Like Tree6Likes
Old 11-08-2013, 11:00 AM   #3001
CristianTabush's Avatar
Sorry, 3 hole pistons.
I will get that revised.
I was trying to compress the pdf to attach it, I will turn up the resolution and decrease the file size
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 11-09-2013, 04:21 AM   #3002
Default Bell Crank
Is anyone running the Bell Crank in their car?
Chris (Yokomo - Reedy - Sanwa)
TFTR - Templestowe Flat Track Racers - www.tftr.org.au
_________________________________________________
Ignition75 is offline   Reply With Quote
Old 11-09-2013, 11:41 AM   #3003
pullstarter's Avatar
Trader Rating: 14 (100%+)
Is anyone getting leaky shocks? Mine seem to be seeping a bit from the top cap.
pullstarter is offline   Reply With Quote
Old 11-09-2013, 12:34 PM   #3004
No, but which bladders are you using? The kit ones are quite well known for expanding after a short period of time. The black ones last forever, well, almost.
cyclonetog is offline   Reply With Quote
Old 11-09-2013, 02:40 PM   #3005
evochick's Avatar
yeah black bladders for the win, the other thing to make sure is that when you tighten down the cap retainer you are not turning the shock cap as well,
Speaking of issues i installed Tamiya front ecs drive shafts, as i prefer the clip type to hold the pin in, and they were a pain to get right without the hex clamp binding down on the bearing when you tighten up the wheel nut. I had to modify slightly a set of 3racing clamps to get them to sit at the right spacing so they sit on the pin and not the bearing. A pain but worthwhile.
Beth.
UnRetired
evochick is offline   Reply With Quote
Old 11-09-2013, 03:03 PM   #3006
Beth.
Cheers I'll try the black ones!
Old 11-10-2013, 11:10 AM   #3007
Hi people, did you test the short shock towers of roche rc with the news short shocks of the same Brand?
I want to try it, but I don't know what to do.
P.d: I run in pro stock class (same as ets
alejandrospeed is offline   Reply With Quote
Old 11-10-2013, 11:34 AM   #3008
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Beth.
Its best to just convert the hexs to Tamiya. Their hex design is a lot better.
Racing4Evo is offline   Reply With Quote
Old 11-10-2013, 12:21 PM   #3009
Arn0 at PetitRC was kind enough to host a set up sheet for us:
I received a question about the outside front camber link. I did not run any shims underneath the ball, but I failed to mention that I switched the ball to an Associated silver ball with 10mm thread. This ball is essentially 1mm higher than the yokomo ball, so it is roughly equivalent to the Yoke +1. The big advantage is in the longer threads, they go deeper inside the steering block and will not strip as easier. The ball ends really increase the durability of your steering blocks.
Old 11-10-2013, 12:46 PM   #3010
Aaron_M's Avatar
I received a question about the outside front camber link. I did not run any shims underneath the ball, but I failed to mention that I switched the ball to an Associated silver ball with 10mm thread. This ball is essentially 1mm higher than the yokomo ball, so it is roughly equivalent to the Yoke +1. The big advantage is in the longer threads, they go deeper inside the steering block and will not strip as easier. The ball ends really increase the durability of your steering blocks.[/QUOTE]
Just wondering, the ball on the bulkhead... is that the standard silver Yokomo or a shorter neck?
There is a fair amount of shimming on the bulkhead for the standard silver Yokomo?
Yokomo BD7
Aaron_M is offline   Reply With Quote
Old 11-10-2013, 02:56 PM   #3011
RC MARKET's Avatar
TDX Rear Suspension Mount 2.25 & 2.75 Deg
RC MARKET is offline   Reply With Quote
Old 11-10-2013, 03:58 PM   #3012
There is a fair amount of shimming on the bulkhead for the standard silver Yokomo?[/QUOTE]
Standard silver ball end. It allows the car to roll more at the front making it softer. It makes the car easier to drive.
Old 11-10-2013, 08:48 PM   #3013
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Smile
www.chubbiescarshack.co.uk has them coming in stock as well plus the rear belt as well
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 11-12-2013, 08:14 AM   #3014
Hey guys,
i have a bit blasphemous question for you. Does anybody know if some other cars spool fit BD7? I would like to race next weekend and yokomo europe is out of stock.
Marten is offline   Reply With Quote
Old 11-12-2013, 01:00 PM   #3015
evochick's Avatar
An associated Tc6 spool will fit. But you will have to put the white blades on the end of the drive shaft
UnRetired
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
