Like Tree5Likes
Old 02-15-2013, 10:10 AM   #1756
I did the same as you.
May I suggest you save the time I wasted and just fit the graphite parts.
cyclonetog is offline   Reply With Quote
Old 02-15-2013, 10:50 AM   #1757
scoyle's Avatar
I had heard that this was the way to go... I am doing a review of the car for my web site so I will go with the car 'out of the box' and then go pretty much immediately to the graphite parts as I will be running on carpet - it means I can document the differences between the two compounds.
...and my build has started
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 02-15-2013, 07:59 PM   #1758
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by scoyle View Post
Thanks for the quick replies - will start carpet minus the graphite parts and then work from there (have bought the graphite stuff planning to go to the complete carpet setup).
WIll have a look at those others as well... thanks.
only option part on my car is black bladders dcjs in the front and 44.2mm front wishbone hanger when steering block strip going put graphite 1s on
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 02-16-2013, 06:02 AM   #1759
NolanP's Avatar
So I pretty much copied Volker's base carpet setup and went with Black springs in the front and Green in the rear for Sorex tires.
For Jaco Blues I have Black and Yellows. Works pretty nice in mod.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 02-16-2013, 07:28 AM   #1760
Craig W's Avatar
so u running soft spring on front
Old 02-16-2013, 07:50 AM   #1761
NolanP's Avatar
yes. on carpet. We are a low/medium traction carpet track.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 02-18-2013, 03:20 PM   #1762
Cadman1981's Avatar
This was posted by Yukijiro Umino on Facebook
Practice Day5.
Old tires are also good for working.
Today, I want the setting at Old tire.
Also test the new parts is well.
:-) — with Ronald Völker.
PLEASE, NEW REDESIGNED DCJs!!!
Cadman1981 is offline   Reply With Quote
Old 02-18-2013, 09:25 PM   #1763
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Practice Day5.
Haha! I was thinking the same thing and couldn't have said it better.
Racing4Evo is offline   Reply With Quote
Old 02-19-2013, 05:50 AM   #1764
Aaron_M's Avatar
Spec R V2 DCJ are very good
Yokomo BD7
Aaron_M is offline   Reply With Quote
Old 02-19-2013, 08:47 AM   #1765
scoyle's Avatar
In the end I got so much feedback about going Graphite for carpet that I did it as part of the build LOL
This car builds up so well - the quality of the parts and fit is extremely good. Looking forward to completing the build and getting a run with the car.
Old 02-19-2013, 12:12 PM   #1766
Trader Rating: 43 (100%+)
are you guys using double sided tape under the servo with the Aluminum special servo mount?
aceinthesky is offline   Reply With Quote
Old 02-19-2013, 12:33 PM   #1767
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
shouldn't have to... plus you don't want to do that..it will tweek the chassis
OVA is offline   Reply With Quote
Old 02-19-2013, 12:42 PM   #1768
It does build very well, much better than I expected. I built a Yok a good few years back which gave me reservations about getting the BD7, but things are much different now and it's the best kit I've built for years.
The whole point is that there is no contact between the servo and the chassis, so mount the servo hard up against the top of the mount.
Old 02-19-2013, 04:52 PM   #1769
Cadman1981's Avatar
Do the Spec-R V2 DCJ take the same pin for the hex as the stock ones? and also the same bearings??
Old 02-19-2013, 05:15 PM   #1770
caltek1's Avatar
Trader Rating: 36 (100%+)
The specR V2 come with a thinner bearing for the inside of the knuckle and yes the pin for the hex is the same. These are being used by a few racers at TITC. There are some BD7's that have had some dremel tweaking to achieve FDR in the 3.16 range for non boosted.
I am using 6mm lower shock towers with the new Serpent short shocks so I can fit the Tamiya IFS bodies on my car. Perhaps at some stage I will post some pictures. Most are using Meens setup available on FB, but with the graphite parts.
This track is very high grip and to compensate we are using the Yokomo blue springs front and rear or the Ride green springs front and rear. Perhaps worth a try.
We have also found that GT body shells all have differing handling characteristics. So far the NSX, AUDI R8, EBBRO , Nissan 390 are all very good.
Anyway must go. Off to do more testing today, before pre qualifiers tomorrow. Qualifying is Friday and Saturday with the A mains Sunday. As always Ronalds car looks very good on the track.
Later,
Calvin.
caltek1 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
