Like Tree2Likes
Old 03-04-2013, 02:50 PM   #1846
Exactly, and with the grip levels most of us race in, it makes you wonder if Yok will ever market those prototype parts.
cyclonetog is offline   Reply With Quote
Old 03-04-2013, 03:40 PM   #1847
fpart's Avatar
Trader Rating: 39 (100%+)
Send a message via Skype™ to fpart
i think for carpet they may be needed though.
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 03-04-2013, 05:00 PM   #1848
Francis M.'s Avatar
I agree, I think all these updated lowered and smaller shocks will show it's advantage in high bite indoor tracks. Or maybe they need to refine the set up with the new components.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 03-04-2013, 08:16 PM   #1849
Cadman1981's Avatar
The X-ray T4 proves we can have shorter shocks, with larger bodies that will have similar qualities to the 'regular' shocks.
I'm looking at getting the T4 shocks, and modifing some shock towers to lower everything on my car. It's extremely simple to do too!
Cadman1981 is offline   Reply With Quote
Old 03-04-2013, 08:46 PM   #1850
NolanP's Avatar
That's 8mm shorter. If you use Serpent shocks that's 6mm and you don't have to buy new springs........Not that I'm trying to work on this.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 03-04-2013, 10:58 PM   #1851
Mr. MR4's Avatar
Going to do the same thing here. CSO make all black xray t4 shocks. Orange shocks wont look nice on the bd7!
Ride m chassis springs (21mm height) should also fit these shocks.
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 03-05-2013, 02:58 AM   #1852
caltek1's Avatar
Trader Rating: 34 (100%+)
I have already had 6mm lower front and rear shock towers made for my BD7 and using the new Serpent short shocks which are 6mm shorter than standard. These shocks let you use normal Yokomo, ride, HPI, tamiya springs.
If you get the shock towers made 8mm lower, then you will be able to use the T4 shocks or the T Shox designed for the T4 car.
That is my next tower modification to try. Goiod thing with the BD 7 is there is no problems with the rear links hitting on the body mounts when lowering the towers I will test using theT4 T Shox with the T shox carpet springs.
later,
Calvin.
caltek1 is offline   Reply With Quote
Old 03-05-2013, 08:57 AM   #1853
scoyle's Avatar
I have done a bit of a build review for anyone who is thinking about buying a BD7... you can see it here; http://www.rcracingni.co.uk/?p=73925
Any comments or corrections appreciated.
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 03-05-2013, 11:46 AM   #1854
Nice write-up.
"The part of an illustration is put into a pulley"
-Mike
Old 03-05-2013, 11:55 AM   #1855
scoyle's Avatar
Originally Posted by grippgoat View Post
Nice write-up.
-Mike
Took a while to realise you were talking about the picture from the additional manual sheet...
Only beaten by the line "The overflowing oil is politely wiped off!" when talking about filling the gear diff.
In saying that the manual very clear pictures and I had zero problems following it and building the kit.
Old 03-05-2013, 12:11 PM   #1856
Can't beat a bit of Japlish, although some Chinglish can be quite entertaining
Old 03-05-2013, 02:31 PM   #1857
Originally Posted by NolanP View Post
Yeah I know Reinhard was talking about there being almost like a sandstorm on the track. I have a feeling that the lowered shock towers are the reason that there was an issue for Volker
It is the diff oil thickness couse to the lower temps give troubles
at the start of the race, after 3 or 4 laps the problem was gone.
eded1 is offline   Reply With Quote
Old 03-05-2013, 05:00 PM   #1858
Cadman1981's Avatar
Does anyone have pictures of their lower shock towers? Do share!
Old 03-06-2013, 01:38 AM   #1859
caltek1's Avatar
Default MY BD7
Here are some pictures of my BD7 fitted with custom made 6mm lower front and rear shock towers made from 3.5mm gloss CF. These were made by Bezerk RC who has a FB page.
I have fitted the new Serpent short shocks which are made 6mm shorter and allow normal springs to be used. The car originally had yokomo pink up front and yokomo blue rear. I ended up at TITC with blue front and rear. These were given out freely by Team Yokomo to all yokomo drivers, as well as a BD7 decal sheet and a free Yokomo T shirt.
I also had a pair of 8mm lower shocks made today which I have included in the first picture. Others are of the 6mm lowered towers.
Hopefully the new 8mm lower towers will arrive tomorrow and I will test with the T Shox this weekend. I was fortunate enough for Andreas, from T shox to be at TITC and he built the shocks for me with enlarged 1.3mm holes in the pistons and short firm rebound springs fitted. Must say they feel very smooth. the proof will be on the track.I did not use at TITC as I did not have the correct size lower towers to fit these too.
Later,
Calvin
YOKOMO Touring Car BD-7-482284_426064790817801_1255478680_n.jpg   YOKOMO Touring Car BD-7-579650_330511870382478_308176009_n.jpg   YOKOMO Touring Car BD-7-64579_330511917049140_1435010274_n.jpg   YOKOMO Touring Car BD-7-11346_330512737049058_980048155_n.jpg   YOKOMO Touring Car BD-7-734795_329770133789985_1918074436_n.jpg
Old 03-06-2013, 04:14 AM   #1860
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
thats right. in the second main there was high winds approx up to 90kmh gust and lots of sand. conditions throughout the event were difficult as they sprayed sugarwater on the track for more grip but due to the high humidity there thats always there, it made for very slippery conditions in general in addition to the sandstorm on sunday.
Yokomo BD7 -- Hobbywing v3 -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
