Like Tree5Likes
Old 03-06-2013, 11:50 AM   #1861
Originally Posted by cyclonetog View Post
After watching the videos, I'm interested to know if Yannic had the prototype parts fitted or not, his car definitely looked better than Ronald's.
Almost all Yokomo factory drivers did run the prototype shock towers and shocks at Gran Canaria, so obviously Prümper, too. Which doesn't mean that both cars didn't differ setup and additive wise...
Team Yokomo | LRP | Spec-R | MPE Stickers
quick-nik is offline   Reply With Quote
Old 03-06-2013, 06:00 PM   #1862
Cadman1981's Avatar
Originally Posted by caltek1 View Post
Here are some pictures of my BD7 fitted with custom made 6mm lower front and rear shock towers made from 3.5mm gloss CF. These were made by Bezerk RC who has a FB page.
I have fitted the new Serpent short shocks which are made 6mm shorter and allow normal springs to be used. The car originally had yokomo pink up front and yokomo blue rear. I ended up at TITC with blue front and rear. These were given out freely by Team Yokomo to all yokomo drivers, as well as a BD7 decal sheet and a free Yokomo T shirt.
I also had a pair of 8mm lower shocks made today which I have included in the first picture. Others are of the 6mm lowered towers.
Hopefully the new 8mm lower towers will arrive tomorrow and I will test with the T Shox this weekend. I was fortunate enough for Andreas, from T shox to be at TITC and he built the shocks for me with enlarged 1.3mm holes in the pistons and short firm rebound springs fitted. Must say they feel very smooth. the proof will be on the track.I did not use at TITC as I did not have the correct size lower towers to fit these too.
Later,
Calvin
Hey Calvin, are you willing to sell your 6mm lower shock towers?? They look really nice! Where can we get a set, and how much?? PM me please!
Cadman1981 is offline   Reply With Quote
Old 03-06-2013, 06:05 PM   #1863
Cadman1981's Avatar
Later,
Calvin
how did the car handle differently with this setup?
Old 03-06-2013, 10:00 PM   #1864
Bill K's Avatar
might this fit the BD7 instead of the optional battery hooks you can buy? this would eliminate that aweful tape too.. and add some bling!
http://www.exotekracing.com/lipo-bat...w-alloy-posts/
Bill K is offline   Reply With Quote
Old 03-06-2013, 11:51 PM   #1865
caltek1's Avatar
Trader Rating: 35 (100%+)
In response to a PM.
The yellow is the original front and rear shock towers. The green is the 8mm lower shock towers and are what are in my first picture on the previous page.
So yes you need to run shorter shocks. That is why I have chosen the T4 T Shox with X ray ends.
Later,
Calvin.
caltek1 is offline   Reply With Quote
Old 03-07-2013, 12:51 AM   #1866
It might, but it's probably a bad idea.
cyclonetog is offline   Reply With Quote
Old 03-07-2013, 04:29 AM   #1867
pmc
Hello
Anyone have tried this optionals from Roche ??
Roche BD7 upper deck 2.0mm
Roche BD7 Main chassis 2.0mm
Thanks in advance.
Best regards:
Pedro Silva
pmc is offline   Reply With Quote
Old 03-07-2013, 06:42 AM   #1868
Cadman1981's Avatar
Here's a clearer pic Calvin
Old 03-07-2013, 08:06 AM   #1869
Thumbs up
Nice!
zzztech is offline   Reply With Quote
Old 03-07-2013, 08:06 AM   #1870
Cadman1981's Avatar
Which other cars use shorter shocks?
We know:
- the T4 has 8mm shorter shocks - Part XRA308307-O - Pack of 2
- CSO T4 shocks (black or orange) - Part - XT-4078K (come in a pack of 4) http://www.cso.com.hk/htdocs/modules...ex.php?nsn=276
- Serpent 411 Eryx - 6mm shorter - Part: RCM-SS (2) (#160124) - Pack of 2
- The T-shox for T4 - Pack of 4
- 3Racing 50mm Aluminium Oil Damper Set For 3racing Sakura Zero #SAK-48/PK - http://www.rcmart.com/3racing-50mm-a...?cPath=389_390
Also, with these shocks, you will need new springs.
Old 03-07-2013, 07:50 PM   #1871
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
it's will be good if the short shock can run normal spring...otherwise u will be tight to only their spring like t4,sakura and tshox..
yokomo short shock can use hpi/ride, yokomo spring, xray t3 spring and other long spring...
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-07-2013, 08:44 PM   #1872
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I agree! I think the best solution is what Serpent is doing by lowering and shortening everything just enough so that regular springs will work.
That's typical Xray philosophy to sell you more sh!t you already have by making T4 specific springs. I kinda can't fault them because on half of their "innovations", they really are the ones pushing development that other manufactures are too lazy to do when they are not threatened in the market.(i.e. Tamiya in recent years).
But, to me it looks like Yokomo is going the Serpent route cause those look like stock Yokomo springs on Volker's car. It looks like the only thing done was less preload on the top shock collar to get the same ride height.
Racing4Evo is offline   Reply With Quote
Old 03-08-2013, 02:25 AM   #1873
caltek1's Avatar
With the new serpent short shocks, there is no requirement for new springs as they only shortened the top and bottom mounting parts and left the shock body normal length, so all standard springs fit.
For the x ray, you need there new short springs or use the T shox springs which are shorter than standard springs being 22mm and 24mm in length.
Later,
Calvin.
Old 03-08-2013, 10:32 AM   #1874
Trader Rating: 43 (100%+)
so when are the short shock towers and shocks going to be released.
aceinthesky is offline   Reply With Quote
Old 03-08-2013, 10:53 AM   #1875
When? We haven't got past "if" yet.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
