Old 03-16-2014, 11:50 AM   #3826
mikeygar's Avatar
Trader Rating: 14 (100%+)
Originally Posted by JimmyMac View Post
It feels smoother, but I haven't ran it back to back to compare it yet because I was doing back to back short shock vs standard shock testing. If I have time I'll do that today with the diffs.
does the silicon feel lighter with metal gears? To clearly put it, does a 1000 with plastic feel the same as a 1000 with metal gears? In the Tamiya's, I noticed that with steel vs plastic, you have to run a much thicker oil to get the same feel as plastic gears.
Originally Posted by Racing4Evo View Post
Feels the same on track. I had no problems with the plastic gears either so that money for metal gears should be spent elsewhere.
Agreed. I've been running a diff from my BD5 days, ran it with mod, and still run it today with 13.5 boosted, never had any problems either. Ordered the metal ones out of curiosity. And am still curious hahaha!
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 03-16-2014, 02:40 PM   #3827
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
Does anyone know if the stock BD7 RS spring cups fit HPI springs? Or do you need these?
https://www.teamyokomo.com/partslist...ts_b7_s3n.html
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 03-16-2014, 02:55 PM   #3828
Originally Posted by frozenpod View Post
I have the 2014, black shocks with titanium coated shafts. I am surprised they are anything short of exceptional. Would a shim to squeeze the orings be worth a try?
Following up from this I spent several hrs building shocks and trying other orings from other brands of shocks.
From the original yok shocks I have 2 ok shocks (100% stock) that can run little to no rebound without sucking in air, 1 not great but workable shock requires about 25% rebound to prevent sucking in air (slightly better with mugen orings) and one that sucks in air badly with stock orings. It is a little better with other orings but is sill not up to the task.
The best fitting orings were mugen reds followed by kyosho clear.
frozenpod is offline   Reply With Quote
Old 03-16-2014, 03:00 PM   #3829
Have you tried the Yok blue oring?
cyclonetog is offline   Reply With Quote
Old 03-16-2014, 03:04 PM   #3830
Yes, the shocks have 2 x yok blue oring with the thin spacer.
Old 03-16-2014, 05:45 PM   #3831
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Are you using black bladders? The clear kit bladders are a one time use kind of part.
Racing4Evo is offline   Reply With Quote
Old 03-16-2014, 05:48 PM   #3832
Yes I have the black bladders.
Old 03-16-2014, 07:45 PM   #3833
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
HPI springs are a direct fit to BD7 Damper, not sure about RS ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-16-2014, 08:30 PM   #3834
I run with my DIY chassis, very good..
asuradahk001 is offline   Reply With Quote
Old 03-16-2014, 09:30 PM   #3835
RAL
RAL's Avatar
Thanks DB!
Old 03-17-2014, 12:05 AM   #3836
What is DIY chassis? Couldn´t find it anywhere.
desaix is offline   Reply With Quote
Old 03-17-2014, 02:47 AM   #3837
DirkW's Avatar
DIY... usually means Do-It-Yourself
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YR-10F | Yokomo R12C3* | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Team Associated RC10R5.1 FT*
Future cars (soon): Yokomo YRX-12* | Tekno SCT410.3* | Xray X10 '16* | Yokomo YZ-2 CA | VIP-Performance Vorlon
DirkW is offline   Reply With Quote
Old 03-17-2014, 05:36 AM   #3838
Jorge T's Avatar
Unless the pitch of the plastic vs metal gears are different the oil should "feel" the same. (That is making sure the plastic or the metal gears are not tight in the diff case.)
RSD Speedway
Jorge T is offline   Reply With Quote
Old 03-17-2014, 07:54 AM   #3839
Default Two or four satellite gear
Hi all, have anyone try to use two satellite gear in the rear gear diff on bd7 2014? If yes, in what condition is this setting preferred?
thesaint is offline   Reply With Quote
Old 03-17-2014, 02:56 PM   #3840
Shocks appear to be sorted, I found the oring cap was bottoming out before the thin washer made contact with the oring on the 2 not so good shocks.
The 2 orings were just protruding from the shock body so I assume the design was to have the washer press up to the bottom of the shock body applying slight pressure to the orings to prevent movement and leaks.
I removed approximately 0.1mm from the cap which allowed the thin washer to press against the oring and stop air being sucked in.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
