Like Tree2Likes
Old 09-08-2013, 08:47 AM   #2716
Reese Bobby's Avatar
Hi All,
Apologies if this has been asked before, is anyone aware of a new chassis for the 2014 WC season. I am currently reviewing whats available and imagine a new chassis is being developed, just like the 418.
VBC Wildfires
Orca - Revolectrix - Sanwa - SMC
Reese Bobby is offline   Reply With Quote
Old 09-08-2013, 10:31 AM   #2717
Jochim_18's Avatar
The good thing about Yokomo If their current touring is very competitive they will not change anything maybe a little refinement at IFMAR worlds.. Just expect Yokomo will release the world edition of the BD7...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 09-08-2013, 11:57 AM   #2718
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
What is great is that yokomo historically release an upgrade kit and judging by the car's relative pace now, it shouldn't be a dramatic change.
Racing4Evo is offline   Reply With Quote
Old 09-08-2013, 08:41 PM   #2719
TLR
Does anyone have any idea how to get ahold of the current carpet setup Hardman is running?
TLR is offline   Reply With Quote
Old 09-08-2013, 09:05 PM   #2720
We were testing at a carpet track this weekend (the new carpet at The Gate) and just got home tonight. I can ask Corey (Andrew's mechanic) to put together a sheet of what we ended up with.
The car worked very well - we were really pleased with it. The new carpet at The Gate is a great place to test ahead of the IIC. We will be back there next weekend for the IIC Warmup race and can give more feedback after that practice/race weekend.
Regards,
Ian (Andrew's Dad)
Team Yokomo, Team ORCA, Solaris Tires, PROTOform, ProSpec
ADHSponser is offline   Reply With Quote
Old 09-09-2013, 03:38 AM   #2721
Hey guys,
as you know there are two ways of setting droop as per the setup sheet.
There is the (for me) conventional method of measuring under the arm.
But there's also the option of measuring under? the pin.
Could someone please explain how to do that, and maybe how to convert the different types of measuring?
Regards,
David
niemand is offline   Reply With Quote
Old 09-09-2013, 03:43 AM   #2722
On another note:
Does anyone here own both a BD7 and an Xray T4?
I'm quite happy with my Xray on Asphalt (and very happy with it on Carpet) but it just seems to create much less mechanical grip than the Bd7 which becomes quite evident on medium and low tracion tracks.
As I'm considering to switch to the new Yokomo, a comparison would be much appreciated.
Regards,
David
Old 09-09-2013, 03:46 AM   #2723
The measurement is to the centre of the pin, the easiest way I find is to use a steel rule to measure the height of the pin off your setup board.
As the arm is a set thickness it's trivial to use 1 measurement to calculate the other, but the pin is regarded to be more accurate because the moulded parts can contract after moulding and/or get scuffed up/worn down from accident or other damage.
cyclonetog is offline   Reply With Quote
Old 09-09-2013, 07:46 AM   #2724
cyba888's Avatar
Will new model or upgrade be released by end of the year?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 09-09-2013, 08:08 AM   #2725
peter.'s Avatar
sure no new car, maybe small update (2-3 parts), but no new car sure. Car work prefect in booth conditions… thats what yokomo europe says
peter. is offline   Reply With Quote
Old 09-09-2013, 08:25 AM   #2726
Not heard of anything.
Smartypants is offline   Reply With Quote
Old 09-09-2013, 09:27 AM   #2727
cyba888's Avatar
Thanks guys what other spare/after market parts is recommnded to run modify on asphalt? Carbon C hubs front and rear? Any build tips I should look out for?
Futaba 4PX
Old 09-09-2013, 09:30 AM   #2728
Actually the C hub is about the only moulded part to always run the kit item.
If your carpet is high grip you'll probably want graphite arms, knuckles and rear hubs.
Old 09-09-2013, 11:07 AM   #2729
Jochim_18's Avatar
No new car for sure unless their rival Tamiya pick up the phase with their new up-coming 418..
Old 09-09-2013, 02:25 PM   #2730
Adam B's Avatar
After seeing Andrew run this weekend it has me really thinking about one. But, if Andrew ran an old Nikko car it would probably look good also. Andrew, Corey, and his father have a great system in place and the Yokomo team is very lucky to have them. I wish this great bunch of guys much luck, until I finally step up to feeling comfortable with Mod, then I wish you consistent 2nd place finishes behind me.
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
