Old 01-29-2014, 07:51 AM   #3586
grapejuice's Avatar
Trader Rating: 125 (100%+)
Originally Posted by Colbynobo View Post
Good going Evochick.
For those who rebuilt their rear differential with the Kyosho o-rings (KYOORG05) and found it to be a degree or two stiffer than expected (I believe Grapejuice said 1000 cst felt more like 2000 or 3000 cst), did it eventually break in and become more like what you were aiming for or did you have to return to the stock o-rings? I'm about 75% through the build on my BD7, but want to know if I should stop and re-do the differential now.
Mine never got any free'r, that's even running mod with it...I've also not had issues with my 2014 diff leaking with the stock o-rings.
MHOR RC Raceway / 5280 Raceway
grapejuice is offline   Reply With Quote
Old 01-29-2014, 07:53 AM   #3587
It's going to be fascinating to see if Hara can compete with Volker, or vice versa. Also to see if Umino will "help" Hara as much as Volker etc.
cyclonetog is offline   Reply With Quote
Old 01-29-2014, 08:32 AM   #3588
Colbynobo's Avatar
Trader Rating: 17 (100%+)
Well, then based on what you and Evochick have shared, I'll put the stock rings back in tonight. Now, I just need to figure out whether I stay with the 400 cst oil in the kit or go with something a little thicker.
Colbynobo is offline   Reply With Quote
Old 01-29-2014, 08:49 AM   #3589
cyba888's Avatar
the shop that I ordered the 2014 black series bd7 gave these to me today. was wondering if anyone else got one?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 01-29-2014, 08:54 AM   #3590
grapejuice's Avatar
I'm running 2k in my 2014 diff. And just be sure to use enough grease or whatever on the stock orings to seal them good. I used AE green slime, I put a ring of it in the diff case first, then cover the oring with it before putting it in the case, then once I slide the outdrive in I make sure there is pleanty of grease on top of the oring before putting the spacer on, then once the spacer is on wipe off any access that may have squezed out.
Old 01-29-2014, 08:54 AM   #3591
rosko's Avatar
Wow cant wait for that race
rosko is offline   Reply With Quote
Old 01-29-2014, 10:17 AM   #3592
Colbynobo's Avatar
I have plenty of AE green slime, so this is exactly what I'll do. Thanks! You'll know whether I figured it out based on how much differential fluid you see me dropping at the track. Too bad I missed your Monday testing session.
Old 01-29-2014, 10:20 AM   #3593
Colbynobo's Avatar
My 2014 Black Series BD7 just arrived from RC Market yesterday afternoon. There was no fan, nor was there a floating servo mount. Thankfully, I had already ordered these parts separately from another vendor.
Old 01-29-2014, 10:37 AM   #3594
If you are using the kyosho o rings then it is possible that the out drives are binding because the o ring is a little bigger.
Install the out drive but leave the pin out, the out drive should spin free now.
Install the pin, if this goes difficult then the out drive will not spin freely. It is possible that one out drive binds more then the other, this makes the car feel tweaked.
You have to sand the diff housing where the out drives exit the diff housing.
If you do that the out drives can get more inward which makes more room to install the pin without binding. The out drive should spin as free as possible with the pin installed.
Another solution would be to use a thinner washer which also leaves more room for the pin to be installed.
sitting duck is offline   Reply With Quote
Old 01-29-2014, 01:02 PM   #3595
Well you don't have long to wait, the race is this weekend with practice on Friday
Old 01-29-2014, 01:20 PM   #3596
Colbynobo's Avatar
When I pull out the Kyosho o-rings tonight, I'll check how thick the stock washers are with my digital calipers. I'll give the stock setup a shot, but if it starts to leak then I'll follow your recommendation and get a thinner washer to use the Kyosho o-rings.
I never actually checked the differential action when dry and fresh out of the package to see whether the gears all synced up before I filled it with oil and replaced the o-rings. Oops. Hopefully, I won't need to file down any of the gears or get ahold of a thinner washer just to make it work with the stock o-rings.
Old 01-29-2014, 07:44 PM   #3597
JimmyMac's Avatar
This is why I change out the stock shims (0.3mm) to 0.1mm shims. My out drives spin freely with the Kyosho red orings before I assemble the diff together. So I know the red orings were not binding anything up. Maybe they squeezed the outdrive once assembled with the 0.3mm shims. I dunno, I may rebuild my gear diff just for the hell of it and put back in the kit orings and see how that goes. I've been using Mugen 2000 diff lube.
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
JimmyMac is offline   Reply With Quote
Old 01-30-2014, 08:52 AM   #3598
Colbynobo's Avatar
Thank you for providing the shim thickness. I forgot to measure them last night during the rebuild. I put the stock o-rings back in, but made sure to coat them with some AE Green Slime before closing everything back up.
I made a real hack job of my attempt to shape up a Parma PSE universal bumper. Someone suggested using a hard foam Xray bumper, but a quick look at the bumper on my Xray T3 makes me think that the holes don't line up correctly. Does anyone have any suggestions on a strong, pre-made/fabricated bumper?
Old 01-30-2014, 11:37 AM   #3599
The front end from my 417 (maybe slightly forward or back, don't remember) and my t3 2012 were basically the same as my BD7. When I switched cars and used my old bodies the fronts lined up. only the rear body post position was different with the cars. That is atleast for me.
429racer is offline   Reply With Quote
Old 01-30-2014, 12:47 PM   #3600
swimbikerun's Avatar
Trader Rating: 100 (100%+)
The Tamiya 416-8 bumpers are almost a plug and play solution. They are thinner so you will need to cut the ribs on the body mount to slide the bumper brace on. Awesomatix USA offers a hard bumper option for their car which is a Tamiya 416-8 bumper. Your other option is the hard bumper for the T3 by Xray or RSD. You will need to oversize the body post holes in the bumper slightly and also dremel the edges of the bumper slightly.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
SEO by vBSEO 3.5.0
