Like Tree2Likes
Old 02-11-2013, 09:08 PM   #1741
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
My car was really good this weekend. I think I had the fastest car at the race but I'm not as good or consistent as the other drivers in traffic so I really couldnt convert it to Tq, plus it was my first time racing mod. Im sure in better hands my car would have dominated the race but I couldnt be happier otherwise.
This is hands down the best car I've ever had and in my opinion the best all around car on the market. I've got a really nice setup on that anyone can getdrive and get comfortable with after only a few laps.
Anyone else do this to their servo mount? Helps a lot with servo centering.
Racing4Evo is offline   Reply With Quote
Old 02-11-2013, 11:29 PM   #1742
Someone tried Ride Rex34 with BD7 ??
I had some test last week-end, but the car was really difficult to drive.. Lot of understeer..
Team Awesomatix / Team Roche / Team Corally / Wild Turbo Fan
nicoo2k4 is offline   Reply With Quote
Old 02-12-2013, 06:12 PM   #1743
jumpnjack's Avatar
i tried both the red and the blue ones. i hated the red ones under steering and no traction, the blue's are great BUT they don't last very long at our asphalt track. the ring of death after 4, 7 minute heats
Awesomatix A700L, T.O.P. Rebel 10
Apex RC Pro Shop
ORCA/Pro Spec, Team EA Motorsport, Awesomatix USA, RC America, Team Powers
T.O.P Racing USA, John's BSR Racing Tires, Gravity RC, R1werks, 3Racing, TQ Wire
jumpnjack is offline   Reply With Quote
Old 02-12-2013, 09:40 PM   #1744
12scale's Avatar
My son has found in stock the red rides under steered and did not have as much traction as the muchmore's we were using, but now he has moved to mod the rides seem to provide a lot more steering which has improved his lap times (strange I know).
Stuart McMillan
Xray T4 2015
Hobbywing/Sanwa/Pro Amps
Adelaide RC Team Mechanic
www.adelaiderc.com.au
12scale is offline   Reply With Quote
Old 02-13-2013, 10:41 AM   #1745
Cadman1981's Avatar
I did the same mod! It helps keep the servo from shifting/rotating side to side, but i didn't put a shim or nut, i just put the antenna mound directly to the servo mount. I wonder why Yokomo didn't just put a 3rd screw tread there...
Cadman1981 is offline   Reply With Quote
Old 02-13-2013, 10:45 AM   #1746
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
I did the same with the shim..
OVA is offline   Reply With Quote
Old 02-13-2013, 10:48 AM   #1747
OVA
OVA's Avatar
So Far runing the 17.5..I switched the spring around ..pink in the rear blue front..works much better, the steering is less aggressive it mellow out the steering as well...
Old 02-14-2013, 03:41 AM   #1748
jumpnjack's Avatar
Originally Posted by OVA View Post
So Far runing the 17.5..I switched the spring aroung ..pink in the rear blue front..work much better, the steering is less aggressive and mellow out the steering
we did the same at IIC last year it helped, we also went to 550 oil
Apex RC Pro Shop
Old 02-14-2013, 07:56 AM   #1749
OVA
OVA's Avatar
I went to 400cst and 500cst..Are you saying 550cst front and rear?
Old 02-14-2013, 11:24 AM   #1750
At IIC it was 650 front blue springs and 600 rear pink springs.
HawaiiBob is offline   Reply With Quote
Old 02-14-2013, 12:30 PM   #1751
OVA
OVA's Avatar
I will try out this weekend...Thanks
Old 02-15-2013, 05:45 AM   #1752
scoyle's Avatar
Hi, guys, have decided to join you and have bought myself a BD7...
Quick question with regard to the base setup that you arrive at when building the car following the manual steps - Is this a mix of the Carpet and Asphalt setup sheets that have been published on PetitRC? Seems to be closer to the Carpet setup (minus the graphite arms) as it is the Suspension blocks that are in the kit but then the springs are Blue/Pink in the kit which is the Asphalt setup...
Is there a setup sheet that shows the setup for the kit?
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 02-15-2013, 07:58 AM   #1753
I don't think I've seen a setup sheet for the "kit build".
I did run the kit build setup to start, but changed to the Yokomo base carpet setup and found the car much better, not really sure what the kit build setup is for?
cyclonetog is offline   Reply With Quote
Old 02-15-2013, 08:38 AM   #1754
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
this is kit setup sheet
http://www.petitrc.com/reglages/yoko...arpetSetup.pdf
here ronalds
http://www.petitrc.com/reglages/yoko...orSetup201211/
this work most places
http://www.teamyokomo.com/download/s...7_yamauchi.pdf
mibo is good start point
http://www.petitrc.com/reglages/yoko...rtCup20121017/
hope all these like helps
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 02-15-2013, 09:02 AM   #1755
scoyle's Avatar
Thanks for the quick replies - will start carpet minus the graphite parts and then work from there (have bought the graphite stuff planning to go to the complete carpet setup).
WIll have a look at those others as well... thanks.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
