Like Tree5Likes
Old 03-15-2013, 05:24 PM   #1921
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by tkd662 View Post
I've had it up to eyeballs fixing the yokomo dcjs, can one of you please help me find some spec r ones or some others that fit as I'm coming up blank in uk.
http://www.chubbiescarshack.co.uk/in...product_id=211
will be back in stock on friday
plus i have yokomo dcj replacement pins in but not on website
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 03-15-2013, 05:27 PM   #1922
Craig W's Avatar
Originally Posted by Cadman1981 View Post
Speaking from experience, the car is solid. I have had some serious hits and accident in my 17.5 blinky class, and only so far broke a rear hub because i was hit at full speed.
Your best bet to make it bullet proof is to get the larger bumper
Yokomo Wide Bumper (BD-001W)
you could go stock car racing with that use as nudge bar
Old 03-16-2013, 01:39 AM   #1923
Hello guys.
I try to find out correct spring rates chart with yokomo spring measurement. A have found just old messages about old style of color spring, like this:
Yokomo (Pro shock spring long type with color marking at the bottom)
Black - 258 gF/mm
Blue - 264 gF/mm
Yellow - 280 gF/mm
Pink - 290 gF/mm
Green - 303 gF/mm
Orange - 330 gF/mm
But somebody says that chart is too old color and somebody have another, modern.
I try to use spring from TOP, Yokomo, RC-ride for best result.
Could you be so kind and tell me, do you have correct spring rates with color and gF/mm.
Thank you and sorry for my english..
Hello from forum about BD7 in Russia, Moscow
ant101 is offline   Reply With Quote
Old 03-16-2013, 02:17 AM   #1924
Thanks mate I've sent you contact in your website
tkd662 is offline   Reply With Quote
Old 03-16-2013, 05:16 AM   #1925
Cadman1981's Avatar
Hey Guys, i was thinking of modifying my shocks to make them shorter. Right now i have about 4mm of spacing for ride height.
I have some spare shock shafts from Tamiya which are about the same (haven't measured yet), so i was going to cut about 2 mm from them, and re-tap the tread on them. and voila, shorter shocks.
Ideas, comments?
Cadman1981 is offline   Reply With Quote
Old 03-16-2013, 09:31 AM   #1926
About to purchase one of these.
Is there anything out of the box that requires upgrading, Tuning options, spares etc
Car will br mainly used outdoors. Cheers
Mi4cxl is offline   Reply With Quote
Old 03-16-2013, 09:42 AM   #1927
Craig W's Avatar
44.2mm front brace dcjs
graphite arm if you want to run them
http://www.chubbiescarshack.co.uk/in...product_id=133
kit back in stock on friday with dcjs
Old 03-16-2013, 09:47 AM   #1928
Craig W's Avatar
has any 1 got part number for kyosho o ring that fits the gear diff please to make seal
Old 03-16-2013, 09:48 AM   #1929
Hi Craig. Nick from Marstons :-D Kirks mate....
After seeing how smooth & easy to drive Jamies was I mailed mb as I saw he wanted drivers to promote he brand over here. Hope I'll get a mail back soon :-D
Shall have to come up stafford & chase Jamie round for a bit!
Old 03-16-2013, 10:08 AM   #1930
You also said my car looked good Nick
cyclonetog is offline   Reply With Quote
Old 03-16-2013, 10:14 AM   #1931
Ideas, comments?
You'll want a lower shock tower and shorter bodies. Otherwise all you're going to do is limit the amount of droop you can run (possibly ride height too).
Also the Yok pistons don't fit the Tamiya shaft, although Tamiya or HB pistons will fit in the Yok shock body. I'd rather run the Yok piston because the team are getting on "ok" with them.
Old 03-16-2013, 10:15 AM   #1932
Well you could be anybody. I'm complimentary about everything ;-)
Old 03-16-2013, 10:16 AM   #1933
Yes I could, but I'm Merv (tends to narrow it down a bit)
Old 03-16-2013, 10:27 AM   #1934
Craig W's Avatar
sent u a fb msg
Old 03-16-2013, 10:45 AM   #1935
Ah Merv hi :-)
Replied Craig.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
