Like Tree5Likes
Old 03-04-2014, 05:12 PM   #3736
Robertcooper88's Avatar
Originally Posted by AL1983 View Post
Hi,
I'm trying to get my hands on some of the old style HPI silver springs (#6543) for touring car that have completely silver coils, rather than the newer ones that have black coils with a silver paint mark.
If anyone has any that they want to part with please let me know.
Superior hobbies has them
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
Old 03-04-2014, 05:47 PM   #3737
JimmyMac's Avatar
Originally Posted by Bar View Post
I have just fitted an alloy servo arm to my bd7, the ball stud now sticks through quite a bit I fear as it now goes into metal it will work it's way loose, so are there any shorter ball studs and tips what people have done so it doesn't come loose?
When I had my blue BD7 with the black direct aluminum servo horn I ran a blue lock nut on the back.
http://www.amain.com/product_info.ph...Locknut-Blue-4
Now I run the XRay servosaver with a silver lock nut on the back to match my Black Edition.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 03-04-2014, 06:33 PM   #3738
corallyman's Avatar
Trader Rating: 98 (100%+)
Does anyone know what aluminum servo horn Volker is using at the last ETS race? I need one like it where the vertical mounting point is away from the servo a bit. Mine are all too close to my servo. Thanks for the help.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 03-04-2014, 07:41 PM   #3739
JimmyMac's Avatar
The Yokomo aluminum horn.
http://www.teamyokomo.com/partslist/...b7_204fsk.html
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 03-06-2014, 05:43 AM   #3740
Bar
yeah I have done the same, except I used a black lock nut :P, with the yokomo alloy servo arm
Luke Burr
Bar is offline   Reply With Quote
Old 03-06-2014, 05:46 AM   #3741
Bar
Have you got a link to them, the web site isn't the best to navigate?
Luke Burr
Old 03-06-2014, 08:18 AM   #3742
AL1983's Avatar
Post Silver springs!
I emailed and asked about the all silver ones, but they haven't got them in stock for a long time, only black ones.
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 03-06-2014, 01:20 PM   #3743
CraigM's Avatar
Trader Rating: 34 (100%+)
There's zero chance of buying the silver silver springs online. Your best hope is to find a retired HB driver who still has some, but there's hardly any difference between the black silver and the silver silver.
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 03-09-2014, 12:36 PM   #3744
Got my BD7 2014 last week and had a first run yesterday. And now a couple of questions:
I ran a BD5WC before and have a complete set of roll bars, can i use the ones for the rear too? There are shorter and build like in the front.
Wich O-Rings are you using in the shocks? And wich bladders? I build it with "old" HotBodies I used with my BD5WC but it was a nightmare to build these shocks.
I also heard that some people running shorter shocks... are these like the old from the BD5WC?
Thank your for your help.
Greetings form Germany.
walzjer is offline   Reply With Quote
Old 03-09-2014, 06:37 PM   #3745
JimmyMac's Avatar
A lot of people are using the Yokomo blue orings with the Yokomo black bladders and the 3x1.1mm pistons. I'm running the double blue orings with thin white spacer.
As for short shocks, I ran them for awhile, but just went back to the standard kit shocks. I think the standard shocks feel better for my track conditions (low/med bite carpet). It feels like it's rolling better through the whole turn. I'll save my short shocks for very high bite tracks. This is for 17.5t blinky class.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 03-09-2014, 06:50 PM   #3746
Same here Jimmy, was talked into the short shocks from my LHS but I also run on low traction carpet. just wasn't getting enough grip around the corners.
jonston is offline   Reply With Quote
Old 03-09-2014, 07:26 PM   #3747
JimmyMac's Avatar
Good to see someone with similar results to back up mine. Now I won't be afraid to leave them at home.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 03-10-2014, 04:50 AM   #3748
Bar
Ronald Volker's setup is up on PetitRc from the Gran Canaria ETS round, unfortunately the link seems to be broken though
Luke Burr
Old 03-10-2014, 05:19 AM   #3749
Are that the right ones?
O-Ring: YOK-YS-7HG
Bladder: YOK-YS-8HD
Pistons: YOK-BD-S113
And what about the roll bars?
Will it have an effect if their shorter when i use the "old" ones from my BD5WC? Or will it be the same like the long version.
Old 03-10-2014, 11:16 AM   #3750
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Short shocks can be used on med grip carpet. I had a good test with them on Sweep QTS32 tires and Jaco Blue. It added initial steering sharpness but the car stays very flat and more stable in the middle of the corner.
What tires are you using?
Racing4Evo is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
