Like Tree2Likes
Old 01-30-2014, 12:12 PM   #3601
Colbynobo's Avatar
Trader Rating: 18 (100%+)
Originally Posted by swimbikerun View Post
The Tamiya 416-8 bumpers are almost a plug and play solution. They are thinner so you will need to cut the ribs on the body mount to slide the bumper brace on. Awesomatix USA offers a hard bumper option for their car which is a Tamiya 416-8 bumper. Your other option is the hard bumper for the T3 by Xray or RSD. You will need to oversize the body post holes in the bumper slightly and also dremel the edges of the bumper slightly.
Obviously, I didn't look close enough. The hardened Xray bumper does a good job on my T3. I'll order another one for my BD7 and get the Dremel warmed up. Now that I've built the car and have more of an idea what support parts I'll need I have to make another Amain order anyway. I'll throw the bumper in with that. I can't remember whether I read it in this thread or not, but do the offset Xray spur gears work on BD7s? If not, maybe the Serpent ones work?
Colbynobo is offline   Reply With Quote
Old 01-30-2014, 04:40 PM   #3602
AL1983's Avatar
Yokomo BD-7 Super Precision Bearing Set (B7-BBP)
Anyone know if these yokomo bearings are Ceramic? if not are they worth the price?
Thx!
AL1983 is offline   Reply With Quote
Old 01-30-2014, 05:02 PM   #3603
JimmyMac's Avatar
My guess is no, they are not ceramic. If I remember correctly, one ceramic bearing from Yokomo was like $10. I use bulk bearings. Like a few dollars for a set of 10. Mainly because our carpet track is horrible for getting carpet fuzz into the wheel bearings. There-fore I have no problems with throwing out a bearing and replacing it with a low cost one that I know I will throw out again. At least for club racing.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 02-02-2014, 08:23 AM   #3604
Crashmaster's Avatar
Default Wet Setup
Hi giuys,
After abit of advice on setup if anyone can give me a hand.
Running in the wet I'm really stuggling to get the car to turn, both initial turn in and rotation mid corner. As the track dries out the car switches on and drives really well but just abit unsure on what to try.
I've attached the setup I ended up with if anyone could take a look and give me any advice? - Note I'm running the kit 4 deg caster not 6 as in the sheet!
So far I've tried:
Yok yellow springs frnt, blue rear (no better just more on edge)
Various shock postions
2.5 deg rear toe (lost too much traction with this, particulary in the greasy conditions!)
Spool up front (even less off throttle steering)
Thanks for any help
Dan
Crashmaster is offline   Reply With Quote
Old 02-02-2014, 08:29 AM   #3605
Trader Rating: 20 (100%+)
Originally Posted by Crashmaster View Post
Hi giuys,
So far I've tried:
Thanks for any help
Dan
dont chase the setup. Just wait till the track dries.
Donny Banks is offline   Reply With Quote
Old 02-02-2014, 08:43 AM   #3606
Unfortunately we race in these conditions over the winter with round by round scoring so can't just wait for it to dry up for a FTD run... Unfortuantely other cars are alot stronger in these conditions too not struggling with the lack of steering.
Old 02-02-2014, 10:02 AM   #3607
Hi giuys,
So far I've tried:
Thanks for any help
Dan
I'd think a good place to start would be short camber links and less camber. I've noticed in low-grip (never raced in wet, though), 2* camber just doesn't work because the contact patch isn't even enough to get the car to roll over onto the tire. Going with much less camber (like 1* or even 0.5*) would give more of a contact patch, and then as the car rolls, the shorter camber link will give more camber gain.
EDIT: Taking another look at your setup sheet, I see you have a long front link and short rear link. The rule of thumb I've sort of come to is that a short link gives more initial grip (corner entry) and less ultimate grip (mid corner), while a long link gives less initial grip and more ultimate grip. So with a long front link and short rear, I'd kind of expect a car that doesn't want to turn-in, but might get loose once it has.
Also, you might try softer shock oil. Having the front thicker than the rear should also help with turn-in.
-Mike
Old 02-02-2014, 02:27 PM   #3608
Bar
Hi giuys,
So far I've tried:
Thanks for any help
Dan
Alright dan, are you running a ball diff in the rear or gear diff, the ball diff seems to transform the car in those wet and slippery conditions?
Luke Burr
Bar is offline   Reply With Quote
Old 02-03-2014, 02:26 AM   #3609
peter.'s Avatar
my yokomo is for sale
Yokomo BD7+Option parts
peter. is offline   Reply With Quote
Old 02-03-2014, 06:46 AM   #3610
wazee's Avatar
Could anybody tell me if there are any (internal) differences in the new and old shocks? Different sizes of o-rings or anything?
wazee is offline   Reply With Quote
Old 02-03-2014, 06:55 AM   #3611
peter.'s Avatar
no all the same
Old 02-03-2014, 06:55 AM   #3612
No difference, only the anti-friction treatment
andrease is offline   Reply With Quote
Old 02-03-2014, 02:03 PM   #3613
AL1983's Avatar
How do I know by just looking at the part or part nr that the suspension mounts are for FF or RR?
Are there any FR or RF one piece in black version?
Thx!
Old 02-03-2014, 02:20 PM   #3614
Hey up Luke,
Running a gear atm, speaking to Dale think I'm going to try thinner diff oil to try and help it rotate. Know the guys have had a bit of success with the ball diff just trying to avoid it atm....Might end up having to bite the bullet though!
Cheers for the answers though guys, much appreciated!
Dan
Old 02-03-2014, 03:56 PM   #3615
Bar
Hey up Luke,
Dan
Yeah running thinner oil will definitely help mate, Jordan was running about 700 I think. The ball diff does seem to make quite a big difference with the bd7, seems to make the car rotate a lot more. Hpi silver springs all round, spool at the front and the ltc-r helps a lot as well
Luke Burr
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
