Like Tree6Likes
Old 09-11-2013, 07:23 PM   #2746
Originally Posted by hanulec View Post
Corey - don't give away all of Andrew's "go fast" secrets now! I'm excited to see him with a potent weapon. Cya at Vegas!!
What can I say, we are here to help. See you soon!
CoreyW. is offline   Reply With Quote
Old 09-12-2013, 07:14 AM   #2747
Is anyone running a BD-7 RS? I like the approach Yokomo used with keeping the carbon fiber chassis but replacing the aluminium with plastic to reach the lower price point. I was wondering what anyone running the car thinks of the quality and performance. It seems that swaybars and the aluminum motor mount would be important upgrades.
kawi650 is offline   Reply With Quote
Old 09-12-2013, 01:35 PM   #2748
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool new kit, but only released 1 week ago, with none in the US marketplace yet
May take a bit to see feedback
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-12-2013, 08:12 PM   #2749
cyba888's Avatar
Is the spec r dcj and better than the yokomos? I had spec r dcj on my t4 and they were junk had a lot of play. The spec r dcj looks identical between bd7 and t4. Someone also mentioned yokomo dcj are not good?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 09-12-2013, 10:54 PM   #2750
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
These will be much better than both! http://www.roche.hk/shopping/index.p...product_id=805
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 09-12-2013, 11:17 PM   #2751
cyba888's Avatar
Those look identical to Spec R?
Futaba 4PX
Old 09-13-2013, 12:11 AM   #2752
Hugh Jazz's Avatar
ChaChing $$$$ lol.
I use the Tammy or the Top ones. They are a lot stronger than the Yokomo or Spec R. Only problem is the pin is loose in the spool cup
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 09-13-2013, 05:29 AM   #2753
cyba888's Avatar
What material are the stock spool cups? Are there spring steel ones out on the market?
Futaba 4PX
Old 09-13-2013, 05:36 AM   #2754
Standard parts are HQ liteweight steel, this is what the Team drivers use as well, if not running a diff
http://www.amainhobbies.com/product_...rive-Cup-Steel
Old 09-13-2013, 09:19 AM   #2755
cyba888's Avatar
Thank you
Can someone confirm if Spec R and Roche DCJs are different? They look identical
Futaba 4PX
Old 09-16-2013, 06:05 PM   #2756
Cadman1981's Avatar
I own the Spec-R V2 set, they don't have any slop or play in them. I've heard the Yokomo ones are fragile, and Rolker uses a new set each heat... but don't quote me on that, i read that in this thread
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 09-16-2013, 06:14 PM   #2757
Andrew (Hardman) has been using the Yokomo version - and we have been happy with how they have been lasting. We have had a few race weekends on them without incident so far.
Regards,
Ian (Andrew's Dad)
Team Yokomo, Team ORCA, Solaris Tires, PROTOform, ProSpec
ADHSponser is offline   Reply With Quote
Old 09-16-2013, 06:52 PM   #2758
I've had zero issues with the Yokomo DCJ's
Also noticed Arrowmax DCJ's look identical to Yokomo, to the best of my knowledge, Arrowmax are quite durable too
Only run 13.5 though
Old 09-17-2013, 12:19 AM   #2759
hanzo3's Avatar
Trader Rating: 55 (100%+)
I am having problems changing spur gears. The screw always gets stripped on the main gear shaft. It won't let me take off the spur unless I dremel it off. Anyone have that problem? Kimbroughs seem to hit the upper deck as well, I need to dremel that too?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 09-17-2013, 03:39 AM   #2760
A buddy of mine had the same problem.
There were 2 causes for his problem:
-use of loctite
-he unscrewed one screw fully, then the other one
Now that he unscrews them bit by bit and doesn't use loctite anymore everything's fine for him.
Regards,
David
niemand is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
