Old 07-16-2013, 09:13 PM   #2461
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Racing4Evo View Post
Got some great tips from RedbullFixx over the weekend, particularly how to lube the DCJs.
His DCJs do look brand new. Did some research turns out heli guys use this stuff too. It sprays on liquid and sets as a thin oily film that stays on unlike grease. Kinda like triflow on steroids! Thanks Dave for the pro tip!
This is the stuff:
HHS-K works great, just don't get it anywhere near bearings, as it's a bit thicker than oil once it's application agents dry out
Thoroughly clean DCJ's with motor spray, and give them a spritz of this stuff every few weeks or so, also use it to lube blades, or pins
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-17-2013, 12:23 AM   #2462
Cool BD7 ver.RS won't be long now...
BD7 ver.RS
MRTC-BD7RS ● y21,800 ● $220.00
The experience of running hot high-end touring car in the world first class!
 The person you are running an RC car at most, those who are running a full-scale competition for high-end touring car playing an active part in the big race of the world is only a handful.
BD7 ver.RS released this time is a touring car that specializes in running it was not possible that you plan to be able to enjoy a reasonable budget ran a real RC car to a lot of fans. main chassis which is the cornerstone of running while being reasonably priced, feature of ver.RS kit adopts generously carbon graphite material identical to the original BD7 the upper deck. The front differential spool, also equipped with Geardiff for the rear. Upon upgrade, option parts and BD7 for parts of the originals were built all possible further. ver.RS car is attractive enough even from development of the own.
Main Specifications
■ 4WD belt drive touring car
optimize the twist of the chassis parts in the configuration of symmetrical ■
■ 2.25mm thick graphite main chassis
mounted closer to the center the motor 9.5mm compared to conventional ■
■ front solid axle
rear gear differential ■
■ lightweight plastic belt tension cam
to use the components in common with the high-end machine ■ "BD7", can also update
Old 07-17-2013, 06:36 AM   #2463
EDWARD2003's Avatar
Default Me so close!
Originally Posted by EDWARD2003 View Post
I've come across a few magazine articles in Japanese briefly talking about the RS but no pricing or release dates. Just a few snap shots of Masami holding the prototype version and some close up shots of the plastic components.
I would estimate the release date would be in August or September. Pricing, I would estimate around 20,000 Yen or $230 USD range.
Man I was off by only $10, somebody buy me a lottery ticket.
EDWARD2003 is offline   Reply With Quote
Old 07-17-2013, 06:07 PM   #2464
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
This is the stuff:
i use Spec-R joint lube. it's a thick oil which wont fly off even after you play..
Give the best while u can !
kschu is offline   Reply With Quote
Old 07-17-2013, 07:21 PM   #2465
Cadman1981's Avatar
Originally Posted by Cadman1981 View Post
How does the thick oil in the diff affect the car? Thicker is better for grippy tracks?
in Winter i run on carpet, in the summer we're on ashpalt.
anyone?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 07-17-2013, 08:44 PM   #2466
Francis M.'s Avatar
anyone?
I use 2000 diff oil most of the Time. I go thinner when the car is too stable.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 07-18-2013, 02:13 AM   #2467
DJ_KILROY's Avatar
Default Gearing help
Can anyone offer any advice on gearing for an 8.5 speed passion motor?
I'm planning to run 48 pitch gears. I'm running a BD5wxi on a tight carpet track and I assume that the internal ratio of 2.1 is the same as a BD7.
It would be great if someone could give me a starting point.
Cheers
David
Current racers; Schumacher K1 Aero, X Factory x6 cubed, Yokomo BD5wxi, Yokomo BD 7, Tamiya MO3, Speed Merchant Rev. 6, Team Associated B4, Team Associated T4.
Vintage racers; Team Associated RC 10, RC 10 Classic, Schumacher Cougar 2 Works, Cougar 2 team, Schumacher Storm truck, Hirobo Zerda, Tamiya SRB.
DJ_KILROY is offline   Reply With Quote
Old 07-18-2013, 02:18 AM   #2468
kschu's Avatar
anyone?
i run thicker oil when the track is high traction. Its can reduce traction roll as it reduce the car response.
But even in low traction track, i also run thicker oil. i found it make the car more easier to drive. i ran 5000 - 7000 oil depend on situation.
Old 07-18-2013, 02:18 AM   #2469
kschu's Avatar
Cheers
David
yokomo bd5 and bd7 is 2.0 internal ratio.
Old 07-18-2013, 06:34 AM   #2470
Cadman1981's Avatar
So a basic rule: a thicker oil on a grippy track, and thinner oil on a slippy track? is that correct?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 07-18-2013, 11:46 AM   #2471
Always thicker oil then
cyclonetog is offline   Reply With Quote
Old 07-18-2013, 11:55 AM   #2472
Was kinda waiting on everyone's response here
I've been running 1k, tried 3k on carpet once, but it compromised corner speed
Guess its a tuning tool for feel ?
This is always with 13.5 blinky for the record
Old 07-18-2013, 07:31 PM   #2473
kschu's Avatar
it will be depend on how you want the car to react and layout....i would start with 2k geardiff oil ....try yokomo geardiff oil as it special formulated. It's more consistent than silicon oil...
Old 07-18-2013, 07:41 PM   #2474
DJ_KILROY's Avatar
Thanks for that, but I still need a starting point?
What size spur should I start with? 48pitch
Old 07-18-2013, 10:47 PM   #2475
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I think 2000wt is the ideal starting point especially if you're at an unfamiliar track. Works 90% of the timefor me. I change the oil to alter the way the car enters the corner and then work my setup around it. Thinner for more aggressive corner entry at the expense of less high speed steering and thicker oil for vice versa. For most outdoor tracks, you can get away with a thinner oil and it won't upset the balance but on carpet, it's very sensitive to viscosity changes.
Racing4Evo is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
