Old 10-01-2013, 07:42 PM   #2791
Default re
Originally Posted by ElliotCanada View Post
Congratulations to Corey (Team Yokomo wrench for Team Yokomo Driver Andrew Hardman) for winning the 2013 Ontario Time Attack Shootout with his GT2 BMW last weekend at Mosport now Canadian Tire Motorsports. He knows how to setup and drive RC Cars and Real Cars.
Corey - I now have Yokomo BD7s, sold the other cars. The Cayman R goes into Pfaff next week for a roll bar. I will need help and advice on the Yokomo and Cayman.
Have a great time in Vegas.
I didn't expect to see that pop up here, Thanks! Steve and I both look forward to seeing you out there next year, so please don't hesitate to contact me about either car!
For those who have no idea what we are talking about, feel free to check out my Youtube channel.
https://www.youtube.com/user/TRFWhitey
See some of you at IIC!
CoreyW. is offline   Reply With Quote
Old 10-02-2013, 04:44 AM   #2792
Aaron_M's Avatar
Originally Posted by cyba888 View Post
You guys think its a good idea to buy RS model to use as spare parts for my BD7? Just the small plastic parts, bearings, rear diff, carbon chassis and upper deck alone is worth over $200?
Exactly what i have done
Replaced chassis plate, rear diff, ball cups, full set of driveshafts, bearings...
Refreshed the car for much cheaper than what it would have cost to buy replacement spares. Building the RS on my old chassis plate to use as spare or wet car next year
Yokomo BD7
Aaron_M is offline   Reply With Quote
Old 10-02-2013, 06:14 PM   #2793
NolanP's Avatar
Throwing around the idea of refreshing one of my cars in full or selling it for a cheap price....
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 10-03-2013, 02:03 AM   #2794
cyba888's Avatar
Good idea
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 10-03-2013, 06:30 AM   #2795
NolanP's Avatar
Good idea
I'm actually tossing around the idea of getting the Japan Champ pack, the high traction top deck, and chassis. Then stripping down the car and if any aluminum is bad replacing it. Thats still alot cheaper than buying a new TC.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 10-03-2013, 11:49 AM   #2796
Hey
I drive my BD7 now for some Practice Days. At the moment theres nothing broken. But what spares should I buy? What are the most broken things on this Car? And what Tuning Options are recommended?
Magrad is offline   Reply With Quote
Old 10-07-2013, 10:23 AM   #2797
Originally Posted by Magrad View Post
Hey
Are you running mod or 17.5? I've been running asphalt mod without damage. I put Spec-Rv2 drive shafts up front. I would get the usual spares like hubs, knuckles, etc
Adrian Clements
Team Meech
Yokomobd7 2016
Kyosho MP9E TKI
M3CSLDreamin is offline   Reply With Quote
Old 10-07-2013, 12:38 PM   #2798
Hey, sorry I ran 13.5t.
The Spec-R V2 Shafts im Driving theyre in.
Sorry, I mean what are the standart Spares, its my first Touring Car after some years Offroad racing.
Also another Question, how big is the difference between the Graphite and the Standart parts?
Old 10-07-2013, 08:43 PM   #2799
JimmyMac's Avatar
I would use the graphite parts on high traction tracks. If the traction is low, stick with the kit arms. I'm trying to limit my spares. I have:
Steering Hub Carrier (3 sets)
Rear Hubs (1 pair)
Steering Blocks (2 pairs or more)
King Pins (1 pair)
Front Arms (2 pairs)
Rear Arms (1 pair)
Inner Suspension Arm Pin Front (1 pair)
Inner Suspension Arm Pin Rear (1 pair)
Outer Suspension Arm Pin (1 set)
Front Bumper and Body Posts (1 set)
I think that's it's for my "spares".
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 10-09-2013, 06:56 AM   #2800
NolanP's Avatar
Rear Hubs (1 pair)
King Pins (1 pair)
Rear Arms (1 pair)
perfect description.
I've found that the long arms up front and the short arms in the rear.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 10-09-2013, 08:12 AM   #2801
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
My understanding there isnt long or short arms, the shock mounting holes are in the different location..
OVA is offline   Reply With Quote
Old 10-09-2013, 06:12 PM   #2802
JimmyMac's Avatar
BD7 rear plastic kit arms are 39.5mm shock mounting hole. So I bought the 39.5mm rear graphite arms. This shock mounting position seems to be the dominate one for most setups. The others are 40.5mm and 41.5mm. Each size up moves the lower shock mount out towards the wheels. All arms are the same length. Just different shock pivot points as OVA stated. Been like this since the BD5 days. The front arms only have one shock mounting hole, so you either have a plastic arm or a graphite arm up front. No size difference for BD7.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 10-12-2013, 09:51 AM   #2803
hanzo3's Avatar
Trader Rating: 55 (100%+)
Do you guys run the foam that goes on top of the shock bladder? This is for carpet. For the setup sheets, where is droop measured from? Under the arm or at the pin?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 10-12-2013, 02:35 PM   #2804
I'm thinking about buying the BD7 RS to give touring cars a go. After doing a bit of research it looks like the servo is fixed to the car with 1 screw and some servo tape? Is this correct, will this be strong enough? Has anyone got any pictures and feedback regarding this mounting method.
f888fhw is offline   Reply With Quote
Old 10-12-2013, 03:44 PM   #2805
cyba888's Avatar
Bd7 is same currently run mod no problems....I did order the floating servo piece just waiting for it to arrive
Futaba 4PX
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jessesnellen
