YOKOMO Touring Car BD-7
#2986
Try Hara Black springs. My favorite for asphalt.
#2988
Good to know. I have built the shocks with AE 500cst. I will try it with pink all round. Has anyone tried running with 2 deg toe at the back?
#2989
I know that there is a special drift toe block that will giv e you 2 deg. Search the posts by "KSCHU"? He's the one that first mentuoned it. I would use it but I don't feel like special ordering it from Japan.
#2990
I will try the blue all round. I will also do the basic setup for asphalt
#2991
Hi.
I plan to buy a new car in the next week's.
Is it a good idea to buy a BD7 now or do you think Yokomo releases a new car in the next half year?
#2992
I use 350 wt oil and yok blue springs all round on asphalt Beth. I have used that at the hill, SMA and Penrith. I also use 2 degree rear toe.
The other option is to use Ride red springs all round, very similar to the HPI silvers.
#2993
If you look back to the BD5 that was released early 2009 and the BD7 mid 2012.
The BD5 had a few upgrades but it did go through the Mi-Mh to Lipo transition. The team have been testing short shocks and lowered towers but the photo's from ETS seemed to show very standard looking cars.
#2994
It's hard to know, but I'd say unlikely.
Greetings
#2997
Ok. Maybe the yearly updates and new versions form some manufacturers make the people crazy. :-)
#2998
#2999
While I have test driven several other modern tourers, the BD7 is the only one I own, and see no greener pastures as yet
Was just playing the devils advocate, as at our track there are a few "car of the week drivers", and they always seem to go the same pace no matter what brand they run
The BD7, easy on tires, and works well on used tires
Yes, yes it does, thanks for your insight Christian
Care to post a setup ?
Oh, and Happy Birthday
Alright. I am ready to post a set-up.
This car is very good. I have struggled for the past couple of weeks getting the right balance of steering and stability. We have a new layout that is high speed and that actually goes over a few bumps on our carpet track. Very challenging. I worked really hard on refining the set-up this past week. The combination of the MS6, Aeration Caps camber links and angles got me to a very happy place.
Things of note:
-Mazdaspeed 6 is king on carpet for a reason.
-Aeration caps are awesome on our track. They give the car so much traction and allow for more aggressive set-up. EVERYONE should keep a set in their pit box and try them at least once.
-Contrary to popular belief, carbon parts generate more traction than the plastic pieces, at least in mod. They are also more durable.
-Our 3mm O-Rings work awesome, even with no shim in between the ring and the plastic guide. Just dip in shock oil for about an hour so they swell a bit. I have had ZERO leakage.
Attached is the set up.
#3000
Quick question on that setup Christian.
You've ticked 2 hole pistons, is this right or a mistake?
Also that sheet is not too easy to read, at least on my screen, resolution has dropped off a lot.
