Like Tree2Likes
Old 10-23-2013, 03:43 AM   #2896
tried moving the accentrics so the diff does sit straight?
PurcyP is offline   Reply With Quote
Old 10-23-2013, 04:17 AM   #2897
pullstarter's Avatar
Trader Rating: 14 (100%+)
Think I've figured it out, for some reason the bulkheads weren't sitting parallel, there must be some play in chassis screw holes? Anyway I tightened them while perfectly parallel and all seems okay so far.
pullstarter is offline   Reply With Quote
Old 10-23-2013, 06:01 AM   #2898
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by pullstarter View Post
It's not out by much, you can see at the rear of the car the pulley is closer to the bulkheads than the front but given that the cams are in identical positions on each side it SHOULD be arrow straight?
Without shock towers, or upper deck, you are relying entirely on bottom deck screws for alignment ?
Loosely assemble the entire car before worrying about how your pulleys line up
Also, do not sand or remove any material from shock towers, they are supposed to fit snug, this keeps the car square
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-23-2013, 07:54 AM   #2899
got the kyosho p5 o rings for my leaking diff
where do i stick em :|
Old 10-23-2013, 08:38 AM   #2900
stro3579's Avatar
Trader Rating: 20 (100%+)
Does this car have alot of mechanical traction?
stro3579 is offline   Reply With Quote
Old 10-23-2013, 09:02 AM   #2901
ended up sticking the p5 o rings in the only place that fit, under the out drives where the black original ones were.
hopefully fix my problems
Old 10-23-2013, 09:10 AM   #2902
Cadman1981's Avatar
Yep, that's where they go!
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 10-23-2013, 09:17 AM   #2903
Ah good, didnt really make sense putting em anywhere else lol!
also got a few extra bits for the bd7 RS today, its quite fun actually to start slowly taking parts out and putting better ones in, never had a real chance to "hop up" before.
Got the blue alloy front and rear belt pully, alloy front spool, the p5 o rings to stop the leaks and the 5mm clamping hubs, will need to grind down the threads on the CVD to accept better serrated wheel nuts as there is a lot of thread sticking proud still.
Old 10-23-2013, 12:25 PM   #2904
No, I had the top deck on, it was just removed for the picture.
Old 10-23-2013, 04:41 PM   #2905
has anyone on here tried roche dvs shock system on here yet? any comment? I know I shouldnt fix something that's not broken but would like to know if it makes some sort of difference.
jonston is offline   Reply With Quote
Old 10-23-2013, 06:44 PM   #2906
hanzo3's Avatar
Trader Rating: 55 (100%+)
My BD7 has traction issues where it will feel real loose. Exactly like the poster above said about the rear wanting to fishtail. I am running on high grip carpet. I am using the standard plastic arms and knuckles. I will try to run the carbon pieces.
Anyone running the titanium spur gear main shaft? I wonder if this cuts down on the screw stripping that I have been getting.
Chris • TRF419 • TA05V2 •
TQ RC Racing • Powered by teeth
hanzo3 is offline   Reply With Quote
Old 10-23-2013, 07:58 PM   #2907
JimmyMac's Avatar
I ran with plastic arms the first time out with the car, but it generated too much traction. Should be great for asphalt though. Don't forget to try raising the rear inner camber link if nothing else keeps the rear end down. It made an immediate difference for me!
How are people stripping the shaft? Over tightening? How often are you removing it? Just curious. I haven't taken mine off once I got the car fully put together with the correct spur.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 10-24-2013, 03:02 AM   #2908
What tyres are you running? I get this on Sorex.
cyclonetog is offline   Reply With Quote
Old 10-24-2013, 08:08 AM   #2909
hanzo3's Avatar
Sorex 32 and 28.
Old 10-24-2013, 10:44 AM   #2910
Chris could you post your setup using the editable setup sheet HERE
Kind of hard to guess what the issue is, not knowing where your setup is coming from ?
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
