Like Tree5Likes
Old 12-18-2013, 03:42 PM   #3256
Luppi Stefano's Avatar
new short shocks is very interesting
hope it come out without shock towers
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 12-18-2013, 03:50 PM   #3257
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Purchase as a kit, or all separate
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-18-2013, 08:10 PM   #3258
Cadman1981's Avatar
What about the new 2014 standard length shock bodies? Any one have info on those? Worth getting if i have the 2013 version?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 12-21-2013, 11:11 AM   #3259
Cadman1981's Avatar
Originally Posted by Racing4Evo View Post
Testing the new shocks....much improved feel and action.
How are you getting these parts??
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 12-21-2013, 10:49 PM   #3260
Bill K's Avatar
Hey guys,
I've encountered a small problem whilst transitioning from running stock to modified, and the main issue I have been experiencing on our medium/low grip ashphalt surface track is the lack of rear grip. After altering parts my setup to try and eliminate this problem with no sucess, I have come to the conclusion that it's the oil in my rear diff causing this problem(??)
Currently running the standard 750wt Yokomo oil that comes with the kit, and wondering if this does happen to contribute towards my problem, which it may or maynot, is this too light? Running this with 4.5t high torque motor (x11 octa) with no boost and mild turbo, and about -35% expo on the radio to try and control this problem.
So, for modified, I've seen setups with oils 1-5k variants in the rear differential on various med/low grip ashphalt track. For something relatively small, with somewhat small amounts of grip most of the time, what oils would you suggest?
This is reall appreciated guys, so thankyou for spending the time to read this.
Bill.
Billy Karnaros
Yokomo BD7 2016
Powered by Muchmore
Futaba 4PX
Bill K is offline   Reply With Quote
Old 12-21-2013, 11:01 PM   #3261
haura415's Avatar
Originally Posted by Bill K View Post
Hey guys,
Bill.
I use nothing under 2000cst . Thick oil made rear more stable
haura415 is offline   Reply With Quote
Old 12-21-2013, 11:09 PM   #3262
Bill K's Avatar
Thankyou for the quick relpy, I'll throw some 2000cst in the rear and see how it goes, if this problem continues I'll try go thicker again, after I've played with the setup to see how different it behaves.
Cheers,
Bill.
Billy Karnaros
Yokomo BD7 2016
Powered by Muchmore
Futaba 4PX
Old 12-22-2013, 10:59 AM   #3263
Cadman1981's Avatar
You can also try to reduce droop on the rear, and stiffer springs in the front
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 12-22-2013, 08:11 PM   #3264
JimmyMac's Avatar
I've been trying some of Volker's setups, but I guess my driving style is a little different. Here is an easy to run front diff setup for those who want to try. Yes, I'm running anti-dive. 0.5mm shim. I've been running 0.8mm shim before and liked it. I wanted to try a little less for more mid/exit so I went with 0.5mm. I feel it is good on technical tracks with plenty of turn-in. Easy to drive. This setup also runs with Gravity LGC tire treatment. I feel this tightens the car up. Not sure if I like it as much as the SXT 3.0 that I used to run. I'll have to switch back and see how it does with a different set of tires (don't wanna use same tires treated with LGC).
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 12-23-2013, 09:21 PM   #3265
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Looks good. That's a good neutral setup!
so what happened to the +2.5mm or so under the inner rear camber link that you were running before? how did you end up solving the rear end swinging around?
Racing4Evo is offline   Reply With Quote
Old 12-23-2013, 09:21 PM   #3266
Racing4Evo's Avatar
Old 12-23-2013, 09:39 PM   #3267
JimmyMac's Avatar
Being out of racing for 2 years I forgot a few things, but I ended up adding -30 steering expo (curve) to dial out the twitchyness of the steering during initial throw. Switching to premounts with a thinner insert also helped out. The car wasn't floating on the tires anymore. There may have been a few other factors, but I think steering curve on the radio helped out the most. Especially with a high speed servo. Simple and easy, something I should of picked up on early but forgot about. If the rear end still continues to be a problem, raising the rear inner link does actually still help out as well as lengthening it which I have done to "tame" it down a hair.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 12-23-2013, 09:57 PM   #3268
Racing4Evo's Avatar
You should try using a short servo horn in place of the negative expo.
We use the one from Tamiya but any horn of similar length can be used. This tames the steering on carpet in especially in stock classes where you're not pushing the limit of the tires.
When we go outdoors, we will use the long direct horn for quicker off center response.
Old 12-23-2013, 10:11 PM   #3269
JimmyMac's Avatar
Awesome. I just switched to the XRay saver (from direct), I may give the shorter hole a try.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 12-24-2013, 04:52 AM   #3270
If anyone interested with good BD7 RS setup for carpet (med-high) traction I attached file from Mibo #2, car make 3rd position overall.
orzel24 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
