Like Tree2Likes
Old 07-02-2013, 02:14 PM   #2386
Francis M.'s Avatar
Originally Posted by cyclonetog View Post
I'm hoping I don't jinx myself here, but I've found my BD7 incredibly tough. I don't make a habit of hitting stuff, but everybody has the odd knock and times I've expected to see a broken wishbone it hasn't happened.
I was worried switching to Yok, but I think it's time the "brokomo" nickname was put to bed.
I remember the old Yokomo's bending CVDs or just wearing out pretty fast.....
This new car has good quality materials and practical design. The old yokomo used to sacrifice some life for weight savings....
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 07-02-2013, 05:43 PM   #2387
EDWARD2003's Avatar
How many of you are running the stock plastic suspension arms,front and rear hubs, and castor blocks for asphalt racing?
I'm not to sure if I should switch out the plastic components for the carbon ones right away.
What do you think?
Also, did any of you drill tiny holes in the shock caps to relieve air pressure on the bladder? I've done this with mine to achieve zero rebound. This is not a new thing, but I was wondering if you guys have done this to your shocks.
EDWARD2003 is offline   Reply With Quote
Old 07-03-2013, 12:31 PM   #2388
jumpnjack's Avatar
What do you think?
we run the plastic here in Hawaii, but make sure you boil them before using them.. and yes we drill them out.
Awesomatix A700L, T.O.P. Rebel 10
Apex RC Pro Shop
ORCA/Pro Spec, Team EA Motorsport, Awesomatix USA, RC America, Team Powers
T.O.P Racing USA, John's BSR Racing Tires, Gravity RC, R1werks, 3Racing, TQ Wire
jumpnjack is offline   Reply With Quote
Old 07-03-2013, 12:48 PM   #2389
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Plastic arms for asphalt racing, have never boiled them though ?
and I always use Graphite steering blocks, as they are more durable than plastic
Carbon arms for indoor/high grip racing
No holes in shock cap, no need
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-03-2013, 02:01 PM   #2390
Ronald and Naoto only ever seem to use the graphite arms, even at the worlds without additive.
cyclonetog is offline   Reply With Quote
Old 07-03-2013, 02:12 PM   #2391
What is the purpose of boiling the plastic arms?
DOTMAN is offline   Reply With Quote
Old 07-04-2013, 01:21 AM   #2392
jumpnjack's Avatar
Conditioning plastic parts
Originally by Plasticar
Adding water to the gears works because the material used to make them is nylon. Nylon absorbs moisture, which makes it more flexible and resistant to impact, both of which help it be less likely to break. A common trade name for nylon used in hobby and sporting goods is Zytel, but there are many other brands also.
It is not recommended to actually BOIL the parts, as the higher heat can degrade the material. Rather the suggestion to bring the water just to a boil, then either pour it into another container, or take off the heat and add the parts to sit is a better one. It doesn't take very long to improve the toughness of the gears (or any other nylon parts). 20-30 minutes should be plenty.
This method will not work with any other types of plastic. Delrin, Lexan, none of these are improved in this method. Fortunately, most of the structural parts in RC cars are nylon.
This process does happen naturally, but takes 6-9 months in open air. Once the moisture has been put into the part, it will continue to adjust the level, but this is a permanent condition, as it is mearly accellerating a natural process.
The nylon gears and other parts will not melt in the boiling water. They don't melt until over 200šC, so unless you have them sitting on the bottom of the pan on high, you are OK. Rather, it is the hot water itself that is the problem. If the water is hot enough for long enough, it will start to break down the plastic itself.
A few mintues on the stovetop should be no problem at all, but you are best as described to remove from heat and let the parts sit in the very hot water that way. That will be more than sufficient to properly condition the parts.
BTW, the majority of the black plastic used in the chassis, drivetrain, suspension pieces is probably nylon and can be conditioned this way if you like. Any of these parts will be harder to break, but will be more flexible. Eventually they will get that way on their own, you are just speeding up the process for your own benefit.
Apex RC Pro Shop
Old 07-04-2013, 07:18 AM   #2393
So you do this to keep from braking parts, or you like more flex, or both
Neither of which are necessary on a BD7 as this chassis inherently has a lot of lateral grip , but it is certainly an option
We used to do this with 12th scale front arms back in the day....
Old 07-04-2013, 08:48 AM   #2394
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I like plastic arms almost everywhere, except on crazy high traction carpet. I keep switching back and forth on carpet and it's hard to tell the difference until the traction is really high or you're racing modified with really fast and harsh weight transfer.
Racing4Evo is offline   Reply With Quote
Old 07-04-2013, 06:02 PM   #2395
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i will go for graphite straightaway....i found it give more response
Give the best while u can !
kschu is offline   Reply With Quote
Old 07-04-2013, 11:43 PM   #2396
Racing4Evo's Avatar
Does anyone else take out 2 screws from the front of the upperdeck for more steering on asphalt?
Old 07-04-2013, 11:54 PM   #2397
bukil's Avatar
Trader Rating: 37 (100%+)
You probably already know this but here goes... I remove this from my car to achieve the steering I want.
Talk about aggressive steering
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 07-05-2013, 12:04 AM   #2398
kschu's Avatar
i remove it to make the front steering response alittle delay when entering corner...and it help a little bit of steering when exit corner..
Old 07-05-2013, 10:53 PM   #2399
Racing4Evo's Avatar
So do you guys like it with or without the screws? I didn't like it. Cant wait to race mod next time on asphalt.
Old 07-06-2013, 02:38 PM   #2400
NolanP's Avatar
Rear CST is 60% 2000 40% 1000.
Stock Wheelbase
Stock Sway Bars
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
