Like Tree5Likes
Old 09-09-2013, 03:53 PM   #2731
TLR
Posting the setup would be great, thanks
TLR is offline   Reply With Quote
Old 09-11-2013, 06:09 AM   #2732
Default re
Here is Andrew Hardman's carpet setup from this past weekends test at The Gate.
Keep in mind, this car is still very new to us and the setup will be changing as we learn more. I will keep posting setups only when I feel the car is significantly better.
Hope this helps!
CoreyW. is offline   Reply With Quote
Old 09-11-2013, 07:52 AM   #2733
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Hope this helps!
Thanks! How far forward do you have the body mounted? My car feels like its floating and I'm runnin a similar setup with 60wt oil and normal wheelbase, but my body is pretty far foward.
Racing4Evo is offline   Reply With Quote
Old 09-11-2013, 08:21 AM   #2734
Body position only effects steering, not overall grip. We have the body mounted approx. 2mm ahead of the most forward position. To be more specific, I have cut the body 2mm behind the cut lines that Protoform stamps into the body for the front wheels.
To address the "floating" issue, you must make sure that you know where you stand with the following three things:
1. Low grip condition(track surface)
Is your track always low grip? If so, then setup changes are needed - if not, do not chase the track as grip may change throughout the day.
2. Tires.
Are your tires in good shape? If yes, are they a good tire to begin with? Rule of thumb; Do not set your car up on old tires unless they are proven to work better than new(Jaco for example).
3. Tire sauce.
Use a sauce that most others at your track have. Sometimes, additives do not mix well, especially when a particular brand is used by a majority of those racing. Paul Lemeiux's new LGC compound works fantastic - much better than Jack, so I would start there if this is a concern of yours.
Old 09-11-2013, 08:47 AM   #2735
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
I think you need to try lighter oil Pete
My BD-7 lost grip when I ran over 450 cst
Cool we got a hot shoe like Andrew running a Yok now
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-11-2013, 08:59 AM   #2736
masterhit's Avatar
Trader Rating: 15 (100%+)
Or go to a larger piston hole size in conjunction with the heavier oil ala Kevens' TC6 set-ups. I.E. 1,1,1.5 or 1.2x3. I'm a big fan of this dampening setup and the old style Losi 56 pistons drop right in (which is around 1.19mm IIRC).
Mike Slaughter
masterhit is offline   Reply With Quote
Old 09-11-2013, 12:09 PM   #2737
Racing4Evo's Avatar
Ok. I'll try 450 again. I need to get some more track time with the Jaco blues. The car just seems floaty and has less forward traction when i put the Jacos on. Now that I look at it, your setup has less uptravel than mine. I will try both.
Old 09-11-2013, 12:20 PM   #2738
Racing4Evo's Avatar
2. Tires.
3. Tire sauce.
Im running on a medium grip carpet track and i was using 4 run old Jaco Blues at the start of the day. Unfortunately the track is exclusive to Jack the gripper and SXT. Grip does change a little as the day goes on but I feel like the balance is off.
Old 09-11-2013, 12:25 PM   #2739
Racing4Evo's Avatar
Mike Slaughter
Actually I drilled my pistons to 1.15mm
Old 09-11-2013, 12:34 PM   #2740
If your track is low bite, or really worn carpet, I would suggest NOT cleaning the tires every run. Jacos are very sensitive to this - allot of time they are best left alone. If you do clean the tires, ONLY do it just before you apply sauce for the next run or you risk drying out the tire.
Setup wise, you can try standing up the shocks another hole which will improve forward bite.
Old 09-11-2013, 02:07 PM   #2741
+1 Corey gave me this advice and it works very well!
Grant
XRAY T3'12 17.5, Spec R R1 13.5, CRC GenXL, Grant Galloway Designs ( Painter )
lifeguy is offline   Reply With Quote
Old 09-11-2013, 02:23 PM   #2742
Racing4Evo's Avatar
Interesting...I'll try that this week! I was cleaning the tires with SXT or motor spray.
Old 09-11-2013, 04:49 PM   #2743
hanulec's Avatar
Trader Rating: 27 (100%+)
Corey - don't give away all of Andrew's "go fast" secrets now! I'm excited to see him with a potent weapon. Cya at Vegas!!
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-11-2013, 05:03 PM   #2744
olhipster1's Avatar
Trader Rating: 95 (100%+)
Send a message via Yahoo to olhipster1
Default Holy Blue parts
I do believe Amain will sell all their Yoks kits...... ...get em while you can
one of the Top North American mechanics posting on the Yok thread....
I do believe Yok made an excellent move in picking this team.
2014 Year of the Andrew
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 09-11-2013, 06:21 PM   #2745
Default re
We appreciate the warm welcome to the team, guys! Our transition from Xray has gone much smoother than we anticipated, and the car has shown itself to be MORE than capable of delivering results. I know Andrew very well, and to be honest, this is the most confident I have seen him in loooong time! More than likely, this is due to the strong performance the car has shown in the short time we have had them, and we are extremely excited to see what the rest of 2013/2014 has in store for us.
I will do my best to help you guys when needed- if you see us at the track, do not hesitate to come say hi, or ask for help.
Thanks again everyone!
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
