Old 12-17-2013, 03:02 PM   #3241
CristianTabush's Avatar
Here's a pdf I uploaded on our site. It's for the HPI Flux, but it works...
https://reflexracing.3dcartstores.co...ushV31_55T.pdf
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 12-17-2013, 07:04 PM   #3242
evochick's Avatar
if only I had a translator
here are all the new part numbers,
http://www.teamyokomo.com/news/order...d714_parts.pdf
Beth.
UnRetired
evochick is online now   Reply With Quote
Old 12-17-2013, 07:33 PM   #3243
JimmyMac's Avatar
Beth.
Nice! I'll take the short shock set please!
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 12-17-2013, 07:34 PM   #3244
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Beth.
Nice to see all option parts available in Black
http://translate.google.com/#ja/en/
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-17-2013, 07:37 PM   #3245
JimmyMac's Avatar
No... it's not nice... because I'll want one even more!!!
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 12-17-2013, 07:42 PM   #3246
evochick's Avatar
yeah I know, for some reason my PC doesn't copy the Japanese characters out of adobe ?
interesting the haven't given us the update c-hub part yet, but the short shock kit does look interesting
UnRetired
Old 12-17-2013, 07:50 PM   #3247
I use Chrome to read/copy data from pdf
BD7-2014 用 新規パーツ注文書 A ( ブルー&共通パーツ )
BD7-2014 for new parts order form A (Blue and common parts)
BD7-2014 用 新規パーツ注文書 B ( ブルー&共通パーツ )
BD7-2014 for new parts order form B (blue and common parts)
BD7-2014 用 新規パーツ注文書 C ( ブラック用パーツ )
BD7-2014 for new parts order form C (black parts)
BD7-2014 用 新規パーツ注文書 D ( ブラック用パーツ )
BD7-2014 for new parts order form D (black parts)
BD7-2014 用 新規パーツ注文書 E ( ブラック用パーツ )
BD7-2014 for new parts order form E (black parts)
BD7-2014 用 新規パーツ注文書 F ( ショートショック用パーツ )
BD7-2014 for new parts order form F (short shock for parts)
BD7 シリーズをショー
トショック仕様にするコ
ンバージョンキットで
す。従来よりも 4.0mm
短いショック長とするこ
とで、重心を下げ、主に
ハイグリップ路面での運
動性能向上、ハイサイド
防止に効果があります。
ただシリンダーを短くす
るだけではなく、ショー
ト化の効果を違和感なく
高めるために、ピストン
位置の最適化や、従来と
同じスプリングを使用す
るための新規スプリングカップなど、ノーマルから変更してもドライビングに支障を与え
ない設計となっています。もちろんシリンダーは潤滑ハードアルマイト仕様とし、最高の
ショック吸収性を誇ります。
The series show the BD7
Co to ​​bets shock specification
In emission version kit
Be. The 4.0mm than the conventional
Short child and shock length
In, and to lower the center of gravity, mainly
Luck of the high grip road surface
Dynamic performance improvement, the high-side
Is recommended to avoid.
Just be as short cylinders
Not only Ru, and show
The seamlessly the effect of bets
In order to increase, the piston
And optimization of the position, the conventional
To use the same spring
I give trouble to driving such as a new spring cup of Rutame, if you change from the normal
And it is with no design. And lubrication hard anodized specification cylinder of course, the best
I am proud of the shock absorption.
Old 12-17-2013, 08:18 PM   #3248
hanzo3's Avatar
Trader Rating: 55 (100%+)
Converting to black sounds pricey. Looks good though.
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 12-17-2013, 08:30 PM   #3249
Trader Rating: 1 (67%+)
Send a message via AIM to racer034life
If some one wanted to by a all black bd7 where should i go?
Sold All my R/c car stuff to by a zx-14, Access Hobbies, CRC, ARC,
racer034life is offline   Reply With Quote
Old 12-17-2013, 08:33 PM   #3250
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Talking
Testing the new shocks....much improved feel and action.
Racing4Evo is offline   Reply With Quote
Old 12-17-2013, 11:16 PM   #3251
Originally Posted by CristianTabush View Post
This is the set up I used to TQ Every round in stock TC and Mod TC at the Region 9 carpet champs. I took an easy win in stock lapping up to second place (came within less than a second in each main of lapping 2nd place) winning the first 2 mains and finished 2nd in mod after dominating qualifying and getting worked a little A1 and A3 by traffic and the eventual winner. My car was by far the best car out on the track. I am very happy with this set-up variation. Tons of steering, stability and just the perfect amount of roll.
Hi Christian
you might want to correct your setup sheet.
I am pretty sure you don't run 44,2mm shims under the Front Bulkhead
Also in the Back, 0.05mm is a pretty small shim
Are you really running the Diff in High position at the Back ?
Also it would be interresting how you run the steering - Bridge installed ? Connected to Top Deck ?
Sorex Tires - Sidewalls clued ?
FrankH is offline   Reply With Quote
Old 12-17-2013, 11:57 PM   #3252
I have sent Arnaud at Petit a corrected version of the set up sheet.
No superglue on the sidewall, except to re glue the tire. By the last 2 mod mains grip was starting to be a bit higher than normal, so I put a slight amount of glue on the front sidewall to decrease a little tire flex, but not so much to take away bite.
Yes, I like running the diff high in the rear. It allows the car to noticeably have more roll in the rear to the point where I feel the car was smoother in the middle of the corner. My car has a tendency to get a little too much rotation at times in the middle of the corner on used tires. Older tires are faster at our track right now. New tires just make the car push. Lap times are not much different, but the car is easier to drive and more consistent with the high diff.
Old 12-18-2013, 06:21 AM   #3253
Jorge T's Avatar
So, does the new kit come with the short shocks or is this an add on?
RSD Speedway
Jorge T is offline   Reply With Quote
Old 12-18-2013, 06:43 AM   #3254
Cadman1981's Avatar
I thought the shocks were the same, and the short shocks didn't work well with the chassis?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 12-18-2013, 08:02 AM   #3255
Tuning Option Parts, not included with kit
4mm shorter, uses standard springs
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
