Old 09-17-2013, 05:22 AM   #2761
swimbikerun's Avatar
Trader Rating: 100 (100%+)
Originally Posted by hanzo3 View Post
I am having problems changing spur gears. The screw always gets stripped on the main gear shaft. It won't let me take off the spur unless I dremel it off. Anyone have that problem? Kimbroughs seem to hit the upper deck as well, I need to dremel that too?
Kimbroughs are too thick. Xenon, Panaracer and RW V2 spurs are thin enough so I would recommend going that route rather than dremelling the top deck.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 09-17-2013, 05:59 AM   #2762
cyba888's Avatar
Thanks for the feed backs
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 09-17-2013, 09:39 AM   #2763
Cadman1981's Avatar
I remove only one screw for the shaft and i'm able to slide the pulleys over to change the spur. But i noticed if you put the screw back without paying attention, it can ruin the threads and then you're...screwed
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 09-17-2013, 11:29 AM   #2764
Trader Rating: 21 (100%+)
Chris, I've learned xray spurs are also a little thinner than Kimbroughs. That might work as an alternative to the ones listed above too.
-Roy
silencery is offline   Reply With Quote
Old 09-17-2013, 12:52 PM   #2765
I also had a problem with the screws in the pulleys. Last Sunday I was for the first time on a Aspahlt track next to me. The Car felt after some first small changes great.
But after about 3Lipos I lost one screw out of the Pulley -> new one in there - 1 lipo later the same problem.
Does anybody know what I made wrong?
Magrad is offline   Reply With Quote
Old 09-18-2013, 01:45 PM   #2766
2 Thoughts.
1. Are you shimming the pulley correctly? If there isn't not enough tension on the pulley shaft then it could come loose.
2. I used a small amount of thread lock on the screws going into the pulley shaft.
Old 09-18-2013, 02:01 PM   #2767
Hey,
the shimming is exactly like the description in the manual and I think its okay. I didnt used Thread lock now I tried is with a little bit for not too thigten the screws. I will test it on Sunday if the weather is okay.
Thank you for the Answear
Old 09-19-2013, 03:27 PM   #2768
Reese Bobby's Avatar
Hi All,
Which additional parts would you guys recommend for a new DB7 setup? Options, tuning etc. I would like to get an idea of what I need to include for a fully spec'ed DB7.
Thanks Guys.
VBC Wildfires
Orca - Revolectrix - Sanwa - SMC
Reese Bobby is offline   Reply With Quote
Old 09-19-2013, 04:40 PM   #2769
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Reese Bobby View Post
Hi All,
Which additional parts would you guys recommend for a new BD-7 setup? Options, tuning etc. I would like to get an idea of what I need to include for a fully spec'ed DB7.
Thanks Guys.
The BD7 is great out of the box, however, here are some ideas
BD7 Additional parts, RC Tech Notes
Team Yokomo BD7: Which option parts do I need?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-19-2013, 04:54 PM   #2770
There is a JNOP option pack - YOKB7-JNOP - that has a number of these items included. I would recommend that you get this at a minimum.
Regards,
Ian
Team Yokomo, Team ORCA, Solaris Tires, PROTOform, ProSpec
ADHSponser is offline   Reply With Quote
Old 09-24-2013, 01:59 PM   #2771
Ian, I pulled the trigger. See you guys soon.
Number 49 Lou's Speedway Canada, Honda House www.hondahouse.com
ElliotCanada is offline   Reply With Quote
Old 09-26-2013, 02:56 AM   #2772
JimmyMac's Avatar
Anyone running the BD7 RS version? I'm running the BD7 and love it, but I have a friend looking into the RS. I was just wondering on the quality of the bulkheads and other composite parts as well as handling. Thanks.
M.J. McIntyre
R1Wurks
Yokomo YRX12
Ho-B Max
JimmyMac is offline   Reply With Quote
Old 09-26-2013, 06:41 AM   #2773
Trader Rating: 1 (67%+)
Send a message via AIM to racer034life
How hard is the bd7 to drive compared to my Rsd tc6.1? I as cause im looking for a car with more steering in the centet of the corners.But ive been told that the BD7 is more of a 13.5 mod car or should only be used in class that are higher speeds. Im currently racing 17.5.
Sold All my R/c car stuff to by a zx-14, Access Hobbies, CRC, ARC,
racer034life is offline   Reply With Quote
Old 09-26-2013, 07:43 AM   #2774
My son, Andrew, just switched to the BD7 and found it is very easy to drive in Mod - and he also feels that it has potential for Super Stock and Stock with the corner speed it seems to be able to carry. The car has been successful in the ETS series in Stock on carpet and asphalt.
Regards,
Ian
Old 09-27-2013, 05:30 AM   #2775
Aaron_M's Avatar
Been running the BD7 for about a year and currently building a BD7RS, hopefully get it finished over the weekend. If so i will be running it mid week so i will let you know how it goes
Yokomo BD7
Aaron_M is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
sstretch
SEO by vBSEO 3.5.0
