Old 07-19-2013, 01:31 AM   #2476
peter.'s Avatar
Originally Posted by DJ_KILROY View Post
Thanks for that, but I still need a starting point?
What size spur should I start with? 48pitch
87t 48pitch for modified
peter. is offline   Reply With Quote
Old 07-19-2013, 10:50 AM   #2477
Does anyone know the release date for the Bd7 RS? Thinking of waiting to buy this instead of a used car for the same price.
missouri racer is offline   Reply With Quote
Old 07-19-2013, 06:38 PM   #2478
Mr.T3's Avatar
I run 87t xray spur and 21t pinion on my mod car.
B-rad
VBC DO8... Sanwa M12... Hudy... Muchmore Racing... Roche...Volante...
Mr.T3 is offline   Reply With Quote
Old 07-19-2013, 08:06 PM   #2479
DJ_KILROY's Avatar
Thanks Peter,
Off to my local hobby shop to pick one up!
Current racers; Schumacher K1 Aero, X Factory x6 cubed, Yokomo BD5wxi, Yokomo BD 7, Tamiya MO3, Speed Merchant Rev. 6, Team Associated B4, Team Associated T4.
Vintage racers; Team Associated RC 10, RC 10 Classic, Schumacher Cougar 2 Works, Cougar 2 team, Schumacher Storm truck, Hirobo Zerda, Tamiya SRB.
DJ_KILROY is offline   Reply With Quote
Old 07-19-2013, 11:45 PM   #2480
hanzo3's Avatar
Trader Rating: 55 (100%+)
Originally Posted by Racing4Evo View Post
I think 2000wt is the ideal starting point especially if you're at an unfamiliar track. Works 90% of the timefor me. I change the oil to alter the way the car enters the corner and then work my setup around it. Thinner for more aggressive corner entry at the expense of less high speed steering and thicker oil for vice versa. For most outdoor tracks, you can get away with a thinner oil and it won't upset the balance but on carpet, it's very sensitive to viscosity changes.
Spec r 2000 oil? What Kyosho orings work for the diff?
What does the black shock bladders do compared to the stock blue ones?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 07-20-2013, 01:34 AM   #2481
Hugh Jazz's Avatar
You want the P5 orange Kyosho orings
http://www.amainhobbies.com/product_...t-P5-Orange-10
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 07-20-2013, 01:43 AM   #2482
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Associated. Kyosho P5 oring at Speedtech. The Black bladders don't swell up like the stock ones. If your car is loose or inconsistent, your shocks have to be rebuilt. The stock ones are useless after a couple of days. On carpet, these things really show themselves so your car has to be perfect.
Racing4Evo is offline   Reply With Quote
Old 07-21-2013, 01:24 PM   #2483
How long would the black ones last do you think ?
tkd662 is offline   Reply With Quote
Old 07-21-2013, 01:37 PM   #2484
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
A long time
Still on original black bladders
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-22-2013, 08:01 AM   #2485
peter.'s Avatar
you have a picture of the xray spurgear in db7 you have used an xray offset spur
berky155@gmail.com
greetings peter
Old 07-22-2013, 08:59 AM   #2486
Crashmaster's Avatar
Quick one guys, can anyone tell me the internal diameter of shim required when running without the steering brace? Going to buy some but not got the car with me atm!
Thanks for the help with setup guys btw, played with a few bits at the weekend and made some steps (unfortunately ran the best setup after the meeting in a few practice laps!!)
Dan
Crashmaster is offline   Reply With Quote
Old 07-23-2013, 02:14 AM   #2487
Hi!
New owner of a used BD7. Have not driven it yet but i know it is an excellent car.
Anybody else who finds the balance right/left off? I bought heavy Fantom 7200mah and electronics are Orca esc, Hitech 7775, airtronics rx451-r and a Ea killshot motor.
It is much heavier on the battery side and to balance it correctly I have to ad 50grams of led far out on the left side mounted ON the electrics. Then it becomes way to heavy.
Run 17.5 blinky and the weight limit is 1350 here in Europe so I am concerned.
Main question though. Anybody else experienced this?
quasimodo is offline   Reply With Quote
Old 07-23-2013, 07:00 AM   #2488
Originally Posted by quasimodo View Post
Hi!
Try mounting your esc further out on the chassis, you could also space the motor out a bit
BD7 has the motor very close to center compared to other chassis
7200ma is overkill for 17.5 blinky, but with a lightweight body, and ti screws you should be able to get the weight down
fyi
You can get new SMC 5600 packs that weigh only 290g, vs: the 320+g 7200 lipos
Also make sure to mount lipo as close to center as possible
Have fun with the new ride
Old 07-23-2013, 07:43 AM   #2489
@redbullfixx, thanks for the reply. I like do things overkill Look out in a couple of hours. I took it a step further. Going to show with pics
Titanium all around and alu driveshafts in the rear.
And thanks, I will certainly do that!!
Old 07-23-2013, 08:19 AM   #2490
Originally Posted by RedBullFiXX View Post
...fyi
You can get new SMC 5600 packs that weigh only 390g...
I'm guessing you mean 290g.
cyclonetog is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
