Old 01-15-2014, 11:12 AM   #3481
Jorge T's Avatar
Originally Posted by Crashmaster View Post
Guys,
Does anyone know if tamiya shock eyes will kit the yokomo shock pivot balls?
Dan
They will not fit. Tamiya is 4.8 mm, Yokomo is 1mm bigger diameter
RSD Speedway
Jorge T is offline   Reply With Quote
Old 01-15-2014, 05:40 PM   #3482
EDWARD2003's Avatar
Shock rebound on a tight twisty asphalt track, what should it be set at? Or is it more a personal preference? At the moment, my shocks have 0 rebound. Just wondering what the rest of you are running for outdoor asphalt?
EDWARD2003 is offline   Reply With Quote
Old 01-16-2014, 10:36 AM   #3483
Cadman1981's Avatar
Originally Posted by Geberit View Post
The chassis pictures don't match the setup sheet's info.
Anyone put longer links (front or rear) on the diff holders? my ball stud drives into the plastic diff bearing holder. any suggestions?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 01-16-2014, 10:46 AM   #3484
Geberit's Avatar
I asked the same thing few posts back
Either the set-up was filled out wrong or the car on the picture is not the actual car Ronald raced with ... Seen many times Umino didn't allow to photograph the original race care
Geberit is offline   Reply With Quote
Old 01-16-2014, 10:49 AM   #3485
B00t13g's Avatar
Or the car was photographed before that setup adjustment was made.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 01-16-2014, 10:50 AM   #3486
B00t13g's Avatar
Use a shorter ball stud. My rear link is like that, but I'm using the aluminum cam adjusters. Not sure if that makes a difference.
Mackenzie Meyercord
Old 01-16-2014, 12:12 PM   #3487
Geberit's Avatar
Right!
Old 01-16-2014, 01:09 PM   #3488
Crashmaster's Avatar
Thanks for the reply mate
Crashmaster is offline   Reply With Quote
Old 01-16-2014, 01:13 PM   #3489
Cadman1981's Avatar
Are the plastic Cams on the 2014 car different than on the ..2012 BD7?
A friend of mine said that when he tigtens down the shock tower mounts for his new BD7 2014 black ed, his diff and spool bearings don't spin freely anymore. I don't have this issue at all on my BD7. Anyone notice this? i remember reading this a few posts back, but what was the conclusion?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 01-16-2014, 01:26 PM   #3490
Hugh Jazz's Avatar
A friend of mine said that when he installs the shock tower mounts for his new BD7 2014 black ed, his bearings don't spin freely anymore. I don't have this issue at all on my BD7. Anyone notice there? i remember reading this a few posts back, but what was the conclusion?
I had the same problem. I put alloy BD5 ones on the car and it fixed the problem.
In quality the 14 is a step down from the original BD7.
Half my suspension pivot balls didn't fit on the hinge pins. The cams squash the bearings.
I have own every BD5 since the W. Didn't have these problems with the 5s as it came with everything.
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 01-16-2014, 06:14 PM   #3491
evochick's Avatar
my 2104 upgrade kit arrive today along with the new drive shafts
sadly I wont have time to install it for this weekend, but did install the driveshaft's and the updated steering linkages, but im not sure they will do anything since they look the same as the old ones..
New driveshaft's look good though, very tight clips, so they shouldn't come free, and feel very smooth.
Beth.
UnRetired
evochick is offline   Reply With Quote
Old 01-16-2014, 08:07 PM   #3492
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Beth.
Where did you get the new Driveshaft's from Beth? Need to get some for my Dad's car!
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 01-16-2014, 08:32 PM   #3493
Hugh Jazz's Avatar
Don't forget Vince. You are using his paypal account after all
Dan Maher
Old 01-16-2014, 09:54 PM   #3494
evochick's Avatar
Rcmarket. Not sure if they are still in stock ??
UnRetired
Old 01-17-2014, 08:03 AM   #3495
bozzplayer's Avatar
Trader Rating: 16 (100%+)
Quick question guys, To convert to the new bd7 2014 i will need the conversion kit only, or do i also need to get the SLF short shock conversion. Thanks for your help
bozzplayer is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
SEO by vBSEO 3.5.0
