Like Tree6Likes
Old 08-06-2013, 04:23 PM   #2566
swimbikerun's Avatar
Trader Rating: 100 (100%+)
Originally Posted by Cadman1981 View Post
I noticed you have a Tamiya 417v5, The Raceberry upgrade uses yokomo parts, how do you like the Tamiya compared to the Yokomo?
I like both (BD-7 & Raceberry 417V5). I thought the Raceberry was easier to drive for mod (running a 5.0) outside but my times were faster with the BD7. I also generally like the maintenance of the BD7 more since it uses more standardized parts all around rather than the Tamiya. The one feature I prefer on the Tamiya over the BD7 is the design of the DCJ. I haven't had an issue with the Yokomo DCJs but like the design of the Tamiya's more. Take my advice for what it's worth since I'm an okay driver on a good day.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 08-06-2013, 08:40 PM   #2567
Cadman1981's Avatar
I got the Spec-R V2 DCJs for my yok, they are similar to the tamiya, haven't had an issue since i got them at the end of spring.
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 08-07-2013, 09:18 PM   #2568
Default Help with Base Asphalt Setup
Can someone help me understand the attached droop setting?
It's from the Base Asphalt setup sheet on PetitRC, I'm using this setup to initially get used to my car.
Yokomo recommend 9.5mm (Pin) at the front and 8.0mm (Pin) at the rear.
Do these values convert easily to using a droop gauge with the car on 10mm blocks?
Or to get it right should I be measuring droop differently?
Thx
Chris K
Ignition75 is offline   Reply With Quote
Old 08-08-2013, 07:41 AM   #2569
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thx
Chris K
YOKOMO Touring Car BD-7
Droop over RH is what I look at
There are 2 methods for droop on the setup sheet, both are easy check
I would reccomend kit build with HPi Silver springs, over any of the Team setup sheets as a baseline
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-08-2013, 01:58 PM   #2570
will it come new version of bd7?
anyone have news about it?
Zooberg is offline   Reply With Quote
Old 08-08-2013, 03:19 PM   #2571
peter.'s Avatar
no new car, maybe small update (2-3 parts),
peter. is offline   Reply With Quote
Old 08-08-2013, 05:41 PM   #2572
Why is that mate?
Old 08-08-2013, 08:40 PM   #2573
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
Why is that mate?
maybe you should tried it and you will see...
OVA is offline   Reply With Quote
Old 08-09-2013, 01:50 AM   #2574
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Tried yokomo springs on carpet again, this time with 60wt oil and 1.1mm pistons. Normally I use 37.5wt. I tried these earlier but they were just so on edge that I couldn't drive a consistent five minutes. The heavier oil really helped calm things down. The yokomo springs bring this aggressive feel to the car in the middle of the corner. I'm definitely going to work on the setup now that I got the car manageable.
Next time I will try a little bit of a softer oil, maybe 50wt.
Racing4Evo is offline   Reply With Quote
Old 08-09-2013, 06:05 AM   #2575
Thank you very much!
Old 08-09-2013, 06:45 AM   #2576
Cadman1981's Avatar
What pistons did you use in the shocks? 1mm or 1.1mm?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 08-09-2013, 09:58 AM   #2577
He said 1.1mm in the first line of his post that you quoted.
cyclonetog is offline   Reply With Quote
Old 08-09-2013, 12:31 PM   #2578
Cadman1981's Avatar
whoops, was still half asleep...
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 08-10-2013, 12:08 PM   #2579
Just pat a bag of bd 7 parts on eBay here is the list if Anyone wants it
Mixes bag of parts for sale from my bd7. I don't want to split if I don't have to. And will post to US but will need to get quote for postage.
Here is a list of what's there
BD-500pw x2
Bd-009bf x3
Bd-009a x1
Bd-s5 x1
Bd-010aw x1
Bd010bw x1
Bd-001 x1
Bd- 189l x2
Zc-206l x2
Bd- 501gg x2
Bd-414b x2
D-046 x1
Sd-414s x1
Zs-011cm x2
Bd-415r x2
Bd-008r1 x2
Bd-008r x1
Bd-008rg x1
Bd-008f x1
Bd-008fg x1
+ a set of double joint drive shafts for front used in 3 runs
Bd-btcs with one ball taken out
Bd-414b with one stud used
Zc-f258 with one screw used
And a pack of servo horns with one missing.
tkd662 is offline   Reply With Quote
Old 08-11-2013, 04:13 AM   #2580
I've actually just fallen in love with the Team Asphalt setup today at the track but hey... I came from a Serpent...So maybe that was it...
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
