Like Tree6Likes
Old 11-24-2013, 08:36 PM   #3106
evochick's Avatar
no I don't have them, I only have the 3 and 2.5,
Initially on club nights the car was happy with the 3, but I switched to 2.5 for the day meets which helped a little, but all the things I tried only ever seemed to take away from rear grip out of the corner and didn't really fix the entry/mid understeer issue. Which makes my think I have missed something
UnRetired
evochick is offline   Reply With Quote
Old 11-24-2013, 08:41 PM   #3107
JimmyMac's Avatar
I'm not talking about the toe blocks... what do they call them in Austrailia... uhh 2 degree chubs? Have you tried these...
http://www.rc-mushroom.com/product_i...caster-p-26942
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 11-24-2013, 08:43 PM   #3108
BardSmith's Avatar
Trader Rating: 61 (98%+)
This may have been asked already but what is the difference betweem the current BD-7 and the new BDD-7 2014 that is that is soon to come out.......
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 11-24-2013, 08:47 PM   #3109
JimmyMac's Avatar
How about this setup. Also you can try the body he is running as well. Should offer a lot of steering for asphalt.
Forgot to post setup.. http://www.petitrc.com/reglages/yoko...ei20130804.pdf
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-24-2013, 08:48 PM   #3110
JimmyMac's Avatar
Start reading near the middle/end of page 204.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-24-2013, 10:01 PM   #3111
evochick's Avatar
ooops sorry wasn't thinking, might be an option, and yep running an ltcr already
UnRetired
Old 11-25-2013, 01:41 AM   #3112
haura415's Avatar
Hi Everyone I need some help,
my BD7 is suffering from serious initial understeer, that I cant seem to dial out,
I am running very close to this setup (except 1.5 camber on front), but I am missing something ???
http://www.petitrc.com/reglages/yoko...i_SMA20121014/
The car was very good with 32 compound tyres that I was using on club nights with a much cooler track when I first ran the car, the downside with these tyres is that they only last 5 runs. On the weekend just past it was very hot and very high grip. So I switches to 36 and tried both ride and muchmores, but with both it just wouldn't turn in.
I just removed the steering bridge to see if that might help with some more flex, and it seems no one is running one anyway, is it worth while removing the top motor mount screw as well ? any downsides to doing this ?
anything else I can try ? help ... I am hopeless at trying to setup cars
Thanks.
Beth.
Shorten your front wheel base
Take out the 2mm. Center links put 0.5
haura415 is offline   Reply With Quote
Old 11-25-2013, 05:06 AM   #3113
Aaron_M's Avatar
Thanks.
Beth.
The steering bridge makes a huge difference to front flex and initial steering. Remove it completely for more "bite".
I wouldn't remove the screw above the motor mount. From your setup sheet less shims on front bulkhead will increase steering and also the thinner top deck will give more steering.
Yokomo BD7
Aaron_M is offline   Reply With Quote
Old 11-25-2013, 07:07 AM   #3114
Cadman1981's Avatar
Originally Posted by CraigM View Post
New top and bottom decks too and the flex point has been moved further forward - the devil is in the details. The new motor mount is a huge improvement on the tweak prone current design and the mounting holes are symmetrical and more centrally aligned. I actually think it would be impossible to tweak the new motor mount
Oh and the black version is the best looking car I've ever seen
You know what, i noticed this weekend that my chassis is slightly tweaked, especially when i put the battery. For the last races, i had to push the car down with a bar and tighten the top plate after the battery was strapped in.
Any ETA for the release dates of the 2014 kit or upgrade kit??
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 11-25-2013, 08:48 AM   #3115
Ran my BD7 RS yesterday at the CWIC
the amount of grip and steering it will give you on a good setup with yokomo pink spring front blue rears is unholy, its a shame i cant drive it hard enough to reap its rewards but hopefully next time round i can push it harder because its just such a smooth, quiet and fantastic handling car, but out of the box the RS will need roll bars, springs, full option bd 7 drive train etc but the bulk heads n susp blocks are fine.
PurcyP is offline   Reply With Quote
Old 11-25-2013, 04:43 PM   #3116
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
if you lack of mid steering, your should try 6 deg c-hub. it's might help your problem.
Give the best while u can !
kschu is offline   Reply With Quote
Old 11-25-2013, 06:19 PM   #3117
Trader Rating: 17 (100%+)
On the setup Sheets it says SJ and WJ for the drive shafts, what is that?
I thought the BD7 RS came with Pink and Blue Springs?
429racer is offline   Reply With Quote
Old 11-25-2013, 07:03 PM   #3118
JimmyMac's Avatar
I think the 6 degree hubs will make her initial under-steer even worse that what it is. I tested 6 degree on carpet and I lost my initial and had too much exit steering. I went back to 4 degree and it was good. Next I would like to try 2 degree. This past weekend I ran 4 degree with anti-dive (.8mm) and the car was great. A lot of changes this past weekend!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-25-2013, 07:24 PM   #3119
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
SJ- Single joint
WJ- Double joint
RS Kit springs look unique to that kit
Not standard BD7 White springs with Pink/Blue marking
Mac:
I also found this to be true with the 6deg chub, more exit steering, not so much on entry or mid
Man that Black Special kit wow
If you already have a Blue kit....
It's like the Hot chick flirting with a married dude
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-25-2013, 07:29 PM   #3120
JimmyMac's Avatar
The exploded view in the RS manual says they are Black YS-1465L springs all around.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
