Like Tree6Likes
Old 10-18-2013, 06:26 AM   #2851
Originally Posted by kosmic View Post
Brilliant, will try this weekend at uk's biggest carpet championship. Still, do you connect bridge to topdeck or leave top screw out???? And how would you word how the longer links fr and r make the car feel. Either long fr or long r or both long.
Cheers
Yes, the screw is in.
Long front link: less initial turn-in, more steering middle off.
Note: Car will feel smoother and will be less likely to traction roll. Good for tracks with long sweeping corners. Not good for tracks with quick transitions(i.e chicanes) or tight corners. *Generally speaking*
Short front link: more initial turn-in, less steering middle off.
Note: Car will feel more sensitive and steer aggressively into the corner but will be more likely to traction roll. Good for tracks with quick transitions(i.e chicanes) or tight corners. Not good for tracks with long sweeping corners. *Generally speaking*
The rear is basically the same.
Long rear link: less initial turn-in, more steering middle off, and easier to drive.
Note: Car will feel smoother. Good for tracks with long sweeping corners. Not good for tracks with quick transitions(i.e chicanes) or tight corners. *Generally speaking*
Short rear link: more initial turn-in, less steering middle off. Makes the car very stable on power , especially on low grip tracks.
Note: Car will feel more sensitive and steer aggressively into the corner. Good for tracks with quick transitions(i.e chicanes) or tight corners. Not good for tracks with long sweeping corners. *Generally speaking*
CoreyW. is offline   Reply With Quote
Old 10-18-2013, 07:31 AM   #2852
This is awesome, thank you. Something tells me other people will greatly appreciate this super info too
Thanks again
Durango DETC410 - HobbywingV3.1 - Futaba - Orca
www.maritimeracing.org
kosmic is offline   Reply With Quote
Old 10-18-2013, 08:17 AM   #2853
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Cheers
hi Simon
I would try Andrew setup with short link at ews if I was racing will find setup we had on car for brca indoor later
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 10-18-2013, 09:15 AM   #2854
Cool
Old 10-18-2013, 09:22 AM   #2855
Default re
Make sure to try pink vs. blue springs.
Old 10-18-2013, 02:15 PM   #2856
Lastly, do you ever drill 1mm hole in shock cap on carpet??
Old 10-18-2013, 07:25 PM   #2857
Bill K's Avatar
Originally Posted by beamcat View Post
MR..ROCHE DIAGON VOLUME SHOCK (DVS) TOURING SHOCKS SET FOR YOKOMO BD7- ROC-BD7-07
All-newly designed “Diagon Volume Shock (DVS)” for touring car. Shorter shock shafts, bigger shock body diamenter keeping the volume the same as original shocks. Shock top cap, shock body, shock bottom cap and height adjuster are made from aircraft grade aluminum with bling machine cutting. All new piston design groove to improve the linearity of oil flow. 4 different springs rate suitable for different track conditions.
Kit are included :
1) Full Set of MR..ROCHE DVS Shock Springs
2) 3 Holes and 4 Holes DVS Shock Pistons
3) Titanium Coated Shock Shafts
4) 4 Hardness DVS Oil Sealer Caps Set
5) Hard Coated Aluminum Shock Bodies
6) Front & Rear Shock Tower for BD7 (-2mm)
Please let me know if anyone has/will be trying this new option part in conjunction with their existing setup. I would like to know how they compare to the current Yokomo shock absorbers/front and rear shock towers, and exactly what performance increase/decrease they will provide. Asphalt would be preferred.
Cheers.
Billy Karnaros
Yokomo BD7 2016
Powered by Muchmore
Futaba 4PX
Bill K is offline   Reply With Quote
Old 10-18-2013, 08:47 PM   #2858
Craig W's Avatar
car work lot better with some rebound so no need for 1mm hole
Old 10-19-2013, 01:10 AM   #2859
For EWS I'd really recommend staying with the short links at the bulkhead. Actually trying to run long there is a right pain because the thread on the ball stud hits the tensioner cams so you either have to dremmel some thread off or run too many spacers. I have some spare studs cut down for making the change but always end up back on short anyway.
At the winter national I ran long rear at the hub but went back to kit towards the end of the weekend and del it was better with the grip higher so I'd be tempted to just leave it there.
For me, on the EWS track, I found the biggest 2 things to help were running 0.5mm more under the front ball stud than the rear and 1.5d fr camber and 1.8d rr camber, 5.0mm fr ride height 5.25 rr ride height. Rest of it was basically Identical to that hardman setup.
I totally agree that measuring droop over ride height is an easy way to do it, but if you are more comfortable using a gauge then 6fr 4.5rr measured on the wishbone directly under the outer pin should be a good starting point for Sorex tyres at EWS.
cyclonetog is offline   Reply With Quote
Old 10-19-2013, 07:10 AM   #2860
stro3579's Avatar
Trader Rating: 20 (100%+)
Where can I find the Japan Nats Pack?
stro3579 is offline   Reply With Quote
Old 10-19-2013, 12:47 PM   #2861
Does anyone find their rear diff leaking a lot?
got a BD7 RS and i can build a diff fine, but this rear one keeps seemingly leaking :|
PurcyP is offline   Reply With Quote
Old 10-20-2013, 12:13 AM   #2862
Hugh Jazz's Avatar
kyosho P5 orings fix that.
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 10-20-2013, 02:41 AM   #2863
anyone with good pinion/spur setup for a reedy 21.5 motor
Christian82 is offline   Reply With Quote
Old 10-20-2013, 08:18 AM   #2864
Luppi Stefano's Avatar
Cheers.
I picked up this kit, next sunday I try on my BD7
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 10-20-2013, 10:29 AM   #2865
jag88's Avatar
Stefano, what happened to the STX ?
jag88 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
