Like Tree5Likes
Old 01-13-2014, 08:32 PM   #3451
Yup was using a pan car type spur . using a XRAY spur now wors great . Thanks for the help.
dan22 is offline   Reply With Quote
Old 01-14-2014, 04:29 AM   #3452
Texco's Avatar
Hey all,
Has anyone used these belts on the BD, Team Bomber Low Friction Belt (Rear) TB-20023?
Are these belts good or should I stay away?
Texco is offline   Reply With Quote
Old 01-14-2014, 05:19 AM   #3453
Does the floating servo mount come in with the 2014 black series kit ?
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 01-14-2014, 05:45 AM   #3454
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Texco View Post
Hey all,
Absolutely garbage, like they are made of cotton fluff and stuck on with a gluestick.
defcone is offline   Reply With Quote
Old 01-14-2014, 07:44 AM   #3455
mikeygar's Avatar
Trader Rating: 14 (100%+)
Anybody have Ronald's setup sheet from DHI at Odense? The petitrc one is a dead link...
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 01-14-2014, 09:28 AM   #3456
Originally Posted by RedBullFiXX View Post
Body forward, more steering
Weight forward, easier to drive normally
My Black edition did not come with the floating servo mount .
Old 01-14-2014, 09:36 AM   #3457
Geberit's Avatar
I't never in the kit! Only if the seller add's it as an offer like Tonisport where I'v got my car from. The floating servo mount came separate ...
Geberit is offline   Reply With Quote
Old 01-14-2014, 01:08 PM   #3458
Crashmaster's Avatar
Default BD7RS Shock
Hey guys,
I've got hold of a BD7RS to use as a wet car and have to say all is good so far apart from the shocks, to be exact the collar adjusters. As they are plastic on plastic they are binding badly to the point where I can't move them without pliers.
So far I've tried putting some shock oil and grease on the threads though it hasn't really helped. Just wondering if anyone else has experienced this/ got any suggestions on how to help out.
Cheers
Dan
Crashmaster is offline   Reply With Quote
Old 01-14-2014, 03:14 PM   #3459
pullstarter's Avatar
Hey Guys,
Having some serious issues finding rear grip with my BD7 '13. We're running control tyres, Muchmore Rush 36s, so going to a softer rear isn't possible. High speed cornering is okay (not brilliant) but accelerating out of corners is resulting in some severe back end slides, even using very little power. Off power slides are also common.
My current setup is:
Xray 350 shock oil, 50% rebound
Yokomo pink springs on front (have the full set of HPI springs on order)
Yokomo blue springs on rear
ride height - 5mm all round (also tried running 7mm front and 5mm rear made no difference)
2 degres rear camber
1 degree front camber
1000 wt diff oil rear
front spool
0 degree toe front
kit standard rear toe
2-3mm droop
It's pretty much the standard asphalt setup that's reccomended with the kit with a few minor tweaks. Any help would be much appreciated, I really dont know where to go form here?
Cheers
Simon
pullstarter is offline   Reply With Quote
Old 01-14-2014, 03:24 PM   #3460
Originally Posted by pullstarter View Post
Hey Guys,
front spool
0 degree toe front
2-3mm droop
Cheers
Simon
when you say 2-3mm drop, what do you mean? is that 2mm over ride height. i would start by adding more front drop to allow more weight to transfer to the rear on power
DOTMAN is offline   Reply With Quote
Old 01-14-2014, 03:27 PM   #3461
Shock oil sounds a bit light, the car seems to like heavier oil (the worlds setup sheet says 600cst without tyre additive!)
I wouldn't expect the kit springs to work in low grip so it's good that you're getting the HPI set, most run silver/silver, pink/silver worked well for me last year.
You don't say which shell you're using, I couldn't get the ltc-r to work at all, went much better with Speed6. I know most people run the ltc-r outdoors, maybe I got a bad one, but I had no forwards traction with it at all.
cyclonetog is offline   Reply With Quote
Old 01-14-2014, 03:30 PM   #3462
Hey Guys,
front spool
0 degree toe front
2-3mm droop
Cheers
Simon
Also, do you sauce and heat your tires?
Old 01-14-2014, 03:34 PM   #3463
Thanks guys, I'm hoping the HPI springs will help. I'm using a Proto P-37R regular weight body.
Old 01-14-2014, 03:39 PM   #3464
That's probably 95% of your problem...
Old 01-14-2014, 03:55 PM   #3465
Even at low speed cornering?
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Gayosaka
