Old 04-22-2013, 08:36 PM   #2056
bukil's Avatar
Trader Rating: 37 (100%+)
I'm looking to buy toe blocks for more tuning options. Does anybody recommend certain ones over the others?
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 04-22-2013, 08:58 PM   #2057
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
The car is great box stock. There's only 2 blocks you'll maybe want for tuning one for the front and one for the rear. This should cover all the bases.
44.2mm Front-Front
45.7mm Rear-Rear
Racing4Evo is offline   Reply With Quote
Old 04-22-2013, 09:15 PM   #2058
bukil's Avatar
44.2mm Front-Front
45.7mm Rear-Rear
Thanks.
I'm not geometrically inclined but how is changing the arms to a different length differ from making the hinge pins closer/further away using the toe blocks? It seems to me like its a redundant tuning option. I could be wrong.
What I'm trying to achieve here is to be able to make my front/rear narrower or wider when I want to without overly getting unnecessary parts.
☆ ActivRC ☆
Old 04-22-2013, 09:31 PM   #2059
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thanks.
Different off-set wheels, hubs, arms, mounts..
So many options to choose from
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-22-2013, 11:03 PM   #2060
bukil's Avatar
Thanks Dave.
Shims and wheel hubs are good too since they don't change your shock angle positioning like what the option arms and mounts do.
☆ ActivRC ☆
Old 04-22-2013, 11:12 PM   #2061
The option arms are the same length, they just alter the bottom shock mounting positions so do not affect the overall width.
cyclonetog is offline   Reply With Quote
Old 04-22-2013, 11:14 PM   #2062
bukil's Avatar
Aha! Thanks for clearing that up. Bear with me as this is my first Yokomo car.
☆ ActivRC ☆
Old 04-23-2013, 12:29 AM   #2063
No problem. Also my first so I knew exactly what you were thinking
Old 04-23-2013, 04:45 AM   #2064
Thanks Dave.
Isnt adding shims to a wheel hub completely different in terms of tuning to widening at the pivot block tho? especially on the front of the car as you are changing king pin angles when turning etc...
Smartypants is offline   Reply With Quote
Old 04-23-2013, 08:02 AM   #2065
theatriks's Avatar
Hey guys anybody get this car on asphalt yet?....my asphalt season starts in 2 weeks just wondering what settings are working for you guys.....im probably gonna run it in 17.5 blinky.....
theatriks is offline   Reply With Quote
Old 04-23-2013, 07:25 PM   #2066
Racing4Evo's Avatar
Try Meen V. Setup from RC Addict. Great starting point and just tweak ackerman and front camber link shimming to your liking. If you really think about it, his setup is just little tweaks to the box stock setup which is a testament to how inherently easy and dialed the car is.
Old 04-23-2013, 11:27 PM   #2067
caltek1's Avatar
Trader Rating: 33 (100%+)
I use the following on asphalt , which is what I used at TITC in feb this year, except rear toe. Shocks yokomo blue front and rear 350 wt oil, three hole piston. 3.5 toe blocks front front and front rear. On the rear I am using the kit toe blocks. ( For TITC I used the 4.2 block on the rear front and 5.7 rear rear, gives 1 degree of rear toe). This was running 13.5 blinky using the fixed HW BL motor and Justock ESC.
The rest of my setup was the same as meens TITC setup. Since returning home I have only changed the rear toe blocks to those listed above , occassionally changing the rear rear back to 5.7 from the 6.4 block.
I also changed the motor to a D3.5 Trinity 13.5 and am now still experimenting with gearing for our tracks.
Later,
Calvin
caltek1 is offline   Reply With Quote
Old 04-23-2013, 11:36 PM   #2068
bukil's Avatar
Yes
Not sure if its the angle. A very good mechanic once explained this to me. I don't remember now . I'll ask him.
Answers are in red.
☆ ActivRC ☆
Old 04-25-2013, 01:18 AM   #2069
Default Building my yokomo BD7
Building my yokomo BD7 (youtube)
Logoedu is offline   Reply With Quote
Old 04-25-2013, 10:51 AM   #2070
cyclone's Avatar
Hi guys, which servo horn is everyone using ( which length) And does anybody know what the length of the yokomo aluminium ones are?
Also has anybody added an extra shim underneath the top deck for the central, middle top deck screw, there seems to be a gap between the motor mount part and the top deck..
cyclone is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
