Old 10-20-2013, 11:04 AM   #2866
Hi CoreyW, you stated that your setup and Ronald's are basicly same except front springs at IIC. Is it also the case with your droop settings?
fasfury is offline   Reply With Quote
Old 10-20-2013, 07:36 PM   #2867
JimmyMac's Avatar
Well I tried some of those setups. But none helped with the back end stepping out. What really helped out was raising the rear inner camber link with 2mm shims. That tightened the back end a lot. With that problem solved I can now work on gaining some steering back. Gonna start back with Team Yokomo Basic carpet setup, but with 2mm rear link shim and go from there. Feels good to finally get a "grip" on things.... pun intended...
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
JimmyMac is offline   Reply With Quote
Old 10-20-2013, 08:49 PM   #2868
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
jimmy, please post up your setups
Give the best while u can !
kschu is offline   Reply With Quote
Old 10-20-2013, 09:55 PM   #2869
JimmyMac's Avatar
I didn't like what I had because I was just trying anything to get rid of the back end from coming around. For the main I tried the 2mm rear camber link shim and it worked, but I had some push at certain parts of the track. Next weekend I'll get a setup posted for sure since I know what the car needs to keep the back end planted. Just start with Volker's Basic Indoor Setup or the Basic Carpet Setup posted on TeamYokomo website. Then change rear inner camber link to 2mm shim. Go from there. This will be my starting setup for next weekend.
http://www.teamyokomo.com/download/s...ing_carpet.pdf
Or
http://www.petitrc.com/reglages/yoko...orSetup201211/
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
Old 10-20-2013, 10:00 PM   #2870
JimmyMac's Avatar
Hardman's setup may even work with this change. Worth a try for those with the rear end traction problem.
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
Old 10-21-2013, 05:16 AM   #2871
XSLR8's Avatar
Anyone looking for japan nats pack,look here. http://www.rabhobbies.com.au/estore/...ducts_id/11812
VBC Racing Australia.....FUTABA AUSTRALIA.....Volante tires.....WTF Fans.....R.A.B Hobbies....President www.serccc.com.au
XSLR8 is offline   Reply With Quote
Old 10-21-2013, 07:03 AM   #2872
Nearly identical - we were running a little less rear droop(.5mm). Rebound would be the only other difference(+/- 10%) but again, nearly identical.
CoreyW. is offline   Reply With Quote
Old 10-21-2013, 10:22 AM   #2873
Ronald Voelker winning first final at mibosport cup this weekend:
+ YouTube Video
andy3000 is offline   Reply With Quote
Old 10-21-2013, 10:38 AM   #2874
thanks for the tip on kyosho o rings for the diff, have ordered them today
PurcyP is offline   Reply With Quote
Old 10-21-2013, 11:21 AM   #2875
jag88's Avatar
+ YouTube Video
WOW, simply WOW !
jag88 is offline   Reply With Quote
Old 10-21-2013, 01:06 PM   #2876
Hi guys. Has anyone tried to run the car with a geardiff in front?
Gerrie is offline   Reply With Quote
Old 10-21-2013, 03:35 PM   #2877
JimmyMac's Avatar
I did this past weekend. I ran it with 2.5M diff lube. It tamed the car down a little but I was fighting the rear end looseness all day long till the main. So I cannot comment too much on it. I'm gonna run it some more this weekend once I get a good setup and then compare it to a spool.
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
Old 10-21-2013, 09:19 PM   #2878
jdm19turn's Avatar
hey jimmy how you been bud you been racing at ho b max in nc I'm might come down and race this weekend with you and tag I'm getting my mi5 dialed in
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 10-21-2013, 09:36 PM   #2879
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
It calms the steering down a lot so you can look at it from different shaded glasses. It dulls the steering and responsiveness, OR, it makes the car calmer and easier to drive. You definitely loose a good bit of forward traction out of the sharp and slow corners that lead into a straight.
I've been running a front diff on carpet and a spool outdoors, but the lap times are very close between the two. If I had to pick one, I like the spool all around, its harder to drive but is faster especially as you move to higher powered motors.
Racing4Evo is offline   Reply With Quote
Old 10-21-2013, 10:43 PM   #2880
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
I agreed..
OVA is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
SEO by vBSEO 3.5.0
