Old 07-23-2013, 07:22 AM   #2491
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by cyclonetog View Post
I'm guessing you mean 290g.
oops, yeah
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-23-2013, 09:01 AM   #2492
This is what i came up with to even the balance. Not shown in pics are two new 2mm shorter outer battery stoppers in 2.5mm cf. Identical otherwise to the originals but shorter. Made the holes 2,7mm so I could set the screws directly in the cf without a nut. It works and it is rock solid.
This moves the lipo 2mm closer to centre.
Pic1. A 1mm thick cf plate witch is 5mm wider than the chassis so electronics can be mounter further out. Only one hole shown in this pic but I made two so both holes in the chassis secures it firmly. Also used the hole in the servo mount so everything is one piece.
Pic 2.
With electronics mounted
pic 3
Shows the 0.5 mm space between chassis and tray. The tray doubles as a battery stopper inwards also.
pic 4
Tray mounted in the car.
The idea is to even the balance and now my ride weighs race ready 1349g with a mazda speed 6 Lw body and the balance is perfect. Got space behind the esc for a motor fan that will make race weight legal.
Another advantage with this is the ease of maintenance in case of a quick chassis swap or some soldering work on the esc. It does not affect chassis flex either.
Your thoughts?
quasimodo is offline   Reply With Quote
Old 07-23-2013, 09:41 AM   #2493
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
thats pretty cool, except you effectively made the chassis thicker by bolting it down in more than one spot and changed the way the car flexes.
Can you just use the one bolt to the servo mount?
Racing4Evo is offline   Reply With Quote
Old 07-23-2013, 09:59 AM   #2494
I dont trust the single bolt in servomount It is only 1mm thick cf. A hard crash could snap that right of so I used two holes. Dont know what they are called in english but the aluminium bushings got some more play (3,25mm inner dia) around the screws and the nut is tighten not all the way on top of those. Not to the cf at all. Look closely at pic 3.
So I understand what you meant but I thought about it in advance. So the tray moves along with the chassis just fine
Thanks for your input!
Old 07-23-2013, 11:50 AM   #2495
if it were me, i'd just use a lighter battery.
DOTMAN is offline   Reply With Quote
Old 07-23-2013, 11:56 AM   #2496
Ha ha, if I knew before I bought the car and lipos I would also go for lighter batteries
Now I can go either way
Old 07-23-2013, 07:43 PM   #2497
Racing4Evo's Avatar
Has anyone tried shortening the front wheelbase on asphalt? What did you notice? I did this and it made the car more stable. Am I missing something or did I do it wrong?
Old 07-23-2013, 11:10 PM   #2498
Volker Setup from Hudy Arena
Old 07-24-2013, 05:01 AM   #2499
Aaron_M's Avatar
I wonder how accurate this is:
The photos that are with the setup sheet show shock positions 4 front / 5 rear, Also the short ball studs are used on bulkheads. If the picture is of the car he was running...
Also standard towers standard length shocks are being used, thought they may have kept the shorter ones.
Yokomo BD7
Aaron_M is offline   Reply With Quote
Old 07-24-2013, 12:18 PM   #2500
Cadman1981's Avatar
http://ets.redrc.net/2013/07/chassis...nald-volker-3/
From these pics, the car looks to have regular shock towers and shocks
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 07-24-2013, 04:51 PM   #2501
bukil's Avatar
Trader Rating: 37 (100%+)
I loose a little of front bite and made the car push a little. I use it more of weight transfer thing than wheelbase. But thats just me.
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 07-24-2013, 07:11 PM   #2502
NolanP's Avatar
Anyone try the Raceberry or interested in the Raceberry options here in the states?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 07-24-2013, 10:27 PM   #2503
Racing4Evo's Avatar
Ok. Thats what I felt too.are you running long or normal wheelbase?
Old 07-25-2013, 06:03 AM   #2504
bukil's Avatar
Front:
Arms are moved forward.
Rear:
Stock shim positioning
Therefore, I have it set to long.
You probably already know this. If you move your arms forward, this changes your ackerman. So adjust accordingly.
☆ ActivRC ☆
Old 07-25-2013, 10:40 PM   #2505
Racing4Evo's Avatar
Sounds good. I'm going to try it on carpet this weekend. Our carpet is like really picky super sensitive asphalt. Come down and race with us! BD7 s are dominant especially Berger and Mejia's.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
