:24 PM   #3874
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Panaracer (Yokomo and HPI repackaged) and RW spur gears fit and come in all different sizes.
Racing4Evo is offline   Reply With Quote
Old 03-18-2014, 11:56 PM   #3875
JimmyMac's Avatar
Xenon
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 03-19-2014, 01:23 AM   #3876
XSLR8's Avatar
Ok so my point is if you are trying to use a different spur you have to be careful it is no thicker than the original, even slightly otherwise the button head screws protrude further out which pushes the pully further out and then you end up tightening the washer and screw against the bearing which causes the binding.
As for the guy having problems using a panaracer spur I have no idea, have you isolated it to the lay shaft? Or have you checked to see it is not something else causing the bind as other common binding issues are putting front spool pulley on back to front and not centering the rear diff correctly.
Old 03-19-2014, 03:16 AM   #3877
CraigM's Avatar
Trader Rating: 34 (100%+)
Has anyone tried the old motor mount on the new car?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 03-20-2014, 03:13 PM   #3878
I finally found a good setup.
But I got a bad tire wear... the front and rear right tire becoming rills at the inside just after 10 runs. The car is then undriveable.. new tires and all is good.
All my club colleagues are running these tires (Solaris 35) without any problems for 30-40 runs. Of course the tires are slower then but its still the same feeling.
Whats wrong with my setup?
I use 17.5 motor... not too fast for the tires
YOKOMO Touring Car BD-7-bildschirmfoto-2014-03-20-um-22.11.19.jpg   YOKOMO Touring Car BD-7-foto.jpg
walzjer is offline   Reply With Quote
Old 03-20-2014, 03:42 PM   #3879
Setup looks fine, is it a controlled tyre build?
Maybe you're on a softer/smaller insert than the other guys?
That tyre looks like it's been run outdoors on an indoor insert.
cyclonetog is offline   Reply With Quote
Old 03-20-2014, 03:44 PM   #3880
It's a handout tire. Solaris S-T35ESM3W all are using the same on our asphalt track.
Old 03-20-2014, 03:51 PM   #3881
Is that a front or rear tyre?
Do they all look the same?
frozenpod is offline   Reply With Quote
Old 03-20-2014, 03:53 PM   #3882
The one in the picture is the front right tire. The rear right has also rills, but not so strong. Left side is fine. We've got 4 left and 2 right corners at our track (I posted a picture a few sides before)
Old 03-20-2014, 04:26 PM   #3883
Your setup looks ok and the tyre doesn't look that bad.
I would suggest to test with 2 deg of negative camber.
BTW are you using tyre additive.
Old 03-21-2014, 12:13 AM   #3884
Okay I will try.
I use no additive. The track is too dirty at the moment.
Old 03-21-2014, 12:43 AM   #3885
I suggest you start using tyre additive as it makes a huge difference to the performance of used tyres.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
