Like Tree6Likes
Old 03-18-2014, 02:19 AM   #3856
When I first build my diff it was abit tight, but then I found out that it wasn't the skimming off the diff there was binding up. It was the small gear, because they was abit tight on the gross pins, reamed them out with my 2 mm hex driver problem solved.
No need to sand all gears and reshim.
Just my 2 cents on gear diff
Cp Grafix is offline   Reply With Quote
Old 03-18-2014, 02:33 AM   #3857
XSLR8's Avatar
When you guys are talking of the layshaft binding, are you using the original spur gear or another brand of spur?
VBC Racing Australia.....FUTABA AUSTRALIA.....Volante tires.....WTF Fans.....R.A.B Hobbies....President www.serccc.com.au
XSLR8 is offline   Reply With Quote
Old 03-18-2014, 03:09 AM   #3858
jdm19turn's Avatar
your probably right but i check everything I'm abit anal i check those gears on the cross pins as well when i go through mine diff every diff is different the injection molding machine making plastic gears isn't perfect they all vary alittle from batch to batch i know i work in plastic extrusion
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 03-18-2014, 03:30 AM   #3859
jdm19turn's Avatar
no were talking about the out side bearing on the lay shaft pully being binded up by the countersunk washer
mi4 ,mi5
Old 03-18-2014, 04:18 AM   #3860
Default Gear diff
[QUOTE=mikeygar;
I don't know why you would, the diff, if properly built is super smooth and lasts really long, and the stress on the plastic gears might be too much and may cause failure. Might be worth trying with metal gears :-)[/QUOTE]
Hi mike, thx for the feedback. The reason I ask is that I prefer to use heavier diff oil and by using two gear, it will give me more rotation thru the corner and more forward traction on the straight. Not sure my theory make sense to u. Yes, u are right, yokomo diff are pretty smooth.
thesaint is offline   Reply With Quote
Old 03-18-2014, 06:14 AM   #3861
Aaron_M's Avatar
Originally Posted by chapmanlung View Post
Thanks for the reply...
Yes I am talkign about the plastic spool that came originally in the box...
He has gone through three of them already..... Luckily I have not broken anything yet....Just want to know what is the issue....
He lost the little ring that goes on the end of the spool....might that have an impact?
cheers
The plastic spool will not take any impact - a slight knock or collision can break it. The ring at the end just helps prevent the plastic from spreading when the drive shaft engages it during accelerating / braking.
Best to either get the yokomo spool or the Spec R spool is very good and about half the price
Yokomo BD7
Aaron_M is offline   Reply With Quote
Old 03-18-2014, 06:21 AM   #3862
JimmyMac's Avatar
The shimming also affects the pressure on the oring. I've built 4 different diff, each different. Before you build the diff, pin the outdrives in the diff halves with the oring and shim. Rotate the outdrive. If it binds, reshim. If that doesn't work then switch to the Kyosho red orings.
Reaming the planetary gears also helps as well as sanding the flashing off the backs of the gears. Put it all together for an awesome diff. It goes a long way for a consistent handling BD7!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 03-18-2014, 09:10 AM   #3863
mikeygar's Avatar
Trader Rating: 14 (100%+)
I read somewhere before that the Serpent and Xray guys like to do this. If for 17.5 blinky, then maybe it can be done with plastic gears, but for anything faster, i'd use the metal ones.
Nothing sounds more horrible than a crunched up diff and I've heard plenty from some guys who run Tamiyas here :-)
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 03-18-2014, 09:34 AM   #3864
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I've been running mod with plastic gears
Most guys I know do as well
Can't speak for Serpent or X ray quality, haven't tried one if those yet
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-18-2014, 09:47 AM   #3865
DirkW's Avatar
Also with only 2 instead of 4 gears? (at least that's what they were talking about. )
Dirk
Current cars: Xray T4'17 | Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): (Xray T4'18) | Xray X1'17(8) | Yokomo YZ-2 DTM | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 03-18-2014, 10:18 AM   #3866
Oh I see
What would be the advantage of two steel gears vs: 4 plastic ?
Old 03-18-2014, 10:24 AM   #3867
Jochim_18's Avatar
Oh I see
Less gear it just make the gear diff lighter and less rotating mass.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 03-18-2014, 10:31 AM   #3868
DirkW's Avatar
Oh I see
The idea is apparently this:
But I'm also wondering if that really would do anything different than with just changing to a (matching) different diff oil...
Different... differential... getting difficult with all these diffs
EDIT:
Are you sure that 2 metal gears are lighter than 4 plastics?
Dirk
Old 03-18-2014, 10:39 AM   #3869
Jorge T's Avatar
The problem with only 2 planet gears is that the diff will unload easier making for inconsistent handling on high grip. It may work on low grip situations but will not work very well on high grip.
RSD MS
Jorge T is offline   Reply With Quote
Old 03-18-2014, 11:31 AM   #3870
Cool
So 4 metal gears, are lighter than 6 plastic gears ?
I'm not convinced of that
Not that this is something I would test, but can someone break out the scale to Bust this Myth please
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
