Old 04-28-2013, 10:18 PM   #2086
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by hanzo3 View Post
Where can I get m2.5x8 screws for the spur gear? Love the car. Can't wait to run it for the summer.
Will this work ?
http://www.amainhobbies.com/product_...n-Head-Screw-6
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-29-2013, 12:33 AM   #2087
No they need to be countersunk, I got a pack of 10 off ebay.
cyclonetog is offline   Reply With Quote
Old 04-29-2013, 01:50 AM   #2088
jumpnjack's Avatar
Originally Posted by RedBullFiXX View Post
no they will not work, to long and you need a M3 screw and a short head or the entire gear will be widened and cause drag.
use these
http://www.amainhobbies.com/product_...Head-Screws-10
Awesomatix A700L, T.O.P. Rebel 10
Apex RC Pro Shop
ORCA/Pro Spec, Team EA Motorsport, Awesomatix USA, RC America, Team Powers
T.O.P Racing USA, John's BSR Racing Tires, Gravity RC, R1werks, 3Racing, TQ Wire
jumpnjack is offline   Reply With Quote
Old 04-29-2013, 04:53 AM   #2089
Here's my take on that
More chassis roll on carpet is easier to drive, especially on a high grip track
Perhaps on large, high speed, outdoor circuits, less roll is advantageous for more stability ?
Hey man , thankx for the input.
I can complete follow you , but isnt so that more roll give more traction because the car can more lean ?
I case of stability you got your point , but how about lateral traction :-).
After alot off reading and testing i finally got the theory and working of rollcenters; (i thought so hehehe)
But then when i look to basic setup of the bd7 (lovely car btw) i think i dont get it complete :-)
Asso B5M
Sanwa M11X
Team Orion
Kevin E. is offline   Reply With Quote
Old 04-29-2013, 07:56 AM   #2090
use these
Thanks Jack
I'll pick up a few of those too
Well I've only had the car out a few times so far, on hi grip carpet, a soft rolling setup makes this car super easy to drive on our 90x45 rug, powered by a 13.5
Will hit the asphalt in a few weeks to see how she goes there
And yes, she is quite lovely
Old 04-29-2013, 08:44 PM   #2091
mikeygar's Avatar
Trader Rating: 14 (100%+)
From teamyokomo.com, new go faster parts!
■B7-S6AC:Aeration Shock Cap 980 JPY
These shock caps provide improved initial bump reaction, and may be well suited for bumpier tracks.
Adjusting the amount of oil and air allows the amount of rebound to be adjusted as well.
■B7-413W2:Front hub carrier (2 degree caster) 580 JPY
Compared to the kit standard 4 degree front hub carrier, the 2 degree version will provide better initial steering response. Although suited for tight track layouts with many corners, in high-grip conditions where traction rolling is an issue, the increased understeer upon corner exit may help prevent traction rolling from occurring.
■B7-413W6:Front hub carrier (6 degree caster) 580 JPY
Milder steering response than the kit standard front hub carrier, the 6 degree front hub carrier provides improved steering during corner exit, helping to reduce understeer. Very effective on high speed corners.
■B7-SS05:Suspension mount spacer (0.5mm, for 1 car) 1,280 JPY (Available late April-early May)
■B7-SS08:Suspension mount spacer (0.8mm, for 1 car) 1,280 JPY (Available late April-early May)
■B7-SS10:Suspension mount spacer (1.0mm, for 1 car) 1,280 JPY (Available late April-early May)
Convenient design allows the suspension mounts to be raised quickly, as neither the suspension mount nor screws need to be removed.td>
■B7-003H:High traction upper deck 1,800 JPY (Available May 2013)
Compared to the kit standard 2.0mm thick upper deck, this thinner version will help improve overall grip on low grip surfaces. However this upper deck can also be used to optimize chassis stiffness where speeds are regulated as in stock class racing, and even in high grip conditions.
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 04-30-2013, 12:36 AM   #2092
hanzo3's Avatar
Trader Rating: 55 (100%+)
Yokomo Main Gear Shaft
[YOKB7-644]
Amain is running low on parts. Where can I get a main gear shaft? Is there an alternative part I can use?.
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 04-30-2013, 01:42 AM   #2093
[YOKB7-644]
Rc Mushroom
RC Market
Chubbies RC
Old 04-30-2013, 04:26 AM   #2094
Are these Aeration Shock Cap helping to get your shaft easy to 0 rebound ?
Asso B5M
Sanwa M11X
Team Orion
Old 04-30-2013, 07:56 AM   #2095
http://www.teamyokomo.com/teamyokomo..._option_e.html
Old 04-30-2013, 10:19 AM   #2096
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
i only have B7-644T in stock but not on website so plz msg me if required
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 05-01-2013, 02:11 AM   #2097
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
http://www.tqrcracing.com/shop/produ....asp?p_id=4443
screw needs to be countersunk flat head. This will work in a pinch, my only reservations are that its aluminum. Just be more careful with this than the stock screw.
Racing4Evo is offline   Reply With Quote
Old 05-01-2013, 05:25 AM   #2098
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
https://www.youtube.com/watch?v=K_7E...qn4lJw&index=9
Been testing 2.0 toe in recently...very satisfy with the feel of it..even im running mod.
the pole position car is mine...manage to secure 6x tq in qualifying and also champ of the race..
Give the best while u can !
kschu is offline   Reply With Quote
Old 05-01-2013, 05:38 AM   #2099
caltek1's Avatar
Trader Rating: 33 (100%+)
Great work KsChu. Your car looks way planted on the track.
I am running the same rear toe, but only running 13.5 blinky on asphalt track here in Sydney.
Keep up the good work.
Regards,
Calvin
caltek1 is offline   Reply With Quote
Old 05-01-2013, 05:45 AM   #2100
do you mean 2degrees toe in? If so how did you do that?
Mornedn is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
