Like Tree6Likes
Old 01-31-2013, 04:47 AM   #1666
Originally Posted by Tofast80 View Post
thanks I will have a listen and I have changed the shell I did not think that would make a difference sorry about the newbie stuff but I have always run pan cars so this is new to me but the car handles well again thanks for the help
Gabe
Gabe, the shell is a massive tuning option, probably the biggest thing after tyres.
The normal starting point on carpet is a Protoform MazdaSpeed 6, really if you use that and you get a problem you'll know it's not the shell.
cyclonetog is offline   Reply With Quote
Old 01-31-2013, 05:20 AM   #1667
Ok thanks that's the body I changed to so t will check the shocks I am going to run it tonight and see if that was the problem thanks for the help I will keep you posted
Gabe
Tofast80 is offline   Reply With Quote
Old 01-31-2013, 05:33 AM   #1668
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
or montech nazda 2.0
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 01-31-2013, 05:38 AM   #1669
Originally Posted by rai View Post
Does anyone has the same problem when their BD's accidentally hit the barrier on the front and as a result the centering was just way off? I'm talking about BD7 chassis using the floating servo.
Did you have the steering bridge off? It tweaks much more easier if its off
zzztech is offline   Reply With Quote
Old 01-31-2013, 12:38 PM   #1670
5tylez's Avatar
Gabe
Gabe make sure your car isnt tweaked and that you have equal droop settings from left to right. also check that your tires aren't coming unglued, as that will cause your car to do weird stuff.
I'll have a look next time I'm at UR.
A bunch of us are hitting St Catherines this sunday. Come if you can!
thx
Chris.
5tylez is offline   Reply With Quote
Old 01-31-2013, 03:20 PM   #1671
Hoot RC's Avatar
Thumbs up
Big news on RedRC.
The Meen Vejrak has joined the team and is running at TITC!!! We are very keen to see his setups and wish him good racing...
more details @ http://www.redrc.net/2013/01/meen-ve...s-team-yokomo/
the Hoot guys
Hoot RC
[email protected]
www.hootrc.com.au The shop for RC Racers.
Hoot RC is offline   Reply With Quote
Old 01-31-2013, 05:37 PM   #1672
rosko's Avatar
Yokomo is putting together a really good squad
rosko is offline   Reply With Quote
Old 01-31-2013, 06:50 PM   #1673
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
hope yokomo can win the world next year..
meen will attend next ETS round...thats is good to hear !
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-01-2013, 03:16 AM   #1674
Stilo's Avatar
I had that problem also and found out that my floating servo mount was able to turn a bit even with the two screws tight on the chassis(center was off 3-4 clicks of trim). I used a long screw to screw through the antenna mount hole to secure the servo mount with 3 screws to chassis. After that I havenīt had that problem. A friend of mine thinks the screws that come through the cassis bottom out to the servo mount threads before fully locking the mount, so you could try to drill like 0,5mm off from the threads to ensure that doesnīt happen. But 3rd screw works also.
Team EuroRC.com
Stilo is offline   Reply With Quote
Old 02-01-2013, 11:32 AM   #1675
Here the same story , a little touch is enough.
In the beginning i was thinkin that the servohorn jump over because of driving without servo saver.
Asso B5M
Sanwa M11X
Team Orion
Kevin E. is offline   Reply With Quote
Old 02-01-2013, 01:25 PM   #1676
Spillertwo's Avatar
In this age of control tires i was wondering how you guys deal with traction rolls on carpet if you can not change the tire.
In what order would you start adjusting the BD7 ?
I'm thinking in this order
stiffer anti roll bars
higher droop values
stiffer springs
dampers more vertical
What would your advice be ?
Spillertwo is offline   Reply With Quote
Old 02-01-2013, 05:44 PM   #1677
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
higher droop values
stiffer springs
try applying CA glue on the side walls of your tires. some spacers on the wheel hexes to widen your car's track width and use light weight bodies.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 02-01-2013, 06:08 PM   #1678
Nuno Gancho's Avatar
What do we call When in the Front arms we have them backwards because we used 1.3 independenteks instead 2.0 blocks.
Have anyone tried that on a Yokomo.
Nuno Gancho is offline   Reply With Quote
Old 02-02-2013, 01:23 AM   #1679
Spillertwo's Avatar
Indeed CA glue was the one that was forgotten.
Spacers i have already on the rear wheels and the front wheels are 0.7mm wider with the use of other blocks.
Light weight body i'm going to try. Just sprayed the first one but the weight difference is only 7gr on the scale. But we'll give it a try.
Old 02-02-2013, 02:03 AM   #1680
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
higher droop values
stiffer springs
I suggest the opposite in terms of springs and width. You want to make the car softer and norrower. It may seem counter intuitive but thats what works for me. Youre on the right track for droop. I like to run even front to rear droop when the front end has too much traction.
Racing4Evo is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
