Old 03-02-2014, 06:57 PM   #3721
JimmyMac's Avatar
Originally Posted by CanyonCarverR1 View Post
Just ordered a 2014 Black Edition, do you guys have any build tips? I know it's necessary to edge glue the chassis, but what about the shock towers, etc? I'll be running on semi-bumpy med traction asphalt.
Pay special attention to building the gear diff. Sand down the gears and diff cup with #400 sandpaper. Make sure the out drives turn smoothly without binding before you put the diff together. The smoother the diff the more consistent the handling. You may need to switch to Kyosho red orings. Some people have had success with them, some haven't. My kit orings bound up my diff in my Black Edition. I switched to the red orings and everything smoothed out. Also soak the orings before you build the diff.
Build the rest as per instructions. You may need to pull shims out of the center pulley if it's too tight for your liking.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 03-02-2014, 09:29 PM   #3722
Hi, can you advice what to soak the o-ring with? Thanks!
mystique13 is offline   Reply With Quote
Old 03-02-2014, 09:36 PM   #3723
JimmyMac's Avatar
With the oil you are going to use or Associated Green Slime. This allows the orings to swell up for assembly since they will swell up eventually if you don't.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 03-03-2014, 09:10 AM   #3724
AL1983's Avatar
Hi,
Which other WHITE low friction belt (front 516mm) does fit the BD7?? For the rear the Xray ones have the same length 189mm.
Team Bomber are sold out everywhere or way overpriced.
Thx!
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 03-03-2014, 11:09 AM   #3725
JimmyMac's Avatar
Originally Posted by AL1983 View Post
Hi,
Which other WHITE low friction belt (front 516t) does fit the BD7?? For the rear the Xray ones have the same teeth count 189.
Thx!
I don't think you need then but if you must then I think Top fits.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 03-03-2014, 01:41 PM   #3726
RC MARKET's Avatar
Hi,
Thx!
TOP had this white belt
RC MARKET is offline   Reply With Quote
Old 03-03-2014, 02:23 PM   #3727
Cadman1981's Avatar
When i installed my conversion kit, the 2012/2013 kit stock spacers for the suspension arms did not fit at all. When i tightened down the toe blocks, all of my arms binded, this included my graphite arms and the plastic kit stock arms. I had to sand all of them to fit, and use thinner spacers for the arms to have free movement up and down, and not back and forth on the shaft movement, anyone else have this issue?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 03-03-2014, 03:36 PM   #3728
CanyonCarverR1's Avatar
Do you have links for the front and rear belts?
CanyonCarverR1 is offline   Reply With Quote
Old 03-03-2014, 03:56 PM   #3729
evochick's Avatar
I cant say i had any issues with my conversion kit, but i dont think i was using the kit spacers, i think i was using associated spacers as i had plenty floating around (unless the kit washers are blue ? )
With my original kit i was using .02 shims anyway to remove slop, i think i had to go down to .01 shims, but that was all.
UnRetired
evochick is offline   Reply With Quote
Old 03-03-2014, 07:16 PM   #3730
JimmyMac's Avatar
If I remember correctly, my Black Edition did not need as much fine tune shimming for arm spacing. Kit shims worked fine except up front where I might have added 0.2mm.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 03-04-2014, 06:32 AM   #3731
Bar
I have just fitted an alloy servo arm to my bd7, the ball stud now sticks through quite a bit I fear as it now goes into metal it will work it's way loose, so are there any shorter ball studs and tips what people have done so it doesn't come loose?
Luke Burr
Bar is offline   Reply With Quote
Old 03-04-2014, 07:10 AM   #3732
Blue thread lock is usually sufficient. But if your not comfortable with that, you can add a nut on the back side. Dremel the execs off on the backside if you don't like how it looks. Make sure to have the ball stud screwed on the servo horn before you dremel. That way if you damage the threads at all, the servo arm will fix the threads
Juan Aveytia is offline   Reply With Quote
Old 03-04-2014, 07:40 AM   #3733
cyba888's Avatar
Depends how far it sticks out...you can add spacer in between
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 03-04-2014, 07:51 AM   #3734
Bar
Yeah I was thinking thread lock, don't really want to dremel it as it won't be black at the end then, my ocd won't allow it lol. The thread sticks out about 3mm, if I add a spacer it will change the angle of the arm Cyba
Luke Burr
Old 03-04-2014, 05:38 PM   #3735
AL1983's Avatar
Hi,
I'm trying to get my hands on some of the old style HPI silver springs (#6543) for touring car that have completely silver coils, rather than the newer ones that have black coils with a silver paint mark.
If anyone has any that they want to part with please let me know.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
SEO by vBSEO 3.5.0
