Old 01-22-2013, 02:43 AM   #1621
Can anyone tell me, out of the Titanium screws and turnbuckles, which offer the biggest weight saving over the kit standard steel equivalents? Since both Titanium items cost about the same amount, I'm looking for the biggest weight saving for the money.
rosey1990 is offline   Reply With Quote
Old 01-22-2013, 03:48 AM   #1622
Bill K's Avatar
Here's what you can do. Take one screw of each kind, and one turn buckle of each kind. Weigh them all and times it by how many of that specific screw/buckle there is. Then add it all into categories and add it all together. The set with the most weight, is the set that is worth replacing with Titanium upgrades.
Sorry if this confused you, but this way of calculation should work for you.
If you have any issues, feel free to contact me back.
Regards
Bill
Bill K is offline   Reply With Quote
Old 01-22-2013, 05:30 AM   #1623
Aaron_M's Avatar
If it helps the steel turnbuckles weigh 11 grams in total. I took all mine off last night and replaced them with TC6 titanium ones, which weighed 7 grams in total. Not that much of a saving really. I suppose everything helps a little bit
Yokomo BD7
Aaron_M is offline   Reply With Quote
Old 01-22-2013, 05:47 AM   #1624
NolanP's Avatar
maybe not but to be able to put 4 grams on the bottom center of the chassis instead of up high does help. I'm sure if you switched to all titanium screws about above the chassis and leave the steel screws on the bottom I bet you could save some weight and effect the car that way.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 01-22-2013, 06:46 AM   #1625
Thanks for your help. I guess there is probably more weight to be saved by purchasing the Titanium screw set instead then.
Old 01-22-2013, 07:20 AM   #1626
Cadman1981's Avatar
Originally Posted by caltek1 View Post
I have never had a binding issue with Tamiya DCJ's in my BD7. I have not modified anything and no binding. Mine have been in the car for three or four months.
Which ones did you get? Part number
Cadman1981 is offline   Reply With Quote
Old 01-22-2013, 08:16 AM   #1627
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
I did the same thing..but there's a little binding between the axles pin and the outer bearing...Keith Yu pointed out to me that the I had a bad bearing ..If you move the front wheel just alittle and you will feel the bearing is binding ...the stock yokomo and Tamiya is about .010 differnce
OVA is offline   Reply With Quote
Old 01-22-2013, 09:53 AM   #1628
Cadman1981's Avatar
Is the axel pin too close to the bearing with the tamiya DCJ?
Old 01-22-2013, 10:42 AM   #1629
OVA
OVA's Avatar
it seem to be okay after you put on the wheel hex adapter. but as soon you tighten the wheel nut is bind a little..yes
Old 01-22-2013, 12:36 PM   #1630
5tylez's Avatar
Originally Posted by Racing4Evo View Post
I want to try this but doesn't this mess with the Ackerman?
yes it does, but i my opinion for the better. My Bd7 is easier to drive.
5tylez is offline   Reply With Quote
Old 01-22-2013, 12:39 PM   #1631
5tylez's Avatar
Originally Posted by Bill K View Post
Did a hot lap with my BD7 today. Will be uploading to YouTube soon!
I take it you enjoyed your first outing on the BD7?
Old 01-22-2013, 04:11 PM   #1632
Bill K's Avatar
Yes indeed!
Heres a link to the youtube video I uploaded. Stock setup, stock parts, great car. I can't really think of anything that needs to be improved on the car besides the motor and servo I'm using, which are both on the way.
Other then that, this car is amazing and suits my driving style quite well. It takes off like a rocket and drives like a beast
http://www.youtube.com/watch?v=a7tYk31ttjs
Regards
Bill
Old 01-23-2013, 11:39 PM   #1633
Trader Rating: 25 (100%+)
Hi, can someone help me find a starting point on which pinion gears to purchase. I want to buy around 3-6 pinions. This is my first onroad car. I am using a 64p (96t). Esc is a SXX TC V2. Motor is Orion VST 10.5 running on a medium asphalt track. Thanks in advance.
bomber9 is offline   Reply With Quote
Old 01-23-2013, 11:45 PM   #1634
Bill K's Avatar
Firstly, I suggest you convert your gearing to 48pitch as 64 pitch spur gears seem to strip quite easily and you'll find yourself spending more money than you'll need to.
Secondly, what car are you running?
Old 01-23-2013, 11:57 PM   #1635
Bill K, I am running a BD7. Do they make 48p for the car. If I were to keep it at 64p, what pinion gears would you recommend.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
