Like Tree6Likes
Old 03-11-2013, 10:44 PM   #1891
http://www.petitrc.com/reglages/yoko...YokomoBD7.html
Top of page
Originally Posted by AMorgan View Post
Does anyone know where I can download or purchase an English manual? My kit came with a Japanese manual. I can build it with the kit manual but having the extra notes would really help.
zzztech is offline   Reply With Quote
Old 03-11-2013, 11:33 PM   #1892
Bill K's Avatar
Originally Posted by Cadman1981 View Post
how do you check your weigh transfer? I had to add 70grams to my car so it's at 1400g, i tried to get the car as balanced front to back, and side to side as possible.
Its hard to explain, but prime your car on the bench and measure its uptravel from the rear and front... do you know what i mean?
If the rear sits at 5.5 deg ride hight, lift the car until the wheels just sit on the bench. Firstly your camber links should be straight.. not up or down. if they are either way ajust your droop so that sit flat when you lift the rear end.
After doing this, hold the car in this possition and measure its rear right height again. this should tell you your uptravel, and how far the rear end lifts (weight transfer) when brakes are applied or entering a corner.
hope you understand what i mean.
Bill K is offline   Reply With Quote
Old 03-12-2013, 03:28 AM   #1893
thank's to all.
I'll try next week.
Another question, just for information, when i see 1° front toe-in, is it 1° per side, or total ?
And last one, whats the difference on the track, between 1° camber or 2° camber?
Regards,
Team Awesomatix / Team Roche / Team Corally / Wild Turbo Fan
nicoo2k4 is offline   Reply With Quote
Old 03-12-2013, 03:35 AM   #1894
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by nicoo2k4 View Post
thank's to all.
I'll try next week.
Regards,
front normally is toe out...it'll be 1deg each side..
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-12-2013, 10:30 AM   #1895
Sorry Bill, but there's a fair bit of nonsense in there!
cyclonetog is offline   Reply With Quote
Old 03-12-2013, 11:05 PM   #1896
Bill K's Avatar
[1]up travel is another way to say droop. Its the travel "up" when lifting the suspension before the wheels leave the ground. so 2mm of up travel in the rear means that if your ride height is set at 5mm then when lifting the rear dead center(usually with an exacto knife) both wheels should leave the ground at 7mm. 7mm-5mm = 2mm of up travel. This method is also used as a quick droop adjustment method. If one tire lifts up before the other, most likely your droop is off, or you are tweaked or possibly shock lengths are different. More than likely though your droop is off.
[1] up travel
This should help explain... I hope
Old 03-13-2013, 07:11 AM   #1897
peter.'s Avatar
what is the standard caster angle 4 or 6
peter. is offline   Reply With Quote
Old 03-13-2013, 07:14 AM   #1898
4 degrees. There are no 6 degree caster blocks available yet.
Team Yokomo | LRP | Spec-R | MPE Stickers
quick-nik is offline   Reply With Quote
Old 03-13-2013, 10:13 AM   #1899
Since the manual ZZZTech posted is the only one I've seen, I'm guessing an english version of the manual is not available online. I've checked with AMain and they can't get me a manual at all, English or Japanese. I would be more than willing to buy a manual in English. Does anyone know a vendor that would have English manuals to sell?
AMorgan is offline   Reply With Quote
Old 03-13-2013, 12:38 PM   #1900
…bunch of words...
I know what droop and up travel are thanks.
You said you were checking weight transfer, you aren't.
Also you said make sure the camber links are level, not pointing up or down. Doing so would supersede setting droop or up travel and is, well, pointless.
Feel free not to point out anything else you think I don't understand.
Old 03-13-2013, 04:24 PM   #1901
pmc
Hello
They are available in the Team yokomo Europe.
http://www.teamyokomo.eu/yokomo-euro...rrier-6-degree
Best regards:
Pedro Silva
pmc is offline   Reply With Quote
Old 03-13-2013, 05:07 PM   #1902
That's a typo.
Have a look at the very bottom of this page.
http://www.petitrc.com/reglages/yoko...hubsExplained/
Old 03-13-2013, 05:15 PM   #1903
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by pmc View Post
Hello
Best regards:
Pedro Silva
they are 4 degree
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 03-13-2013, 09:07 PM   #1904
Cadman1981's Avatar
There are new parts for Tamiya's TRF417, when i saw them, i thought it was interesting... have a look
Cadman1981 is offline   Reply With Quote
Old 03-13-2013, 10:54 PM   #1905
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
This has been discussed several times and it looks like there is still a lot of confusion about the caster angle of the kit c hubs.....
Stock is 6 degrees.
You can look at all the baseline starting setups on petit rc and you will see that all indicate 6 deg c hubs because that's what comes with the car.
Stock is 6 degrees.
Stock is 6 degrees.
Stock is 6 degrees.
Racing4Evo is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
