Old 01-14-2014, 07:40 PM   #3466
Trader Rating: 17 (100%+)
If you have the problem at low speed, I would check your car to make sure the arms drop freely and the shocks are not binding up and sticking. Everything should move freely. Also do not know how your roll centers are, so a setup sheet of your setup would help more. Make sure the arms move freely with no force applied. Also on the setup you have posted so far the only thing I would says is a little thicker rear diff oil, but I bet you have something not right. Also that body has lots of steering.
429racer is offline   Reply With Quote
Old 01-14-2014, 07:59 PM   #3467
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by pullstarter View Post
Thanks guys, I'm hoping the HPI springs will help. I'm using a Proto P-37R regular weight body.
change shell to Speed6 that may help 37r does handle strange
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 01-14-2014, 08:32 PM   #3468
pullstarter's Avatar
Trader Rating: 14 (100%+)
Everything is free and moving easily, no binding anywhere at all. Will try a different shell and see how it goes.
pullstarter is offline   Reply With Quote
Old 01-14-2014, 08:48 PM   #3469
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Hey Guys,
Having some serious issues finding rear grip with my BD7 '13. We're running control tyres, Muchmore Rush 36s, so going to a softer rear isn't possible. High speed cornering is okay (not brilliant) but accelerating out of corners is resulting in some severe back end slides, even using very little power. Off power slides are also common.
Cheers
Simon
Kit/Box setup with Hpi Silvers should be super easy to drive
Oils, shims, CG, RC, WB, everything
50% reb is too firm
20% is what you are looking for
The BD7 is very sensitive to changes
It's possible you have something tuned too aggressive in your setup
And that body isn't doing you any favours, get a LW Speed 6, or LTCR if you need more rotation
I always go back to kit setup if something doesn't feel right, it's lazy, but works great on asphault
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-14-2014, 08:54 PM   #3470
Thanks guys I'll give all these things a go, much appreciated .
Old 01-15-2014, 02:22 AM   #3471
Hugh Jazz's Avatar
Also try a harder oil in the diff.
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 01-15-2014, 04:03 AM   #3472
Crashmaster's Avatar
Originally Posted by Crashmaster View Post
Hey guys,
I've got hold of a BD7RS to use as a wet car and have to say all is good so far apart from the shocks, to be exact the collar adjusters. As they are plastic on plastic they are binding badly to the point where I can't move them without pliers.
So far I've tried putting some shock oil and grease on the threads though it hasn't really helped. Just wondering if anyone else has experienced this/ got any suggestions on how to help out.
Cheers
Dan
Just on this guys does anone know if the thread on the composite shock body is the same as the aliminium ones? I guess if they are the ai shock collars could be a solution
Cheers
Dan
Crashmaster is offline   Reply With Quote
Old 01-15-2014, 04:29 AM   #3473
I've actually got a ball diff in the spares box, I might give a try.
Old 01-15-2014, 06:44 AM   #3474
Geberit's Avatar
DHI set-up is up: http://www.petitrc.com/reglages/yoko...nse2014011112/
Geberit is offline   Reply With Quote
Old 01-15-2014, 08:15 AM   #3475
Geberit's Avatar
Any comments on Volker's setup from guy's who have experience with the previous version?
Old 01-15-2014, 08:28 AM   #3476
Aside from front WB, and shock position
Nearly kit settings, and very close to what I used on Med grip carpet
Old 01-15-2014, 09:51 AM   #3477
Guys,
Does anyone know if tamiya shock eyes will kit the yokomo shock pivot balls?
Dan
Old 01-15-2014, 09:51 AM   #3478
Geberit's Avatar
How would you comment the Rear long camber link?
Old 01-15-2014, 09:59 AM   #3479
Cool
Never tried that
Mine are like this
Old 01-15-2014, 10:08 AM   #3480
Geberit's Avatar
Never tried that
Mine are like this
I see so what was he driving like in the picture (outer hole) or set-up (inner hole)
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
