Like Tree5Likes
Old 07-26-2013, 04:38 AM   #2506
Cadman1981's Avatar
He guys, what is the stock length of our shocks? I have 5mm lower towers, and i can get 8mm shock towers, i forgot how much shorter shocks i would need. I was planning on trying the new YeahRacing shocks
http://www.rcmart.com/advanced_searc...g-0050&x=0&y=0
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 07-26-2013, 06:41 AM   #2507
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
63mm according to the kit directions
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-26-2013, 11:42 AM   #2508
any word on the BD7 RS?
missouri racer is offline   Reply With Quote
Old 07-26-2013, 12:01 PM   #2509
http://www.teamyokomo.eu/yokomo-euro...K-IN-SEPTEMBER
Smartypants is offline   Reply With Quote
Old 07-26-2013, 01:42 PM   #2510
Trader Rating: 16 (100%+)
Send a message via AIM to DJGonzo69
Buying a BD7 next week. What are the necessary parts/options I should get? Does the kit come with a lower Shock towers or is that an option?
Thx-John
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 07-26-2013, 02:19 PM   #2511
Francis M.'s Avatar
Thx-John
Just buy the black diaphram for the shocks and buy the kyosho
O-ring for the rear diff.
No crazy options needed on this car
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 07-26-2013, 02:39 PM   #2512
Reese Bobby's Avatar
Hi Guys,
I read in one of the articles that Ronald's mechanic found something which gave him an advantage over the opposition at ETS recently. In fact, I think he dedicated the win to his mechanic.
Are you aware of what Ronald was referring to?
VBC Wildfires
Orca - Revolectrix - Sanwa - SMC
Reese Bobby is offline   Reply With Quote
Old 07-26-2013, 02:52 PM   #2513
bukil's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Racing4Evo View Post
Sounds good. I'm going to try it on carpet this weekend. Our carpet is like really picky super sensitive asphalt. Come down and race with us! BD7 s are dominant especially Berger and Mejia's.
Will do. Work got me tied down at the moment. I definitely need to make a trip down there again. I got my @$$ handed to me last time I was there. My car needs a lot of work on carpet.
I honestly think the carpet needs to be replaced. It's way overdue.
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 07-26-2013, 03:25 PM   #2514
There are clubs running on the same CRC rug much longer than the nearly 3 yrs at TQ
But it would be cool if Sean would steam clean it once in a while
Surprisingly, it's not an issue with Sedans
Foam tires however, well ...
Old 07-26-2013, 03:34 PM   #2515
How about those split blocks for the arm mounts?
Are the lower shock towers included or are they an option?
Amain is out of the DCJ's. Any other place in the US to get them?
Thx.
Old 07-26-2013, 04:02 PM   #2516
Hugh Jazz's Avatar
Thx.
There are no lower shock towers available for the car. I believe most people are getting them custom cut.
I use the Tammy DCJ's.
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 07-26-2013, 04:05 PM   #2517
Hugh Jazz's Avatar
Originally Posted by Reese Bobby View Post
Hi Guys,
I think he was referring to tyre prep. The article I read said that they only played around with tyre prep as the car felt good from the start.
Dan Maher
Old 07-26-2013, 04:48 PM   #2518
Team Speedy's Avatar
Trader Rating: 42 (100%+)
I have the following in my pit box:
  • 43.5 split (std) Front
  • 41.3 split (optional) Rear
  • 42.0 split (std) Rear
For the optional parts I purchased, amongst other things:
  • YOKYS-8HD - Black Bladders
  • YOKYS-7HG - Double O-ring setup
  • YOKBD-S2W - Thin P3 O-ring for double o-ring setup
  • 6542 - HPI Blue Spring
  • 6543 - HPI Silver Springs
  • ORG05 - Kyosho O-rings for the gear diff.
  • YOKB7-203 - Floating Servo Mount
  • YOKBD-010FW - Double Cardon Joints
  • Full line of graphite suspension parts, except c-hubs.
I also have titanium turnbuckles and a few odds and ends that are nothing more then eye caddy added. However, the above is what I'd start with again if I had to repurchase this kit at a later time.
Team Speedy is offline   Reply With Quote
Old 07-26-2013, 04:51 PM   #2519
Thx.
My theory:
Team Yokomo drivers occasionally use lower shock towers, when racing with the unusually tall, soft sidewall, spec RIDE tires
There may be other benefits ?
But on normal tires, the car has no traction roll, or grip issues with the current shock towers, which are btw, lower than the previous towers on the BD5
There are several of us in So-Coal running on high grip rug, we all run the BD7 nearly on kit settings
The BD7 is remarkable out of the box, as most current TC's are
The only TC's I've seen T-roll at our track are, HB, Awesomatix, and the new Mi5, and I'm quite sure there is a setup to fix those
Old 07-26-2013, 07:51 PM   #2520
Bill K's Avatar
I have never had my BD-7 running so good on an asphalt surface apart from now. This car is just beautiful to drive, and I'm able to hit every apex, and rotate the car fast enough to make those tricky corners.
I have myself an order coming in from overseas with DCJ's, springs, sway bars, shock oils/bladders and other hop-up options for this car, but I really don't want to altar the setup and ruin it's performance.
This car is the best decision I've ever made, and all I can really do is recommend this car. With the right setup, this car is driving on rails, and although it may take some figuring out to find it, it's worth it in the end!
Bill K is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
