Like Tree6Likes
Old 11-18-2013, 05:11 PM   #3046
joms's Avatar
Thank you racers.. For the advice and recommendation.. It apppears it's better for me to get the proper BD7 kit.. And yes Beth I'm from Sydney, and will be racing at werc once my TC is ready..
Thanks guy's & gals.
joms is offline   Reply With Quote
Old 11-18-2013, 07:06 PM   #3047
Cadman1981's Avatar
Originally Posted by gom View Post
the bd7 is very picky on spur gear. so far only the Panaracer brand fits because it's the official brand. there might be other brands but i haven't figure out yet.
the car comes with a 116 tooth 64 pitch gear which is too big for 21.5 motor. you'll need to buy a 92-96 tooth spur. preferably a 92 tooth if you can find it. 96 is more popular though and most hobby shop carries it.
your FDR will probably range from 3.4 to 3.8. so just get the appropriate pinion gears.
for spare parts, just get the arms, c-hubs, steering knuckles and bottom king pin screws. it's a somewhat durable car despite popular believes. nothing else should break in a small to medium crash.
I have been running kimbrough, Serpent, xray and even the panaracer spur gears. You just need the flat philips screws from tamiya - part 51211, and then all spurs fit with no issues.
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 11-19-2013, 03:03 AM   #3048
evochick's Avatar
the other trick is to use flat head screws
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 11-19-2013, 04:33 AM   #3049
I have started using RW spur gears however i countersunk the holes on em and used small counter sunk screws to achieve a perfect fit.
PurcyP is offline   Reply With Quote
Old 11-19-2013, 12:52 PM   #3050
joms's Avatar
Ok.. So i will get 92 tooth spur gear as preferred,... How many tooth should my motor gear be to get aFDR of 3.4 ? Thanks in advance.
Old 11-19-2013, 04:04 PM   #3051
cyclonetog is offline   Reply With Quote
Old 11-19-2013, 10:07 PM   #3052
cyba888's Avatar
are these the 4.5mm hubs? if not who sells them thank you
http://cgi.ebay.com/ws/eBayISAPI.dll...:X:AAQ:US:1123
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 11-19-2013, 10:31 PM   #3053
joms's Avatar
Originally Posted by cyclonetog View Post
54
thank mate.
Old 11-19-2013, 11:49 PM   #3054
JimmyMac's Avatar
Those are the 4mm hubs with 0.5mm and 1mm wheel shims.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 11-20-2013, 02:51 AM   #3055
cyba888's Avatar
Thank you
Futaba 4PX
Old 11-20-2013, 08:44 AM   #3056
gom
thanks for the tips.
Yokomo BD5 - Yokomo BD7 - Futaba - Hobbywing - Reedy - Savox
gom is offline   Reply With Quote
Old 11-20-2013, 06:09 PM   #3057
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
bd7 2014 come out....should be hitting the store end of december !
Give the best while u can !
kschu is offline   Reply With Quote
Old 11-20-2013, 06:12 PM   #3058
Cadman1981's Avatar
Not much about the BD7 2014
http://www.teamyokomo.eu/yokomo-euro...ember-in-stock
Full specifications
[Feature of BD7 2014]
1) Capable to use large sized Pinion Gear for adapting high geared driving
2) Renewed Motor mount position in the middle of main chassis
3) Hard Anodized Aluminum shock cylinder (i can't tell, but the shocks look different)
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 11-20-2013, 06:32 PM   #3059
Cadman1981's Avatar
The black series
or the blue
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 11-20-2013, 06:33 PM   #3060
evochick's Avatar
ok so we have a new motor mount and new shock bodies,
will glad i didnt wait,
From google translate
BD7-2014 to benefiting from home-European touring car, achieve a normal evolution of true. Japan, as well as to prove their ability in a race around the world, while rivals take each year lag, it ticks away brilliant step to the next stage one step ahead again.
Place in the center of the chassis motor mount, redesigned the shape of the steering bell crank, while increasing the driving feel, 2014 has achieved a balance of grip and cornering speed. Also, I give a hard anodized lubrication of high quality to shock cylinder, significantly reduces the resistance of the internal shock, gap of road surface slightly absorbed supple, increases operability significantly. In addition to the standard kit of blue anodized, black series with a brightness such as the black diamond a certain dignity as (limited model) special edition this time comes!
BD7's running looks even reached the realm of art at last!
Not chased the times, real specs to make pressed for time will be proven in your driving.
Main Specifications
● The Beruejji all black anodized and realization (BLACK SERIES) looks more luxury 漂
● Promoting the low center of gravity and optimization of chassis rigidity in the new design motor mount
● Spread the gear ratio setting width, Compatible with various regulation
● The redesigned steering bell crank, and can cope with changes in suspension alignment
● shock cylinder was subjected to hard anodized lubrication reduces the resistance of the internal shock
■ competition 4WD belt drive touring car
■ Optimize the twist of the chassis parts in the configuration of symmetrical
■ Separate aluminum suspension mount (front rear front-rear)
■ Front aluminum solid axle
■ Rear differential gear
■ lightweight plastic belt tension cam
■ stabilizer standard equipment before and after
■ large capacity aluminum oil shock
Unretired
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
