Old 05-01-2013, 09:24 AM   #2101
Originally Posted by kschu View Post
https://www.youtube.com/watch?v=K_7E...qn4lJw&index=9
Been testing 2.0 toe in recently...very satisfy with the feel of it..even im running mod.
the pole position car is mine...manage to secure 6x tq in qualifying and also champ of the race..
Please share your setup
zzztech is offline   Reply With Quote
Old 05-01-2013, 06:58 PM   #2102
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by Mornedn View Post
do you mean 2degrees toe in? If so how did you do that?
i change to Yokomo DRB 2.0 toe block...
Give the best while u can !
kschu is offline   Reply With Quote
Old 05-01-2013, 09:33 PM   #2103
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Yokomo Released a 2.0 rear block for the BD7 It also allows you to get 2.5d rear toe with the 41.3 Rf mount but a narrower rear end.
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 05-02-2013, 12:35 AM   #2104
jumpnjack's Avatar
Originally Posted by Racing4Evo View Post
http://www.tqrcracing.com/shop/produ....asp?p_id=4443
screw needs to be countersunk flat head. This will work in a pinch, my only reservations are that its aluminum. Just be more careful with this than the stock screw.
i agree aluminium will shear.
Awesomatix A700L, T.O.P. Rebel 10
Apex RC Pro Shop
ORCA/Pro Spec, Team EA Motorsport, Awesomatix USA, RC America, Team Powers
T.O.P Racing USA, John's BSR Racing Tires, Gravity RC, R1werks, 3Racing, TQ Wire
jumpnjack is offline   Reply With Quote
Old 05-03-2013, 03:53 AM   #2105
peter.'s Avatar
I have a sp Competition MMM Series 13.5R and if I drive with blinky 20grade timing can I also just to keep 4.0 or higher
peter. is offline   Reply With Quote
Old 05-03-2013, 05:57 AM   #2106
Robert_K's Avatar
Peter,
I think at the MRM circuit 4.0 gearratio is way to heavy with the 20deg board inside. start at 5.5 gearratio at this twisty circuit, and then go down in gearration sowly. Measure you motor temperature after a few minuts till it's start to get hot (above 70degC).
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 05-03-2013, 07:37 AM   #2107
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by Robert_K View Post
Peter,
Regards Robert
4.5 fdr
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 05-04-2013, 12:27 PM   #2108
bukil's Avatar
Trader Rating: 37 (100%+)
Does anyone know what 2 o-rings meant on some of the setup sheets? Are they used as a limiter or do you just put 2 them all in the lower shock cap and leave the lower plastic piece out?
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 05-04-2013, 01:10 PM   #2109
There is a thinner plastic spacer available so you can use 2 O-rings in the bottom of the shock. The thin spacer part number is YOKBD-S2W.
HawaiiBob is offline   Reply With Quote
Old 05-04-2013, 01:10 PM   #2110
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Yeah you put them in the bottom but you use a different plastic peice that is thinner.
Racing4Evo is offline   Reply With Quote
Old 05-04-2013, 02:05 PM   #2111
so the next question would be...what does 2 give you over one?
DOTMAN is offline   Reply With Quote
Old 05-04-2013, 02:16 PM   #2112
Racing4Evo's Avatar
A better seal for one and more stable cornering. For me the car is already stable so I like the one o-ring at least on the tracks I'm running on (med-high bite).
Maybe i'll use 2 orings at Tamiya if the traction is really bad but I doubt it.
Old 05-04-2013, 11:30 PM   #2113
Francis M.'s Avatar
Bought a used BD7 and it only took one pack to confirm that it was a good decision! thanks to Racing4evo who helped me to get the car up and running....
TQ-racing Yokomo BD7 Airtronics
Francis M. is online now   Reply With Quote
Old 05-05-2013, 08:33 PM   #2114
hanzo3's Avatar
Trader Rating: 55 (100%+)
Nice driving today Francis.
I lost a belt tension spring cam ball. What size are those balls?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 05-05-2013, 09:42 PM   #2115
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Anyones want to share their set up for out door racing ...17.5 or mod Thanks
OVA is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
