Old 11-25-2013, 08:37 PM   #3121
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by JimmyMac View Post
The exploded view in the RS manual says they are Black YS-1465L springs all around.
Black BD7 spring YS-1460L
Optimal professional shock spring as Touring Car. And it is with 6.0 turns in 1.4mm diameter wire.
Black BD7 RS spring YS-1465L, softer than Black 1460L
Pro Shock spring of BD7 ver.RS for touring car. And it is with 6.5 turns in 1.4mm diameter wire.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-25-2013, 08:43 PM   #3122
Trader Rating: 17 (100%+)
Originally Posted by RedBullFiXX View Post
SJ- Single joint
WJ- Double joint
RS Kit springs look unique to that kit
Not standard BD7 White springs with Pink/Blue marking
Mac:
I also found this to be true with the 6deg chub, more exit steering, not so much on entry or mid
Man that Black Special kit wow
If you already have a Blue kit....
It's like the Hot chick flirting with a married dude
Thanks! I have been going back and forth about the BD7 or the RS. I have a nice 417 that I am looking to replace it with and deciding do I or Don't I.
429racer is offline   Reply With Quote
Old 11-25-2013, 10:49 PM   #3123
evochick's Avatar
Thanks for everyone's suggestions
I have filled out my setup sheet with what I have changed the car to, try next week, just waiting on a new R1 fan to arrive
Fingers crossed those small things help.
Beth.
UnRetired
evochick is offline   Reply With Quote
Old 11-25-2013, 11:12 PM   #3124
EDWARD2003's Avatar
Default Droop.
Evochick - Have a look at your droop settings. Usually that's the first place I start, you'd be surprised at how powerful an adjustment it is.
EDWARD2003 is offline   Reply With Quote
Old 11-25-2013, 11:36 PM   #3125
Beth.
looking at your setup
For entry/mid understeer
1K rear diff
Front gear diff w 2.5m, fine tune, some like it, some don't
Lighter damper lube Fr & Rr
More ackerman
Racing4evo also has a killer 13.5 asphalt setup, his car was supa dialed outdoors
Old 11-26-2013, 01:41 AM   #3126
CraigM's Avatar
But it's not black...
The photo car was missing some parts that were not ready. Floating mount was one, and if you look closely you'll see the steering bridge and spool were champfered by hand
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 11-26-2013, 04:00 AM   #3127
BD7 RS kit springs are awful by the way lol
way too soft
PurcyP is offline   Reply With Quote
Old 11-26-2013, 06:47 AM   #3128
Helo guys i have just received my BD7 and planning to put spec r dcj on it. Ive been wandering whether i need to chamfer the edges on my c hubs to fit those?
One more question, does anyone have problems with servo mount? It seems that some might have been facing moving servo mounts when running the car. Is this a serious issue? How do i fix these problems?
Sorry for the repeating questions, but through my search in the forum i cant seem to understand the explanation given.
Noobi_Kenubi is offline   Reply With Quote
Old 11-26-2013, 08:55 AM   #3129
gom
spec R dcj will fit in the BD7 without modification to the c hubs. you might need to shim a little bit between the pin and the ball bearing. but that's it.
Yokomo BD5 - Yokomo BD7 - Futaba - Hobbywing - Reedy - Savox
gom is offline   Reply With Quote
Old 11-26-2013, 07:56 PM   #3130
JimmyMac's Avatar
I run the Spec R V2 swing shafts and have no clearance issues with the chubs. You just need a .2mm shim to put on the axle between the bearing and wheel hub pin. As for your servo mount question, I do not understand what you are saying but there are no issues with the servo mount.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is online now   Reply With Quote
Old 11-26-2013, 09:19 PM   #3131
I see thanks for the advice. With regards to the servo mount, i ve read somewhere here saying that the mount requires some additional spacer to prevent it from moving too much. They said sometimes the mount bend a little(flex) during corners and did not return to its original position during corner exit and the car failed to go straight.
Old 11-26-2013, 09:20 PM   #3132
Noted with thanks.
Old 11-26-2013, 10:09 PM   #3133
JimmyMac's Avatar
You mean this?
http://www.petitrc.com/reglages/yoko...Reinforcement/
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 11-27-2013, 11:04 AM   #3134
Yeah thats it, anyone used the same method to strenghten their servo mounts? Or should i leave it as it is?
Just wondering whether it is a "must do" or just "optional".
Old 11-27-2013, 11:12 AM   #3135
AOD
AOD's Avatar
I did it on mine. It keeps the servo from tweaking in a hard crash and can be done with parts most people already have in their spare parts.
AOD is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
