Like Tree5Likes
Old 10-12-2013, 05:49 PM   #2806
TLR
I cant believe Volker does not have his setup posted yet!!! I mean come on it has been 30 minutes since he won!!
TLR is offline   Reply With Quote
Old 10-12-2013, 06:31 PM   #2807
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Probabky sick of seeing posts from all those d!cks that say it is a one off prototype car that isnt remotely close to a stock BD7.
Racing4Evo is offline   Reply With Quote
Old 10-12-2013, 06:46 PM   #2808
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Well I'm sure the that Andrew Hardman will share his set up..you never know ,it might be close to Volker...
OVA is offline   Reply With Quote
Old 10-12-2013, 07:25 PM   #2809
JimmyMac's Avatar
Originally Posted by f888fhw View Post
I'm thinking about buying the BD7 RS to give touring cars a go. After doing a bit of research it looks like the servo is fixed to the car with 1 screw and some servo tape? Is this correct, will this be strong enough? Has anyone got any pictures and feedback regarding this mounting method.
I've never tried it on this car. In the past I have done it with no issues. I'm currently using the CSO overhang mount. Same Yokomo Blue Aluminum at 1/3 the cost of the Yokomo mount. Here's a quick pic of mine. If you get the RS, a good optional pack to get is the Japan Nats Option Pack. It's between $109 to $120, but it includes all the hopup options that you'll need for carpet and high traction surfaces. Or just run the car as is and have fun!!
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 10-12-2013, 07:42 PM   #2810
JimmyMac's Avatar
Originally Posted by hanzo3 View Post
Do you guys run the foam that goes on top of the shock bladder? This is for carpet. For the setup sheets, where is droop measured from? Under the arm or at the pin?
I don't run the foam on top of the bladders, but I do run the black bladders. As for droop, this is how I measure. Here is an old pic I took. This one is 8.5mm rear droop...
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 10-12-2013, 08:39 PM   #2811
SLOW 77's Avatar
Trader Rating: 25 (100%+)
Corey W, on Andrew's setup what brand oil are you'll using? AE, Yokomo?
Thanks!
John Hodges
Yokomo BD7 - KOPropo EX-RR -Xray NT1 -Mooreway Motorsports
SLOW 77 is offline   Reply With Quote
Old 10-14-2013, 03:06 PM   #2812
Any setups or motor/esc/servo combos from worlds?
Christian82 is offline   Reply With Quote
Old 10-14-2013, 03:33 PM   #2813
Thanks!
We are using the Yokomo oil.
Regards,
Ian (Andrew's Dad)
Team Yokomo, Team ORCA, Solaris Tires, PROTOform, ProSpec
ADHSponser is offline   Reply With Quote
Old 10-14-2013, 08:25 PM   #2814
SLOW 77's Avatar
Thanks Ian!
John Hodges
Old 10-15-2013, 06:05 AM   #2815
stro3579's Avatar
Trader Rating: 20 (100%+)
Where can I find the Japan nat pack? No one has them in stock. I have searched everywhere.
stro3579 is offline   Reply With Quote
Old 10-15-2013, 06:08 AM   #2816
stro3579's Avatar
Where can I find the Japan Nats Pack b7-jnop? I have searched everywhere and no one has them.
Old 10-15-2013, 07:22 AM   #2817
Default re
We will be posting our setup very soon, and for the most part, our setup is very close to Ronalds.
Just an FYI, Ronald runs a completely stock BD7 with no special parts(meaning parts not available to consumers). Yumino is an absolute master with details(both setup and build) and that is the only thing that separates his car from everyone else's. As a fellow mechanic, I hope to be as good as him one day!
Stay tuned for the setup(hopefully by Wednesday).
CoreyW. is offline   Reply With Quote
Old 10-15-2013, 08:03 AM   #2818
Can some offer me some advice please, its was my second night running my new bd7 in stock class, I lost steering 3 times tonight because of my bd7 bell crank system, the screws that hold it together keeps loosening and falling out, if I tighten it u my steering locks up and the servo cant push it.
I was thinking of putting a couple of drops of locktite in for next week, but does anyone has any tips on how to keep it secure without screwing it down to hard?
thanks
Jon
jonston is offline   Reply With Quote
Old 10-15-2013, 08:17 AM   #2819
thanks
Jon
Hi Jon, just use a tiny bit of locktite to help keep the screw secure. If you are using a direct servo horn, crashes will cause vibrations throughout the steering system and screws will eventually back out, so it is best to locktite ALL of the screws in that area. Makes sure to use a mild version of whatever brand you choose, as I am sure you would want to be able to remove the screws in the future.
Old 10-15-2013, 08:51 AM   #2820
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
thanks
Jon
Are you missing shims?
You should be able to tighten without any bind at all
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
