Old 02-05-2013, 02:42 PM   #1711
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by NolanP View Post
So how many of you who are having issues played with different Yokomo Springs?
Stock yokomo spring are too soft ..but the HPI Pink and Silver works for me ..
OVA is offline   Reply With Quote
Old 02-05-2013, 02:46 PM   #1712
NolanP's Avatar
Did you just switch to the HPI springs or did you try Yok orange and greens?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 02-05-2013, 09:01 PM   #1713
Bill K's Avatar
I have some spare Schumacher Green, red and white spings; would these fit on the yokomo?
Bill K is offline   Reply With Quote
Old 02-05-2013, 09:44 PM   #1714
OVA
OVA's Avatar
yes I just switch to hpi..for now..
I don't have any other yokomo option spring in hand..I did have those HPI on my Tamiya and they works really well..
Old 02-05-2013, 09:59 PM   #1715
12scale's Avatar
Ride red springs front and rear work well also.
Stuart McMillan
Xray T4 2015
Hobbywing/Sanwa/Pro Amps
Adelaide RC Team Mechanic
www.adelaiderc.com.au
12scale is offline   Reply With Quote
Old 02-05-2013, 10:03 PM   #1716
The schumacher springs have a much smaller ID. But if they fit the perches, they should work. Those ones you have won't work well together, though. Green and red will be too stiff. White front and rear might work on asphalt, but probably too soft for carpet.
My schui on carpet actually works well with yokomo pink front and blue rear. Better than with the hpi pink/silver. I have some more yokomo springs you can try when I get back from Hong Kong.
-Mike
Old 02-05-2013, 10:15 PM   #1717
OVA
OVA's Avatar
-Mike
Hi Mike
can you pick some yokomo option springs for me too?
all I have is two set of pink and blue for now..
Old 02-06-2013, 08:49 AM   #1718
There's something about the Yok pink/blue springs that make them work on carpet with rubber tyres.
I have also tried the Moorespeed Red/Grey springs and they work very well on the BD7 on carpet.
The HPI springs are probably best used on tarmac.
cyclonetog is offline   Reply With Quote
Old 02-06-2013, 09:08 AM   #1719
The Evicerator
Can anyone tell me how wide the bd7 chassis is?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 02-06-2013, 11:11 AM   #1720
NolanP's Avatar
I'm using Black fronts and Green Rears or Pink rears pending traction.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 02-07-2013, 05:48 PM   #1721
jumpnjack's Avatar
stock yokomo is 85mm
the sco is 84.8 mm
Awesomatix A700L, T.O.P. Rebel 10
Apex RC Pro Shop
ORCA/Pro Spec, Team EA Motorsport, Awesomatix USA, RC America, Team Powers
T.O.P Racing USA, John's BSR Racing Tires, Gravity RC, R1werks, 3Racing, TQ Wire
jumpnjack is offline   Reply With Quote
Old 02-07-2013, 05:55 PM   #1722
jumpnjack's Avatar
ya that is 301 all the way around. makes the car a little twitchy, but if it works with a little throttle control..
Apex RC Pro Shop
Old 02-08-2013, 04:35 AM   #1723
Hi guys any one have problems with the rear diff leaking oil I had it apart a few times to check it but still the oil is leaking out
Gabe
Tofast80 is offline   Reply With Quote
Old 02-08-2013, 05:22 AM   #1724
Hi, my rear diff is also leaking a little, you can see the rear belt has oil on it.
No leaking around the outdrives but just were the belt sits on the pulley.
Also does anyone run the little foam piece which sits above the Black Bladder in the Yokomo shock.
Many thanks
415tam is offline   Reply With Quote
Old 02-08-2013, 06:45 AM   #1725
I use kyosho orange color for my gear diff. So far no leak. And i use xray spring steel outdrive for the gear diff, it fit perfectly just plug and play.
minez is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
