Like Tree2Likes
Old 02-21-2013, 08:27 AM   #1786
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by vitomon View Post
any of you run 17.5T motors and use a gear ratio of 1:4,0 ?? wandering how to get there. which pinions and spurs do u use that fit. i found out that the gearchart provided in the kit is not 100% true
96 48 should give u 4 fdr
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 02-21-2013, 08:44 AM   #1787
swimbikerun's Avatar
Trader Rating: 100 (100%+)
A 96/48 works fine for a 4.0 FDR. With a 96 spur you can go down to a 3.84 FDR (50t pinion) due to the clearance of the pinion and the motor mount.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 02-21-2013, 09:51 AM   #1788
Cadman1981's Avatar
Originally Posted by grippgoat View Post
http://www.tqrcracing.com/shop/produ....asp?p_id=2790
Says in stock when I add to my cart.
-Mike
Thanks Mike!
Cadman1981 is offline   Reply With Quote
Old 02-21-2013, 09:58 AM   #1789
Cadman1981's Avatar
Excellent! i ordered a set! I'll keep you guys posted on their quality!
Old 02-21-2013, 01:02 PM   #1790
I run them in my Schui, and I've been pretty satisfied (never run other DCJs, though, since they're not available). They have a fair amount of play (at least after as long as I've used them). But they're smooth, and seem pretty maintenance free. I finally got one to pop apart running 10.5 boosted in Hong Kong and hitting a few things and doing a lot of curb jumping. The pin worked its way out of the barrel. But nothing was lost, and I was able to reassemble it with the other set of holes on the barrel, and it held fine. I did have to tighten up the ring a bit with pliers, but no biggie.
One thing to note: Before you put them in the car, you'll want to change the direction of the pin retaining rings on one side of the car (don't remember which side). You'll want them oriented so that when the car is going forward, if the ring were to touch the inside of the steering knuckle, it wouldn't catch the straight end of the ring and pop the ring off.
Code:
---->  Direction of rotation
--Ž Ring
  O  Barrel / Axle
Hope that helps.
-Mike
Old 02-21-2013, 04:09 PM   #1791
Never had an issue with the clip getting caught on a chub. The bd7 chubs have clearance enough.
HawaiiBob is offline   Reply With Quote
Old 02-21-2013, 04:28 PM   #1792
I did that 15 pages back, I'd be interested to see if you find the same as me.
YOKOMO Touring Car BD-7
cyclonetog is offline   Reply With Quote
Old 02-21-2013, 06:55 PM   #1793
Cadman1981's Avatar
I remember reading that, i have shims i can put between the bearing and pin to take out that slack, i do it now on all my cars, makes everything nice and slop free, and the shim is small enough not to cause binding when i put the wheel on!
Old 02-21-2013, 07:31 PM   #1794
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
He is referring to the drive pin at the end of the drive shaft where it slots into the spool out drive.
You actually just ordered the last set from my local race track. Right under my nose and I still managed to miss them. Arrrgh!
Racing4Evo is offline   Reply With Quote
Old 02-21-2013, 09:41 PM   #1795
Bill K's Avatar
Tonight will be running the BD7 for the first time with my new flowworks team. Hope all goes well and nothing gets broken
Bill K is offline   Reply With Quote
Old 02-22-2013, 10:09 AM   #1796
Cadman1981's Avatar
Oh, i read it wrong then. Sorry about that Racing4Evo, i have been looking for these actively for a week!
There are these for sale
YOKOMO BD7 DOUBLE CARDAN UNI'S FOR SALE
The guy ships to North America and is great!
Old 02-23-2013, 01:15 AM   #1797
Hi guys, when your talking about removing the steering brace, are taking it out all together then putting washers and screws in top, or just removing the screw out the top deck?
And all so are you removing the screw out the top deck above the motor mount?
tkd662 is offline   Reply With Quote
Old 02-23-2013, 01:36 AM   #1798
Bill K's Avatar
The screw that fits the steering mechanism infront of the bulkheads can be removed, I have left the screw in above the motor mount so the top deck has some stability, and is not being held down just by both bulkheads. Otherwise it could snap with a hard enough hit.
Old 02-23-2013, 09:14 AM   #1799
Cadman1981's Avatar
Yeah, i removed the brace altogether, and put 2 shims of 0.2m and 2 button head screws. For the screw on the motor mount, what Bill K said!
Old 02-23-2013, 10:24 AM   #1800
Cadman1981's Avatar
Where is Yokomo's presence at the TITC 2013?? I can't see many pics of their cars.
But i am seeing new Tamiya TRF417 parts, and Yokomo parts on the Tamiya's too!
TRF417 avec Yokomo BD7 motor mount (+perhaps layshaft and center pullies?) + different lower & upper deck...
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
